Yep, and the L2m with Manafont XML is pretty....*turn on* *cackles maniacly at light output* for the siz.
Its the awesome UI and the programmable driver that your buying. I ordered a storm several months ago for $50 from GG, but it was lost in the mail....
I recently bought a 120P second hand, and in the hand its a fat torch, but the electronic switching is awesome. The driver is just really well designed!. The parasitic drain is the lowest I've ever measured! 3.8uA at 3.7V. The low draws 8mA for 0.08 lumens, 11mA for 0.5 lumens. 700mA on max for 120 lumens. All at 3.9V, which is what I think I measured it at. The main feature is the proportionately reducing draw down to 1 lumen, with a small overhead noticable below this. The V10R goes lower, but it still draws 30 mA doing so.
Im currently running mine off 18650s, and with a trustyfire 2200mA, I can expect 10 days straight running on moonlight, and on a (low) maximum of 120 lumens, I can still get 3 clean hours of runtime. This is all on a old seoul emitter.
Mechanically the led sits in a large block of aluminium, which has a very large flat thermal contact area against the head of the torch. I.E. thermal pathway is very close to perfect. When I get my XM-Ls this will be modded. I would like to see how many lumens I can get, hopefully pushing the 250 lumen mark.
UI is equally awesome, 4 brightness modes each of which have shortcuts straight to them, each level programmable in brightness, and as a strobe/beacon/sos. With all the other extras in the programming menu, such as quick access strobe/beacon/sos, momentary function on the switch, battery cutoff, low level background flash locator to help find the torch at night, and maybe a couple more. Importantly the programming feels quite intuitive.
The storm can be cracked into a 120P with a 250 click sequence. There are documented cases where this has been done.
The 17670 tubes can be had for under $5 from light hound. I just machined out the inside by a mm or two and with some paper as an insulator I got my 18650s to work.
I think some members of CPF dont like the novatacs, especially the newer "consumer" run (the storm, classic, special ops, wichita), becasue they were outsourced to china for production to keep the cost down for their while the 120P, E, T, are still made in the US. The price reflects the costs of manufacturing, but the default opinion is that china must be worse....
Well if your after a torch with a very functional and well thought out UI and a very complete programming UI then you should give such a torch a go, but if all you want is just output/$$ and the normal click through UI is sufficient then this isn't the torch for you.
It depends. A guy on CPF mods, I'm not sure what he does, but he usually gets 300-600 lumens.
Its the XM-L mod which some people claim to do 600 lumens, We all know some people like to talk up the numbers, and sometimes its true! But I haven't done the mod myself yet, so im not going to believe it till I see it. The torch draws 700mA at 3.9V on my measurement. Given that the emitter was originally designed to take 700mA max, Im assuming that the driver is also designed to 700mA. I Don't know how the driver will react to a higher Vf of the XM-L, but assuming it still tries to push 700mA, we can only expect 250+ lumens from an XM-L. Maybe the driver will push more than 700mA but im yet to find out, but I don't expect it to be much more than that, I want to be pleasantly surprised ;)
( I havent yet read the stuff on CPF mods so im assuming that all ill be doing is an emitter swap)
You mean lower vF? Which means...i have no idea, since all the HDS lights are calibrated for at the exact lumen level (120), and have more than one hour of runtime. Everything else is rejected.
There seems to be a pretty fair review of this torch here http://www.light-reviews.com/novatac_storm/ although he doesn't cover everything...like does this thing have last mode memory????
I really like the UI, it seems very quick to navigate the modes and will be very nice if it has last mode memory and it is even nicer to know the programming can be unlocked! I will be buying one!!!
I will also say the NiteCore's Boaz is selling are very nice too and a great buy...I love mine!
Im very inclined to agree with the post above but then again i have absolutely no 1st hand experience with any of those.
Well I just did the mod... And I'm willing to bet I get 600+ lumens.
Old setup with the luxeon emitter had a tailcap measurement of 700mA, Now I get 2.95-3.05A tailcap draw at 3.9V. Should have done this LONG ago!! Its also a Beautifully smooth beam with an AWESOME tint. These photos show quite well the differences in tint, and how things appear. On my screen anyway it shows the tint difference beautifully, and its pretty close to what is seen to my eyes (ymmv... this is my screen vs what I see)
Heres some beamshots of the final product, although I havent got any beamshots of the before (luxeon), it was very close to the output beam pattern and output of my GDP EX10.
Pictures uploaded -
*Just noticed that the bathroom light was turned on... so the lights from the windows look alot brighter - making it feel like the exposure settings were changed, but they are all the same still. The improvement was really as significant as the photo suggests! (mouse over for other pic)
And heres a 4 way comparison
(M60R *800 emitter lumens quoted) - (EX10 GDP *120 lumens (similar to original 120P))
(120P with XM-L 5tint T4 mod) - (R5A3 on 14500 (which other BLF tests have suggested to be in the high 200+ lumen region?)
Excellent upgrade, okwchin...and it looks like a nice improvement to the tint as well!
okwchin - Is that mouse-over trick hard?
wouldliketoknowhowtodoitFoy
Quote the message and choose filtered HTML as input format and you can see how it's done.
When you open the "Add Image" window, click 'Advanced' and you'll see the 'Alternative Image' tools. Don't forget to tick the 'Alternative image' box.
I wrote a little how-to back when I discovered the function... maybe it is time to write a full how-to in a separate article.
Wow I should tell you guys Amazon has these for $17 plus $5 shipping unless I buy the rest of them...................hmmmmm.
http://www.amazon.com/NovaTac-120ST-Storm-LED-Flashlight/dp/B003GAEZL6
Will someone please buy the black one for me and ship it to me in australia???
I'm really itching to get another XM-L mod going! Its seriously an awesome flood light with super smooth beam. The neutral XM-Ls from cutter are equally awesome!
I just tried. Even though amazon showed 2 left in stock, at check-out it said they were all sold out. Sorry mate.
Awww.... thanks for the thought!
They are still in stock for $23 plus $5 shipping through amazon at anime_castle.
http://www.amazon.com/gp/offer-listing/B000PHX4P6/ref=dp_olp_all_mbc?ie=UTF8&condition=all
Thanks guys. Didn't know about "alternative" whatever. Looks like there's a tool bar up there with all kinds of stuff.
blindersFoy
Black.. hmm Would love to have a go at some gold! haha.
The 17670 tubes are a dark grey though, so either way it never matches.
