How easy was it to replace the lens on the BTU? Also, if it’s not too much of a hassle, since the lenses are too short, can you give us the exact diameter and thickness of the lens you recommend? I’m thinking about ordering a custom AR acrylic lens.
Thanks!
EDIT: I got the lens measurements form_the_’s exhaustive review:
Lens diameter: 94mm
Lens thickness: 3mm
How much wider would you suggest the lens be (96mm)? I assume the thickness is correct.
I’d say 96mm would be a good size. The acrylic lens I don’t have any experience with, so I don’t know how well it will compare or hold up to my glass UCL lens. But if the will get you one for a reasonable price, its would be a reasonable choice to try.
I personally have no issue buying from Ric again. The BTU is a beast of a light with its only comparable rival being the TK75 when power, throw, price, quality, and flood are all considered.
And truthfully, the BTU comes closer to matching its advertised specs than 90% of the Chinese seller lights on the market.
That’s the way I look at it.
But Shaquille’s money, is his money, so if he’s not satisfied with the sale Ric made to him, I guess that his choice. I can understand that.
But I personally think I bought an awesome light for money from Ric.
If Shaquille is referring to the missing AR coated lens, he is correct. The product page does state AR lens, but it does not come with one.
Other than that, the product page matches the product better than almost every other light available from China.
yes the AR lens + 800 meters throw + the sudden price drop . not sure if mine really had U2 emmiters in the first place ! cos now after upgrading to u3 the difference is so much that i suspect these were t6 emmiters. The only reason im satisfied now is due to my own upgrades.Once i add the sr 90 lens then itl be worth $180 .RIc has dozens of company available in china where he could have ordered nice ar coated lens in china for few bucks. why mislead us? .
I can be too picky at times i do admit but whenever you see smoke coming from my behind then someone started a fire there
It’s super easy to change the lens on the BTU. The reflector is held on via the led heatsink/plate. So keeping the lens pointed down, simply unscrew the bezel, once off set the light to the side tailcap up to keep dust out of the reflector. Remove the old lens out of the bezel. Carefully set the new lens in place in the bezel. Set the light on the bezel, pick the assembly up and slowly screw the bezel back in place until snug. Done.
I would say yes… But when tried to get one from Fenix they told me to kick rocks. Wanted me to send in my TK70 for repairs. When I explained to them what I was doing they told me they dont sell them seperately.
