Thanks for the links. I think that the measurements in that comment are made with Trustfire cells; I was interested if there’s a difference with MNKE IMR Unprotected cells on the AK-47 stock driver. Thanks
I went through my notes and surprisingly didn't find the answer, so I temporarily tossed the stock driver (which is great) back into the Trustfire AK-47 so I can give you the correct answer on this one.
Additionally, if you install the KD driver in this light, Trustfire 5000mAh cells will NOT work. You may be able to
get the light to come on as far as MED mode, if you're lucky, but the light is undependable with the KD driver and Trustfire 26650 cells.
I'm hoping the ENERPOWER+ Protected 26650 4500 mAh (Tensai) PCB 9A cells will be able to smoke the Trustfires. The Enerpower cells are coming to me with a 9a protection circuit, and apparently not the 8a I've seen. I'll assume they'll be fine with more capacity too. I'll post when I have the cells in hand.
Zeus, I purchased it from the same vendor Old-Lumens purchased from, this ebay seller linked below. He also has various other sizes and types, so if you require something different, check his other auctions.
Just found another great set of 26650 cells that I had shipped in from Germany 7 days ago. Just charged up these EnerPower 4500mAh protected cells to 4.2v each. Tossed three in, the light came on super bright with a tail cap current at 8.14 amps. They effortlessly powered this modified Trustfire AK-47 with a KD driver installed as easily as the MNKE unprotected cells have. Remember, this is a 90 watt flashlight now. I’ve never seen 26650 protected cells with this much power before and it won’t be cheap for this type of quality cell.
Yep, my Trustfire 26650’s are great cells, but this particular flashlight, pushing this much power is beyond their output rating, but have been great in every other light I have.
I’m sure these new cells will be about $5.00 more per cells than the MNKE cells, but it’s nice to have choices when it comes to high output and quality cells that will keep performing. As soon as my hobby charger arrives, I’ll be able to check these new cells out indepth.
Super cells they are. Thanks for all the measurements. Can you please tell me how to pull out the driver from ak-47? Must I unscrew the driver or take it out by force? Thanks!
You unscrew the top retaining ring. You’ll need either needle nose plyers, or snap ring removers and press them into the 2 holes and twist. If you don’t have either of those, try to get the ring out by using two nails in those holes.
Once the ring is removed, the driver should lift out. If it appears stuck, try and carefully lift it from one side if you can get something sharp under one side of it. The driver itself is not screwed in, it just sits in the seat.
That’s a great question. I’ve been using the stock Omten 1.5a 250v PBS-101 switch it came with. In fact, I’m looking into purchasing a few spares or see about retrofitting a Jabsco (spelling?) The Jabsco switches I’ve seen have wires, so I’d have to figure out how to remove the wires so it installs and functions as the stock switch, perhaps allow some extra power to get to the LED’s as well.
Tested the light with 18650’s this time to see how they handle the power of the KD driver.
Using Redilast 2600mAh cells fully charged, just as the light came onto medium mode, about 4.85 amps, one cell tripped it’s protection.
Removed them and tossed in 3 Redilast 3100mAh cells, the light worked on all modes. On high, tail current was only slightly low at 7.85 amps. I left the light on high for about a minute with no problems.
Looks like there seems to be a problem with these AK-47’s that I had hoped would have been an incorrect assumption on my part from my original post.
I’ve got a second AK-47 in my hands that I’m upgrading for a forum member with the KD driver. All is fine with the light physically and is mint, but the stock driver I removed not only had one of the 3 resistors off, it was actually missing having never been installed.
Without this 3rd resistor, this has the effect of not allowing the light to push more than about 3 amps at the tail cap on high mode with 3 cells. With the resistor in place, the stock driver would pull well past 5 amps despending on how good the cells are.
At least the one I purchased recently, the 3rd resistor was present, just not soldered on sufficiently, so it was an easy fix. The one I’m working on now will have a 5-mode KD driver installed within the hour and pull over 8 amps at the tail on high mode with 3 MNKE cells in it. So this one will light up Broadway.
Sorry to give the bad news, but if you upgrade the driver, it’s simply a wall of light.
