Help a noob please! Whats the difference between these and which one do you recomend?
Thanks!
Thanks!
More AMC chips equals higher output on high. (downside is more heat and less battery life).
The first numbers after XM-L is BIN. It tells you about the expected output/efficiency of the led. Read more here
The number after bin is tint. Or color temperatur. Here is a chart I made for the tints sold from Fasttech:
I would have bought it with 8x AMC and 5C tint. But I prefer warmer tintsā¦
+1
So the U2 8xamc will give me maximum brightness?
Yesā¦
The 8 chips (8x350) they use gives a total of 2,8 Amps.
6 chips gives a total of 2,1 Amps.
See the XM-L specs/chart in the link in my previous post for more infoā¦
Must appreciated review. Many thanks. Ive been using the M1 now for over a week; and I like it a lot. Itās got a lot going for it.
I got the very same one thatās being reviewed here. Probably the best thing about the M1 is the tints/drive levels available, since everyone has his own preferenceā¦
Hey JohnnyMac, is there any chance you could take a photo of the M1 with a L2T or L2P (or some solarforce L2*)? I have an M1 on order from FastTech, but Iād like to see the comparison for sizeā¦
Thanks!
PPtk
Very helpful review, and I do believe itās time to order oneā¦
I must admit, I like the appearance of the M2 more, but you mentioned something about the M1 performing better. Will you explain why?
Beamshot and comparison pics added to the original post.
Better throw due to larger reflector while still providing great spill and much better heat management due to head design. Donāt get me wrong, the M2 is a great light and you wonāt go wrong getting one. I am just surprised because I like the M1 a whole lot more than I expected to.
The M2 is the same size as a p60. Granted, the L2T does look and feel a little smaller than the other L2 models but I was surprised that the M1 was actually larger than the L2T. Not much, as you can see in the pics, but enough, especially in head diameter.
Thanks Very Much!
The M1 is bigger than I pictured it. Guess Iāll have to order an M2 as well.
PPtk
Excellent review Johnny. Another item to add to the wishlist for my next order. Seems as though this is a much better alternative to the Solarforce builds that I've done.
Thanks for the review JohnnyMac. Interesting light. The battery tube reminds me of the Shadow line of lights.
I have yet to own a Convoy, I might start with a S2 then work my way up to the M1. They really do look well made. Thanks for the detailed review!
Great review. Thanks for that.
Also, I am very impressed with Fasttech. They seam to go the extra mile and care about the customer, which is rare for a Chinese based company.
One suggestion on your review. I always find it helpful to see lights in someones hand to get an idea on its size. You have parts in your hand which helps, but a hand actually holding the light is good.
Thanks again.
hi thanks very much.
would a āPanasonic Protected NCR18650A Rechargeable 3100mAh 3.7V 18650 Lithium Batteryā fit the M1 ?.
might order a pair along with the M1 7C tint.
thanks.
With those cooling fins in the head, it looks like it is asking to be driven to 5+ amps
Thanks, helpful pictorial descriptions of the flashlight parts!
Ask and you might receive. In this case you did. Iāve added in hand pics to the OP.
