Iam not sure how you checked it, but you can quickly place the head to a bit cloth and you will here the noise the higher the noise the higher the PWM frequency. But i can never judge about how good PWM is because I am not one of the sensitive gays guys.
Compare it with a BLFA( and you will here a really high sound compared to the most stock trustfires and so on.
Too sad that 4xC s won’t work… I like that on the TF3T6 so much…
Yes, I’m aware of the cloth method and have used it. With the cloth method, AK produces a hardly noticable whine on Low, and Med, but not on high mode. The Skyray produces a clearly audible whine on all modes.
Typically to check PWM, I mount my camera on a tripod and point the light at a wall and count pulses, if any.
By removing the reflector, which requires popping out the driver and removing 2 screws under the reflector and replacing the + and - wires down to the driver with 22 gauge silver wire (same as Old-Lumens uses) on 3 x 26650’s you can increase power to each LED to just over 6 watts+, up from about 5.82w, but my cells static voltage was 4.05 at this point.
Thats taking into account my Trustfire 5000mAh cells don’t dip below 3.8v each under load and assuming an 80% driver efficiency. I’m sure replacing all the 30 gauge wires actually connected to each LED, would increase this number quite a bit more.
Testing the KD driver only using 2 x 26650’s in this light and on high mode, (they don’t work with 3 cells) the stock driver performed better on high mode with the same 2 x 26650’s.
Nice pics.
Thats what i like so much about my 9T6 it makes everything bright.
You can clearly see the superb King makes a lot light but with the 9 XML lights the house in the back, the wall on the right everything gets lighted up.
In the first Beamshots the AK74 looked a bit brighter than 9xT6 but in the now posted pics I cant really see a difference between the two.
I decided to use a 100 foot beam shot this time. It really allowed all the lights to stretch their legs and show what they each can do. Unfortunately since I’ve posted the Amazon link I purchased it from, they seem to be sold out now.
I believe it was Ric from CNQ that told me once, when unusual lights like the 9x T6’s first come out, he isn’t sure how popular it’ll be. So he’ll only purchase may 6 or 12 and see what happens. Then if the light takes off, he has to get more. Maybe that’s why everyone that’s been purchasing from him, they are all getting different named versions of it. But I’ve only seen this version I have of the AK-47 that can actually be used with only 2 cells if needed. Interesting.
thanks richie for them beamshots! it was exactly what i needed. i think i am now convinced on the 9xml’s .
so is amazon the cheapest place to buy the ak47? after brief research, it looks to be the cheapest and the fastest delivery.
hay so since using 2x 26650 is the same tail cap voltage, so you didnt see any change in brightest with your naked eye?
only reason is because i only have two 26650’s and prefer not to buy another if i dont have to.
will king kong’s fit?
Yes, there is a 20% reduction not using the light with 3 cells. That extra voltage from the 3rd cell adds a lot, but it still produces a great amount of light. Honestly, the AK-47 is a wonderful light in 2 cell configuration, I couldn’t imagine you’d be disappointed with it.
It’s unfortunate the Skyray isn’t designed for 2 cell operation. I’m trying to get my hands on original stock drivers for the AK-47 so I can toss one in my Skyray 9x T6 for times I don’t want to use it in 3 cell configuration. KK raised top cells would work, but flat tops cells would not. I also purchased some UNprotected MNKE IMR 26650’s from Jason at EDC+, that work excellent due to their raised tops. http://edcplus.com/mnke-imr26650-3700mah-p-5.html
The other problem is over the last week or so, there have been so many different versions of this light that have suddenly popped up, it’s difficult to say what light or driver version would show up at your door. To be safe, that Amazon retailer has restocked and now shows them in stock. At least purchasing from them, if they don’t send what you want, it’s easy to return it back to Amazon. I’d say they are your best bet, not to mention these lights have also suddently gotten expensive depending on whom you purchase from.
My cousin got a nitecore tm15 at 2000 lumen yet my trustfire ak 47 supposedly at 10000 lumens is dimmer. I opened it up to take a look if its then resistor is not connected and to my surprise, the resistor arent there at all.
So I assume the driver appeared to look exactly like the one in my photo of my AK-47? I just want to make sure yours has the same driver as mine. If possible, see if you can post a photo of the driver.
Its exactly the same driver just without the resistor. I am using my phone to type this so cannot post picture. Can just use copper wire to connect the two ends?
To the right of that large capacitor, you should see a total of 3 resistors. If you only see 2 of them, then one is missing, which is the one that was falling off on mine, and resoldered on.
This is all mess. I would like to start project about finding good and quality drivers and place to buy, so we can have clear situation.
I had problems with KD 5 led driver, now I wait for KD 9 led driver which is junk as Richie said.
We must find good and reilable high power drivers to sort this mess. Price is not the problem, 30 - 50 USD driver is ok as long as it is real deal-
Tell me your thoughts.
“Hi friend,it will be the same as we described. Output power:3-4 li-ion battery LED current 2.8-3A,70-100W. Modes: High 10% Mid 30% Low 5% ”
This is what KD engenear told me. So no strobe no sos and high power with 3 or 4 bat.
We need to find good drivers for multiple XML lights. In this moment I have TR-3T6, SR King and TR-J12 and AK47 on the way, all multiple XML
Lets go start topic?
Guys, you can use the KD 9x driver in these lights but only on 2 cells. As an example below:
AK-47 stock driver - 2 x 26650 Trustfire cells HIGH mode 4.50a+ tailcap or 2.96w per LED.
AK-47 KD 9x driver –2 x 26650 Trustfire cells HIGH mode 4.55a tailcap
AK-47 KD 9x driver - 2 x 26650 MNKE IMR UNprotected cells - 7.85a tailcap or 5.1w per LED.
The MNKE cells are perfectly at home in a light that pulls this much power and capable of pushing more power than this. In fact, the cells were holding that current rather than the Trustfire 5000mAh cells that start to fall off steadily.
Even though this KD driver is a 5-mode with blinkies, on 2 cells, it’s nearly as bright and powerful as the stock driver is on 3 cells.
To go with the MNKE cells, it’s $15.00 per cell plus some shipping, but they are as good as you can get in unprotected cells.
If you love the AK-47 in 3 cell configuration, try it in 2 cells. It’s one heck of a powerhouse in a more compact light and looks fantastic.