I don’t have a spare R820 resistor the stock driver is missing. But the member is allowing me to keep it as a spare, so I’m going to see about getting some. My wife loved the output of my light, I ended up placing an order for the last AK-47 that Amazon dealer had on hand, so it looks like I’m going to have to fix a third one.
She wants to use it in a 2 cell configuration because it’s pretty compact, so that’s fine. I also have some KD 3-mode drivers on order, so I’ll be able to get the power level up to what I feel it should be.
I just receied my multimeter. By the tailcap I got 3.2a falling out quickly. In the stock driver are just 2 resistors, one is completely missing, and I thought this is a powerfull flashlight. I ordered immediately 3 Enerpower 26650 cells and a KD 3-mode driver. I can’t wait to blind myself;) I’m so thankful for all the information I got here. Thanks!
i so cannot wait to get my modded ak47 this week! thanks again richie for the helping hand with this mod.
wow, so you got the last one from that seller? when i ordered, he had 6 left hahah. and that was on thursday lol and today is what saturday . geez this thread must have gotten seen hehe
Strauss, sorry this has happened, but it has become a very familiar situation with these Chinese lights. The first run tend to be decent, but if they sell out quick and they have to restock, the newest ones usually have cheaper parts and components installed.
This latest version from Amazon did away with the GITD O-ring at the lens, no 3rd resistor on the driver, and the plunger on the tailcap spring is to short to allow the use of the shorter unprotected cells reliably. So I removed the link from my OP. I’d say if anyone still wants one of these lights, try the one from Manafont. Hopefully it will be better.
With all the different versions and changes going on with the manufacturing process for this light, I thought it would be best to post some additional photos for clarification.
This photo shows the proper length brass tail cap plunger on my first example AK-47 at .434 mm length. This plunger will allow
the use of any length protected or unprotected cells to make proper -B battery contact.
Sorry for the blurry photo. This is what the long plunger looks like removed from the tailcap. The smaller version
below it is what I removed from BLF member blueb8llz’s AK-47, which is only .278 mm long, and replaced it with the longer one.
Fortunately I was very thourough when testing his light with both the longer EnerPower protected button-top 26650 4500mAh cells
and then with unprotected MNKE 26650 button-top cells and quickly realized there was a problem. Due to the shorter length of the MNKE, which are similar to the King Kong cells, the light would flicker due to improper cell contact when moved around. I had several spare correct size brass plungers in my spare parts bin, so his light is perfect. I only wish I knew where I got them from.
This last photo is a minor issue, but still a change I didn’t like. My first version had this GITD lens gasket and blueb8llz’s had a standard black one. The size seems to be 73 mm diameter and just lays inside a recess and the lens simply sits on it. I’m trying to locate some replacement GITD O-rings because I have a second AK-47 that will arrive this week and I want it just like my original.
Last night my wife needed some extra light in a room she was doing spring cleaning in. There are two 75 watt bulbs in a fixture on the ceiling, but that wasn’t enough. She asked if she could use the AK-47. I had just finished reinstalling the stock driver in the light because my encapsulated KD driver was given to blueb8llz. So I brought it in and turned it on high mode (5.75a). It appeared as if a 300 watt light was in the room now, which was much to bright. Naturally you can’t run most any light on high mode for long, so I switched it to medium, then tail standed it on a table and left the room. She was really happy for about 15 minutes and returned with the light saying it went out.
I assumed one of the EnerPower cells tripped the protection, and check them but all and were fine. Further investigating revealed the +B spring on the driver annealed and the driver also fried. Damn, I couldn’t believe it.
Lucky for me blueb8llz was generous enough to allow me to keep his stock driver so I can fix mine until my new KD 3-mode drivers arrive. Since his driver was way underpowered, I removed one of the R820 resistors from my blown driver, soldered it onto this replacement driver, then removed the crappy Trustfire +B spring and replaced it with one of my heavy duty gold plated ones, and also added some copper braid.
The light is back to running great with a 5.75a tail cap current, so I’m happy again. I’m certainly going to learn how to encapsulate these drivers. Clearly it makes a big difference compared to leaving them as they come from the factory.
I think I’m beginning to see why the factory now makes them 3a on high mode leaving out the 3rd resistor. This stock driver is worthless driven to what it should be and simply frys.
