Thanks for the review.
Is is possible to swap out the forward-clicky switch for a reverse-clicky, for the purpose of facilitating mode changes?
hmmm…. it is possible, but I dont know if there is any switch with this size and shape…
I will take a photo of the switch when I will take the beamshots and photos of the box, to help you “see” what switch it uses… but… a bit difficult to find one, I beleive… XP
Hi BLF!
I added beamshots at 3 meters, also photos of the box and the switch (sorry for the quality)
The switch is a “square” one, soldered to a PCB. Perhaps can be found… DX has about 20 different models, I dont know if any of them will fit there…
The “square” part of the switch, measures 11x11 milimeters. It has 2 pins soldered, one in one edge and the other in the other edge…. I will try to find one at DX and post it here…
Also Ill probably search for myself but I was wondering how much it is? The link to it directs to google.com
I have seen it being sold from 38$ to 42$.
I would not pay more an 25$ for…. “this”
too bad guys… the light started to flicker
I had the light powered on on med mode lying over the table… about 1 hour later, it started to flicker with no reason…
I have to find why….
I am starting to dislike this flashlight…
well they got something like a year and a half warranty on um. that should cover it… and we will get to see how their warranty service is too
Maybe I will fix it…. if it can be fixed…. I will not send nothing to anywhere in the world…… too expensive for me
Thanks, fran, for your review ;)!
Looks like another sh*t light from “premium” Chinese manufacturers who are trying hard to achieve level of quality that JetBeam/Klarus/Fenix/etc lights have.
Crelant is no premium brand.
Crelant is ....
Ok, it is not a sh*it light (but almost XD)… seriously, it is an aceptable light (not bad!) but many things could have been improved before entering into production
And about the flickering. Update. The flickering dissapeared by the same way it appeared: without doing nothing.
But… but… the continous flickering dissapeared… but now it has some “esporadic” flickering. Some times it flickers. I have tried to solve cleaning and lubing the threads (again), completely screwing the swtich assembly… but… no results. Maybe bad driver?
You guys are too hard on Crelant!
Alright, I dont own this light, but this review got me interested, however there are lots of 2xAA offers in the market today, both from “little” budget brands up to the big players and then theres somewhere between companies like Crelant.
Im just disappointed that they ask 30-40$ for a light that is quite a dud to be honest.
Thanks very much! Frontpage’d and Sticky’d.
manage to order this light after reading some reviews, still waiting for arrival.
hopefully it does much better than a Lenser P7 or Terralux 300.
Or a bad switch...? I had a light that always flickered when turning it off, changed the switch I have never seen that issues after that. Of course, prior to changing the switch ,I checked if everything is clean and properly screwed etc.
Actually I have some occasional flickering on my 4Sevens Quark AA2, which I not looked into very much, I only cleaned the threads but nothing changed.
No, the switch isnt, bcos bypassing the switch it happens. But is “randomly”…
I have the lifght and I'm not a big fan except I won it on their big crelant giveaway so the price was right ..i'd agree 28$would be a better number to be paying for a light like this ..But it seems like the lower offerings of certain manufacturers in the 25 to 40$ range almost always suck and are overpriced and underfeatured ..IE the jetbeam ba-10 ...lights made for a non aholic AA only kind of crowd who needs a name brand light IMO they usually suck ....decent finish a funky tint and a bad clip is all they offer for 40$
Thanks for the review. Would like to kindly offer a couple of points in response…
I think many of your critical points come down to personal preference. Which is OK, just what it is. You kind of admit so yourself.
You also seem to lack prioritization. Some things surely matter more than others, no? It would be good to make that more clear.
How a light is driven and regulated are crucial technical details - the most important criteria for any light IMO. You almost mention these as trivial minor details. Glad you gave 4 stars for that reason though.
Forward clicky is a matter of taste. I like forward clickies and the ability to silently use momentary. (No, its not a tactical momentary for signalling, but I don’t need that for this light.) You imply fwd clickies are inferior or cheap, but that is not accurate. There are good fwd clickies, and bad. Many of my most expensive lights have fwd clickies (good ones).
You are really bothered by the tail cap huh? It doesn’t bother me to install batteries the other way. Yes, the threads are a bit small, that is true and could be improved. But I have never come close to cross-threading or stripping them or anything like that. Just need to be careful. At least the threads are good and smooth (on mine). I guess it might kind of look less clean than some end caps, but it’s not a big deal to me.
I don’t really see how these points make it glaring that Crelant chose cost over quality. The build, feel, and fit n finish of both my models is quite good. Certainly miles away from ultrafires and stuff like that. No, their not Zebralights either, but much less expensive than them. I don’t have any finish flaws in my Crelants.
Personally, I wonder if some of the design aspects of these lights was meant to keep tinkerers from disassembling these lights. I am not a big fan of that kind of attitude, but some companies do pull that crap. Not sure about this case.
“Chinese lumens” - well…. we all should be kind of used to this by now. Unfortunately it is common practice across the board, some worse than others. Only the most expensive premium brands seem to give a crap and use realistic numbers.
I can say that my cool white V11 does seem a bit brighter than my neutral V31. This is to be expected and the difference seems proportional to comparing other cools to neutrals. Don’t have a lightmeter or anything like that to really quanitfy it.
Much of our difference in opinion might come down to the price paid. Got one of mine on clearance, and the other lightly used/reviewed from classifieds. edit: Went back and looked it up and I paid $32 for one and $26 for the other. At that price I am satisfied. If I spent $80 on the pair I would probably not be as pleased. Overall though, my experience with these lights has been positive enough that it has me looking at other Crelants. Which I imagine is their entire plan. So it worked on me. Bastards!
Just my feedback bud. Hope this might help on future write-ups. If you disagree that is OK of course, we are entitled to our own opinions. Merely politely offering my counterpoint. Good day sir.
