Status Update: BlackShadow Terminator U3 is back in stock. We have also received another small shipment of SC52s and will be working on the backorders throughout the day.
If I’m not mistaken, I had to jump through a few annoying hoops (entering my info, going through a couple screens…) before I was finally able to plug in a coupon code so I could A) figure out the percent value of the coupon code and B) figure out the price of my items with the coupon code applied.
Please correct me if I am wrong.
Nevertheless, IlluminationSupply’s service is top-notch. I’m just being picky, really, when I wish that theirs was easy like Ftech, where anyone can just plug in a coupon code directly from the shopping cart…without having to enter information etc.
Unfortunately that is part of the limitations of our particular web store software and of being an authorized dealer. We are not allowed to publicly state the values of our coupon codes if it breaks MAP and causes other retailers to complain to the manufacturer. While we may have the ability to list lower, we do so at the risk of alienating manufacturers and other retailers alike.
It is simply not possible for us to have a price war with Fasttech, nor are we willing to have one. It would be a war of attrition that China would undoubtedly win.
No offense taken cateyes If there is a lower price out there everyone is indeed free to choose another vendor. It’s your hard earned money and though we would like you to buy from us, if you can get a better deal you should. Illumination Supply doesn’t just simply retail common products, but also carries some unique items and hopes the ease of transaction and customer service brings customers to our store. As always, thanks to everyone at BLF for their support.
Apologies, USPS has raised international shipping costs and the price you see is pretty much the price we pay. We don’t really make money of shipping and handling.
We’ve recently just finished the long list of backorders and received a big shipment of these little guys. Because of the huge wait time, we have decided to extend the introductory promotion and offer 15% off. Simply enter discount code “SC52Restock” after choosing your shipping speed.
The Zebralight SC52 is powered by a cool white CREE XM-L with a 280 Lumen output on high off a single AA battery.
Additional Specs:
User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels or strobes.
Light output are ANSI out the front values. Runtime tests are done using Sanyo 2000mAh Eneloop AA batteries. Light output with 14500 batteries are the same except that the H1 is 500Lm for the first minute and then steps down to 280Lm.
Operating Voltage Range: 0.7V - 4.2V
Battery: One 1.5V AA (NiMH, lithium or alkaline) or 3.7V 14500 Li-ion battery. Batteries are not included in the package.
Parasitic Drain: Negligible (equivalent to 16 years, much less than the self discharging of a battery)
Beam Type
80 degree spill
12 degree hot spot
Dimensions
Diameter: 0.93 inch (23.6 mm)
Length: 3.08 inch (78.2 mm)
Weight: 1.4 oz (40 gram)
Features
Automatic stepping down when battery (AA and 14500) capacity is low
Built in over-discharging protection for 14500 batteries (2.8V cutoff)
Electronic soft-touch switch, with a 200,000 cycle operating life
Smart user interface provides fast and easy access to all brightness levels
Precision machined unibody casing from premium grade Alcoa aluminum bar stocks
Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing
Durable natural hard anodized finish (Type III Class I)
Tempered optical grade glass
Preinstalled bezel down pocket clip
Orange peel textured reflector
Anti-roll and tail-standing capable
Battery power can be locked out by slightly unscrewing the tailcap to prevent unwanted activations or parasitic drain
Yes we are going to be stocking them. Zebralight estimates a shipping date of March 22 but I wouldn’t hold my breath based on the SC52 shipping speeds.
Illumination Supply advocates responsible flashlight shopping. Please do not forgo basic necessities to buy our products. If need be please contact Flashoholics Anonymous for help. :bigsmile:
