And the daft thing is that it could have been good publicity for BV / PW had they chosen to deal with it professionally.
I have an open order with them and I was contacted by them as they were concerned that I had ‘Threatened to raise a paypal dispute’ in this thread. As part of the mail exchange that followed I was sent a .gif attachment that was a screen shot of some English text that said just this.
Me thinks that you thought that I was talking to about your post in the first place, though I was simply trying to give verge's post some context.
You did follow up troll, though:
[quote=marcl]
There have been problems with fake Chinese food before and to my knowledge the only way to tell is the fortune cookies
[/quote]
Nope, I know no shame.
Anyway, off topic enough, fake or not, as long as my charger's not simply weighted with lead shot, and continues to charge batteries to a consistent level, I'm happy.
And especially suprised since I got it off FleaBay.
Im thinking about dissembling one of my i4 V2 just to take a look inside of it and post some pictures here, perhaps someone will be eager to compare them?
Is there no way you can check the serial no with the company via email first. I’m not sure you will learn much taking it apart. What if they did that when they copied it? It should look the same if they reverse engineered it.
It is just like marcl said. Two different chargers could look exactly the same both inside and outside, but still the other might be fake. Reverse engineering is very common in China. It is also possible that the fake products come from a same factory as original products.
That type of accidents is the reason I have added a 5000 volt test to my charger tests. Weak isolation and very short isolation distances will usual break down when the 5000 volt is applied.
My spouse has obtained a bunch of those wall wort chargers from eBay sellers for various camera and phone batteries and she charges her Samasung phone battery in one almost daily. While I noticed they take twice as long to charge as the GP Charger with the floating contacts, I hadn’t realized they are also twice as dangerous, perhaps it’s best to get rid of them or at least dis-assemble each one and look at the isolation distance. What would a minimum recommended distance be to pass the 5000V test?
The safety tests and specifications depends on the mains voltage, with 230VAC the distance has to be at least 4 mm through air and longer on a circuit board.
But the trafo must also have some isolations distances inside and that is impossible to see. Sometimes there is a capacitor between mains and low volt side, this capacitor must have safety rating, but on some of the cheap chargers it does not (They uses a ordinary 1000 volt capacitor).
