Of course, the whole discussion is sort of a mute point. Real world, single emitter lights don't have to go to extremes, just clean the surfaces and apply whatever you want, either thermal compound or thermal adhesive and give it some pressure. Good enough for 95% of the lights out there and only a highly modded "hot light", would really need the extra attention.
Even with those, most of us would use it a few times, for short periond and then put it on the shelf, sell it, trade it, or give it away, so in 99% of the cases, it's not really a big issue, it's just an issue in our minds.
I dunno, a lot of the performance CPU heatsinks out there are pretty much lapped out of the box. If you automate the process the time overhead is really fairly small. Coming from a computing background I’m surprised just how badly heat is managed in flashlights, the amount of thermal gunk in my bike lights suggests that they never read the instructions as it’s far to thick to be effective.
You really want to avoid getting thermal paste on your skin. The AS stuff can be quite toxic and is a bugger to remove as it really gets into the pores.
hah! But if we weren’t OCD, we’d just buy a Craftsman LED torch from Walmart and be happy with it, wouldn’t we
I’d wager that most of the single emitter lights on here would benefit greatly from better thermal management, given how much heat they’re producing in such a small place. You only have to look at the output drop from switch on to +15min to see how ineffective they are at dissipating heat. I’m not saying cleaning up just one thermal interface (between star and pill) is going to magically solve that problem, but it’ll help.
All this has really got me thinking about the Jacob a60 and ke-5 I just nodded, on both I sanded then wire wooled the anodizing off and polished the stars, now perhaps, I should go further next time.
I’m also thinking I need to get an hd2010 to play with…
Pretty much all thermal compounds perform the same! The main difference between a good and poor compound is the long term stability of the carrier fluid used to make up the paste.
Sorry, I’m thinking everyone knows what I’m on about, on both the Jacobs and the ke-5, there is no pill, the light engine is part of the host, as such, its anodized just like the rest of the host, so I sanded and polished under where the star will sit, so the star was pasted direct to the host alu, rather than there being an anodized layer between the base of the star and the aluminium of the light engine, now I see, I should have also polished the base of the star flat too, something I’ve wondered about.
Lapped might be superior when done professional. With home tools? I'm unsure..
How could soldering have any negative effect? You already have a layer of solder between LED and PCB, but the layer between PCB and heatsink would have 10times the area -> better heat conduction. If you have a 1" pipe at the source it doesnt matter how many 1" pipes you add in the path, even if some are 3"..
Actually aluminium PCBs would be great if you could solder the LED directly on the aluminium, without the dielectric layer and all that stuff inbetween. Thats the main advantage of copper pcbs. I think even brass PCBs would be better if its a good alloy.
And I dont think the gold layer has any influence on thermal conductivity at all. Its there so the copper doesnt oxidate. Also, even those copper PCBs from LED-tech are uneven because they are punched out..
@ChimpOnABike: CPU heatsinks arent lapped because you need both parts for lapping. They are sometimes sanded pretty good, but often far from a mirror-like finish. Its an easy improvement actually.
Something with powdered diamond in it. Diamond powder is actually not too expensive. Check Ebay: Shop by Category | eBay%28dust%2Cpowder%29&_sacat=3213&_odkw=diamond%28dust%2Cpowder%29+mesh&_sac=1&_osacat=3213&_from=R40
well, I have lapped machined parts professionally, but I don’t think someone else needs to have been paid to do a good job. it does take some patience.
there isn’t any fluid mechanics involved here, so fluid in pipes isn’t a good analogy.
i’m not sure how to explain it differently. Maybe we’ll have to agree to disagree.
the thermal conductivity of solder is lower than the metals involved, so putting it in between them reduces thermal conductivity if they have very good contact before soldering - what happens before or after that can change the temperature gradient in operation, but not the properties of the materials at the junction.
I guess we’ll have to agree disagree.
you can solder aluminum, but it requires a different solder, or at least a different flux, and it is a PITA
any material will have ‘some’ influence but it’d be near impossible to measure
anyway, I didn’t mean to imply that’s why gold shouldn’t be removed…I meant you don’t want the copper to tarnish…which would surely reduce contact area as well as thermal conductivity…
anyway, let me know when you find copper PCBs, I’d be happy to test this scenario.
