So the U2 8xamc will give me maximum brightness?
Yes…
The 8 chips (8x350) they use gives a total of 2,8 Amps.
6 chips gives a total of 2,1 Amps.
See the XM-L specs/chart in the link in my previous post for more info…
Must appreciated review. Many thanks. Ive been using the M1 now for over a week; and I like it a lot. It’s got a lot going for it.
I got the very same one that’s being reviewed here. Probably the best thing about the M1 is the tints/drive levels available, since everyone has his own preference…
Hey JohnnyMac, is there any chance you could take a photo of the M1 with a L2T or L2P (or some solarforce L2*)? I have an M1 on order from FastTech, but I’d like to see the comparison for size…
Thanks!
PPtk
Very helpful review, and I do believe it’s time to order one…
I must admit, I like the appearance of the M2 more, but you mentioned something about the M1 performing better. Will you explain why?
Beamshot and comparison pics added to the original post.
Better throw due to larger reflector while still providing great spill and much better heat management due to head design. Don’t get me wrong, the M2 is a great light and you won’t go wrong getting one. I am just surprised because I like the M1 a whole lot more than I expected to.
The M2 is the same size as a p60. Granted, the L2T does look and feel a little smaller than the other L2 models but I was surprised that the M1 was actually larger than the L2T. Not much, as you can see in the pics, but enough, especially in head diameter.
Thanks Very Much!
The M1 is bigger than I pictured it. Guess I’ll have to order an M2 as well.
PPtk
Excellent review Johnny. Another item to add to the wishlist for my next order. Seems as though this is a much better alternative to the Solarforce builds that I've done.
Thanks for the review JohnnyMac. Interesting light. The battery tube reminds me of the Shadow line of lights.
I have yet to own a Convoy, I might start with a S2 then work my way up to the M1. They really do look well made. Thanks for the detailed review!
Great review. Thanks for that.
Also, I am very impressed with Fasttech. They seam to go the extra mile and care about the customer, which is rare for a Chinese based company.
One suggestion on your review. I always find it helpful to see lights in someones hand to get an idea on its size. You have parts in your hand which helps, but a hand actually holding the light is good.
Thanks again.
hi thanks very much.
would a “Panasonic Protected NCR18650A Rechargeable 3100mAh 3.7V 18650 Lithium Battery” fit the M1 ?.
might order a pair along with the M1 7C tint.
thanks.
With those cooling fins in the head, it looks like it is asking to be driven to 5+ amps
Thanks, helpful pictorial descriptions of the flashlight parts!
Ask and you might receive. In this case you did. I’ve added in hand pics to the OP.
Quick question. I just bought this M1: Convoy M1 Cree XM-L U2-1B 2-Group 3/5-Mode 350LM LED Flashlight (1 x 18650 / AMC7135*8 / HA-III). On specs it says rated 350LM, while others T6-3C, T4-7C, T5-5C that are also AMC7135*8 are rated 700LM on the Fasttech website. Did I just purchase the wrong one?
Must just be a typo in the specs.
Yeah, that’s just a typo in the specs. If you look closely you will see that it says >350 lumens and it is, by twice that amount at least.
As long as you bought the AMC7135*8 version you shouldn't worry. :)
