Been wanting an XML light a long time. May have to get this, Thanks Too!
Because of you, one FandyFire HD2010 is now floating in the world coming towards me :party:
When are they gonna figure out that most people buying this want it with a U2, or U3, or XM-L2, or at least a NW T6?
It arrived today. Has “Fandyfire HD2010” logo. And the weird thing is that the PVC pipe, 26650-to-18650 sleeve was glued. Can’t take it out. So I could only use 18650 on it.
Is the 18650 battery tube glued in or just a tight fit? 18650 and 26650 are the same voltage. The only difference is that everything being on a level playing field a good 26650 battery may be capable off delivering more current than an equal 18650.
If the BLF code is still good (5% off), it’s only $28.61. Mine is on the way on the fast, slow boat from China.
Did anybody notice on Fasttech’s page that this light only draws 800ma on high. Listed in the OUTPUT WARNING above the price. I have a Fandyfire HD2010 from lightscastle and it lists the draw at 2300ma, has a bigger hotspot than the Tangsfire HD2010 but otherwise they look like they were built in the same factory. Maybe they ran out of 2300ma drivers and substituted them with 800ma drivers, I’ve seen this happen many times with other parts.
Damn, I have one arriving in the mail and when I ordered no such warning was posted. I would never have ordered if I knew it only drew 800ma.
The way I keep step’n in it, I gotta buy bigger boots!!! Fricken flashlights! Hey, I ain’t given up. Just ordered the Small Sun ZY-T08!
Just change the driver.
Yep, fasttech sells the east-092 drivers don’t they?
Just checked WHO sells the East-092 driver. Guess WHO? FastTech!!! Maaaannn, size 20’s ought a do it!!!
Your fast!!
I file useful facts away…
$28.61 - HD2010,
$3.07 - East-092 driver,
$200.00 - time and labor (this skinflint ain’t cheap),
$9.99 +CRV - beer,
$.10 - electricity for soldering iron
Total - $242.77
Not bad, a $242.77 budget flashlight I can sell over at CPF!!!
Ha! I’m a jeanius!! H)
Sure it was not just one or a couple with that low output? Could just be a case of bad ground?
I like positive!! I’ll let you guys know what I get. Cheers, gotta go
I think we need more confirmation on what's going on with these lights only pulling 800mA. We need everyone that receives on to test theirs and report back. The ones that only pull 800mA could be random.
-Garry
I don’t think it is random - they have this posted:
0.8A~1A current output read the warnings section*
Output Warning: this light has an exceptionally low current draw (about 800mA on high). While this extends battery life (runtime per charge), the LED in the light is not driven to its full potential. In other words, you may find the flashlight somewhat dim compared to similar Cree XM-L lights.
If driver swapping is needed, I may want to change to one with regulation and without blinkies. what other driver works with the hd2010 besides the east092? Will this work?
