Yes that would make for impressive run times to say the least. Only negative there is it would make it pretty big, about like the TK70 or bigger. I would think just taking the TK75 as is, along with spare batteries would be more practical for long journeys with it. You would still get the long base run time with the 4 starting batteries, could swap out fresh runs if the time required it, but it would allow you to keep the light weight and compact size that is one of the TK’s best features. I would hate to carry around a TK70 sized light for hours on end. I say that knowing my similar sized SR90 would get pretty cumbersome too after a bit of time lugging it around.
But irregardless, it’s nice of Fenix to give you that option of battery extensions if so desired.
My brother and I both have slightly different takes and views on these lights like everyone else does but we just agree to disagree. I personally find the ergonomics and looks of the TK75 to be more to my tastes while he prefers those of the BTU. I would not trade my TK75 for his BTU or most any other power light out there. I have been watching the thread on the RC40 with a little interest but personally think that even though it should be a beast it also looks like a beast (kind of homely). I don’t think the BTU is ugly by any means. It is a little big for my personal tastes but I am glad my brother has one so that I can play with it too. Even thought I like my Tk75 better I challenge anyone to pick up a BTU in CW and shine it around a while without getting a big smile on your face. Betcha can’t do it. Lol.
The RC40 is going to be a heavy flashlight to carry at 3lbs 4oz. That’s even heavier than the TK70. And the price has yet to be seen.
I don’t have a BTU Shocker, nor can I say I really want one. The TK75 does more than I need and it’s a lot smaller and lighter to pack. I also would bet money that the quality edge would go to the TK75 no doubt. The TK75 is just a more practical light.
Great review. I’ve just bought a tk75 and it was a hard choice. I almost bought both as I like them both so much. The tk75 was cheaper and I like the size of the tk75 more than the btu.
They both get great reviews and I’ve decided that if I was to go for something as big and bulky as the btu I’d probably grab a big headed hid. I’ve got a tn31n for throw so at the moment I have no real need for much else.
Well hopefully next week or two we can do some head to head beamshots. Maybe by then rdr’s TN31MB will be in and we can do some with it as well. Of course as far as throw goes it will be in a class by itself. The Skyray king is a nice flooder and might be interesting to campare to these other big flooders.
A comparison to the SRK is always a good idea when comparing flooders as it’s such a common torch and most people know by now what they are capable of.
I wonder what warrants the pricing of the BTU except for exclusivity. The performance to TK75 is so close. I have had great CS with Fenix and I believed its a trusted brand.
With their experienced RND and excellent circuit design. I believe the TK75 is the light to go for. Now I need a holster.
rdrfronty, thanks to you for your unbiased test result. We definitely need more people like you who are willing to measure and report.
From reading your lines about testing many other flashlights experiences, just want to know is it your stand is that your BTU is not the best performer among other BTU, while your brother’s TK75 is the best performer among other TK75, this cause your result showing TK75 has equal lumen output with BTU at 30s.
We can’t just ignore the fact BTU is driven 3.8A per led, while TK75 is driven below 3A per led, both are U2, if everything is perfect, BTU should have higher output, right? But nothing is perfect.
The TK75 isnt driven at under 3a per emitter. No way. You don’t get 975otf at under 3a with a U2. Not gonna happen. At the emitter - sure, not otf. Possible put on a big slab of copper it might come close, but not in a triple led setup in a under $200 light like the TK75. It’s not gone to happen. The TK75 is driven somewhere in the 3.5-3.8a range. I’ve got U2’s and U3’s driven just slightly over 3a and they fall about 100otf short of that. I’ve got U3’s driven at 3.75a on copper pills that are almost there with about 960otf at 30sec.
But U2’s, triple setup, UNDER 3a per LED, in a factory setup, putting out 975otf each - nope.
Truthfully I don’t know. I’ve generally used the BTU’s turbo in lots of short bursts of under 1 minute. I know even while doing a lumen test in my lightbox with foam around its head (for light sealing) the light isn’t remotely starting to heat up in those 40 sec or so. The head isn’t warm at all. And I don’t feel it’s due to lack of heatsinking because the lumen output levels off very nicely, with only a slow drop after about 5-10sec.
I wouldn’t hessitate to run it on turbo well after the 3 min. kickdown. Kicking back on multiple times would likely be ok. Thats one place this lights big beefy body helps by lots of mass to absorb the heat the LED’s generate. I do need to experiment more with longer runtimes and see how it does.
Someone have already measured TK75 using power supply, at 7.5V, current draw is about 4A. That is 30Watt. If it is 100% efficiency which is impossible, each LED get 10Watt. XML driven at 3A typical voltage is 3.35V, and that is about and above 10W. So no way TK75 is driven above 3A per led. Based on this and runtime, I estimate it is 2.8A per led. XML maximum limit is 3A, no way a reliable brand like Fenix will drive it above 3A. Fenix will prefer to make it perfect in heatsink, and drive it below 3A. That is what has happened in TK75. Fenix is always playing safe. TK70 is 2.5A per led. With smaller head, it is not logical for Fenix to drive TK75 to be 3.5A per led.
About your last line about 975otf per led, maybe you have overestimated the otf. Fenix official number is 2600 lumens, that is way too low compare to your number.
