16650’s are a tiny-tiny bit thinner, so they will fit into lights more easily.
Great! Checked the sanyo batteries. Looks nice.
Any info on where to get a decent cheap charger?
The protected ones are longer. I just got 2 and they don’t fit my WF 139 charger.
I have had 4 off these chargers. They dont charge at a fast rate but do the job. All four have terminated at 4.18 to 4.2 volts. I highly recommend this charger.
Go with the 16650 Sanyos. I have some lights that are supposed to take 17670, but the AW 17670 I have are too fat, or so snug I worry about expansion. The Sanyos fit in anything and have a larger capacity.
16650 - 2100mA
17670 - 1100mA
Fine guys. 16650 it is. I need a budget decent charger. Even if it charges only one 16650 cell, Im fine with it.
ML-102 from Intl-Outdoor store.
Erm.
http://www.intl-outdoor.com/ml102-usb-charger-for-18650-26650-battery-p-243.html
$8.95+ $1.50 spacer+$8.5 power chord…Not so cheap
Thanks though.
Cant a 18650 charger be used to charge them?
Yes. Any Li-Ion charger will do. If it will charge an 18650, it can charge 16650.
Great if they will work. Will they fit without any spacers?
16650 are the exact same length as 18650.
16mm dia. 65.0mm Length = 16650
18mm dia. 65.0mm Length = 18650
Man this is getting complicated for me
I want to use it specifically in the Quark Pro QP2L-X.
http://www.foursevens.com/product_info.php?products_id=2918
As far as I know and based on 4sevens correspondence, 18650 cells DO NOT fit in this flashlight. Would this mean 16650 does not fit also?
EDIT:
Here is 4sevens response…They talk about WIDER….Guess it will fit??
_*Thank you for your interest. The 18650 cell is much to wide for the
body of this light. That said, two RCR123A will work great. Please let
me know if I may be of any further assistance.
Regards,
Trevor Nasko
FourSevens.com*_
I use the Sanyo 16650 exclusively in my Quark Pro QP2L-X. They are the exact same diameter as a CR123 (16340) so they slide right in.
16mm dia 34.0mm Length = 16340
THNKS BRO! Made my day
Last thing, how about this charger? http://www.fasttech.com/products/0/10000436/1046800-portable-digital-battery-charger-for-18650-recharg
I really can’t comment on the charger. It’s a crap shoot when purchasing cheap chargers. I personally believe in buying good chargers with a proven track record. If a charger doesn’t cut off early enough, and overcharges your cell past 4.2v, that’s bad. Bad for the battery, and could lead to worse catastrophic events.
But if you insist, the Sanyo 16650 is one of the few cells that is rated for 4.3v., so you have some leeway.
Great. Is the output on one 16650 as high as 2xcr123 on turbo? What about runtimes?
The way It’s regulated, output stays the same. As for runtimes, we’ll wait for you to test yours and give us a report.
Here is the reply from 4sevens just now…
*I see what you mean. The 16650 cells are not recommended either. The
light need the voltage of two cells to work best. You may gain lots of
capacity from the larger single cell, but the benefit won’t be more
than two rcr123, usually.
If you had the QP2A-X and a two 123 body, with a single 16650 cell,
this would work great.*
hehehe Why not!
