Awesome… I like the concept of the insulating kaptontape. Too bad it’s so expensive. Hard to justify that, given its limited use to me. Are there any cheaper options for something similar?
I don’t really know much about drivers to be honest. What is a pulsed direct drive? Thank you for the pics by the way!
Kapton is real affordable, I like it a lot.
I used 10mm wide kapton but I have ordered the 30mm variant,too.
One fasttech 30m are sold for 2$ ……rather cheap mine was more expensive
I am not sure how to call that driver, so I created the name myself.
Between the LEDs and the batteries is a FET who drives the LEDs. We can see this FET as an electronic switch opened or closed with the controller. The controller opens the FeT in pulses(we can here it, some noise).
I also added a o ring and cut the “pimple” on the tailboot, nice tips I had read here some times for making a flashlight tail standing. Now it can tail stand better.
Edit: I tested with almost full batteries 12.3V and I got almost 9A. I tested only 5 minutes, now I am recharging to really full batteries and will test the new peak current :bigsmile:
I was a bit surprised because the soshine 26650 are claimed as 8A max.
Edit2: I have charged them up and then pushed them with a power supply to 4.2-4.21V, current was 9.4A.
I upgraded the wire and I added a copper wire on the positive spring on the driver. Because I recognized that the current increased every time when I pressed the batteries harder down the tube.
Hobbyking sells really nice silicone wire.
It’s ultra flexible and the insulation is heat resistant.
I had ordered 1m on some different sizes, so that I have same here in case I need it.
I also have requested them on fasttech.
Edit: I have thought about it and I can’t really explain why this increased current. I have measured resistance from the removed wire and my DMM showed zero Ohms….?
But then I powered the wire with 5A from my power supply and it gets hot, I tried one of the awg22 and it stayed cool and it was double the length……?
So I am now puzzled.
Can someone please try to improve just the spring and measure current before and after.
I don’t have such pliers, I will get some and then let you know. You can’t see anything on it or at least I can’t see it that something is burnt.
Just smelled and doesn’t work anymore. If I have to buy an new one I give this Kaidomain http://kaidomain.com/product/details.S020165
a go should be interesting for 20 dollars
just posting a reply on here so its in MY POSTS so its easy to find for future reference. does anyone know of an easier way to maybe bookmark a thread for easy future locating? sorry for the interruption, thanks, ted.
s. great beamshots, thank you and everyone else who replied for listing all the detailed info. really helpful for a newb like me, appreciate everyones efforts.
Brining back an older thread. When I follow the link in the op it takes me to a “Trustfire” 9xT6 light. Although the pics are Sky Ray. Is this how it’s always been, or is it a different light now?
One thing I would mention for a long time: the kaidomain driver is for 9 LEDs in series so it won’t work with the stock wiring in the 9xT6. Stock wiring is 3s3p
When I tried using the KD 9x driver in both my Skyray and AK-47, it worked with 2 cells but would get screwy once the 3rd cell was put in.
But my question is this; why do the manufacturers wire these lights in 3s3p, is it better due to the very thin gauge wiring they use?
I have been considering rewiring my AK-47 in series and eliminating the 3s3p and using 22g silver wire, but just wondered what you think?
3Sx3P LEDs actually requires thicker wires than 9S since the current in them would be three times as much. Running 9S would might not be as efficient for the driver since it requires a higher voltage boost ratio.
