Is the 18650 battery tube glued in or just a tight fit? 18650 and 26650 are the same voltage. The only difference is that everything being on a level playing field a good 26650 battery may be capable off delivering more current than an equal 18650.
Did anybody notice on Fasttech’s page that this light only draws 800ma on high. Listed in the OUTPUT WARNING above the price. I have a Fandyfire HD2010 from lightscastle and it lists the draw at 2300ma, has a bigger hotspot than the Tangsfire HD2010 but otherwise they look like they were built in the same factory. Maybe they ran out of 2300ma drivers and substituted them with 800ma drivers, I’ve seen this happen many times with other parts.
I think we need more confirmation on what's going on with these lights only pulling 800mA. We need everyone that receives on to test theirs and report back. The ones that only pull 800mA could be random.
If driver swapping is needed, I may want to change to one with regulation and without blinkies. what other driver works with the hd2010 besides the east092? Will this work?
It’s weirdly glued to the pill. So I could screw the pill just by turning the pvc pipe. You can imagine.
Anyway, the warning message of underdriven only came out just a few days ago. And when I ordered the warning wasn’t there. How do I check if mine was a ‘good’ one or a ‘bad’ one?
