I've been kind of out of the game, but it's obvious that there's been a wave of reflow fever here on BLF and I'm about to catch it. But then again, with everyone doing it, maybe I should just wait until people start selling LED's already on a copper :) Great ideas you guys are having though!
There's been NightCrawl's but also 1 or 2 other variations posted. I was thinking more of a direct connect through an existing pill top down into a copper heat sink inside the pill, or even just a couple of copper discs. So basically you could adapt it to any existing pill pretty easily - though I'm not saying it would be easy...
The other posted variations were more involved with cutting out a rectangle in the star to match the full pad, but it would be a lot easier just doing a simple hole to match a copper rod's thinkness. I'm just not sure about the reflow when you have that copper rod prutruding well below the star - my frying pan reflow method won't quite cut it. What Matt is proposing is simpler in a way, but you don't get a direct bond down to a heat sink.
The only thing I'm curious about is what we are un-doing by having a direct thermal connection, including the SinkPAD's -- there's no electrical isolation, those substrate layers in the original PCMCB's are there to electrically isolate the thermal pad of the emitter from the host's ground, actually battery negative I believe. Has there been any discussions here about that?
No, not yet. I'm an all or nothing dude. ;)
But I will do it with XML and XRE once my order from LCK-LED arrives. I'll post pictures on that. :)
Dont have an XPG light that would need this kind of treatment.. but I might do it anyways if I'm really bored and find a spare PCB. ;)
@Tom E: It actually sounds really easy. If the pill is brass or aluminium, it even is easy. Copper is hard to work with, even if you "simply" want to drill a 1cm deep hole with a 1.2mm drill..
Your point about reflowing with a large copper pill is indeed something to consider. But on the other hand, it doesnt have to be complicated at all. If you put it all together and heat up the whole pill (will work in your pan) you can reflow the LED. If you want to fill the pill with copper pieces and solder afterwards, that should also work if you take a little care not to heat it all too much. Trial and error. :D
I think matts idea would work just as well. See this graph here:
Testing performed by German TLF member Basti. It shows that the material after the star is relatively irrelevant. Of course copper performs best, but the difference is negligible.
On what we are "un-doing".. there have been discussions about that. For most LEDs, there is no negative effect because the center heat pad is electrically neutral, except for some weird LEDs.
Regular PCBs are built the way they are built because its the cheapest way. And you need some of the layers on aluminium PCBs because its not easy to solder to aluminium. Another thing I want to try.. reflow an LED directly to aluminium.. a lot of work to do. :D
Sort of off topic, but my mod'ed ZY-T08 w/XM-L2 U2 SinkPAD, Nanjg @4.2A lost a 7135 somehow - maybe it never worked day one I'm think'n. Anyway, added another 7135, with the 2 Pana PD batts, measured 4.27A, and measured output: lumens - 1,395 @start, 1,366 @30 secs, throw: 100 kcd (broke the 100k barrier). Those Panasonic PD's from FT are outstanding for single cell XM-L2/SinkPAD's. A little better are the Samsung INR's - only got 2 from FT dirt cheap (pulled from a battery pack) @ 1500 mah. Ordered 3 more Samsung INR's at higher capacity off of eBay, and think I'll order more Pana PD's from FT -- excellent in the 7G9 and T08, plus my single cell mod'ed XinTD, UF C8, and UF-V3. The 7G9 did 125 kcd w/the 2 Samsung INR's and 1 Pana PD -- best #'s ever. The AW IMR does well but these batteries beat it.
I've done this, best way I found is to put a chamfer/bevel on the top & bottom of the hole you drill thru the MCPCB. Then cut the copper rod (14ga copper solid core house wiring works great... it's .064/.065" OD EDIT: BRAIN FART - .080") so it sticks out about 1/16 above each side, then squeeze it with vise grips so that it expands into the hole, and fills in the top/bottom chamfers, like a ye-olde-timey hot rivet. Trimming the ends down flush with hand files is A REAL PAIN, small drill press with end mills and a depth limiter would make it a breeze.
On MCPCBs with the center pad connected to bigger areas outside the LED footprint you can add the copper pins all over the board, as it's all the same copper top layer. Depends on how much free time you have.
that’s good info comfychair, thanks for the feedback. I especially like the tip about squeezing the wire to make sure it fits, although I was hoping to find something that I could press in with an interference fit for the best heat transfer. My plan was to push it through with a vise so that the LED end was flush with the star, then trim it off the other end with a dremel.
I just got some parts from a friend to build a milling attachment for my ancient mini lathe, so hopefully I’ll be able to use that to do a more “pro” job
Ha, I was looking for this thread to make a correction in that post when the notification email popped up, I got the wire size wrong. xD
Try this: cut the copper pegs to length so you have around 1/16" sticking out both sides. Insert ALL the pegs, then file the tops flat while they're still clear of the solder pad, then push then down flush from the top, then do the squeeze/rivet expanding thing. MUCH less filing needed on the topside this way. Trimming the backside is no problem as it's got to be sanded flat anyway after all that abuse.
Oh, and doing it rivet-style is what gives you good contact, even with the initial clearance loose enough that it's easy to assemble. When squeezed the copper rivet gets shorter in the direction you squeeze it, and expands radially to create an interference fit in the hole I.D. The chamfer on top/bottom really isn't needed as the fit will be tight enough as-is, but what it does do is increase the surface area of the copper in the two spots where its needed most.
really sweet comfychair and thanks for the correction, I’ll definitely be giving this a go. I need to head to Home Depot this weekend for some other stuff, so I’ll pick some wire up while I’m there. What size drill bit do you use? I’m not very good with Imperial/ fractions
great looking star by the way, looks very pro!
Drill is .079", 14ga copper wire is about .080". It's what I would call a 'light press fit', meaning you may need pliers, but only if you're afraid you might chip a thumbnail. Even if it's sloppy, if you have the copper peg long enough it will expand enough to fill it in. I just use 6" vise grips (with the jaws filed smooth, no nasty knurly grippers), squeeze a little, tighten the adjuster a bit, squeeze again, tighten adjustment, etc.
Cut up a bunch of little 1/8" long pieces of copper wire and squash 'em by themselves, get a feel for how much they will expand (quite a bit). Then practice doing rivets on some plain aluminum sheet, once you get it figured out you'll be able to feel when it's no longer squashing and has filled in the hole.
Oh and for the countersink/chamfer I use a Dremel round ball carbide burr, .100" dia. Turning it by hand, not in the Dremel! It's basically not doing much more than breaking the sharp edges around the holes.
Very clever. Great idea and thank you for the picture too.
I guess you could also extend this through the pill and chamfer the back of the pill instead of the MCPCB. Then press them as unit. Reflow the MCPCB to the pill first. This combines Nightcrawl’s and Comfychair’s great ideas.
EDIT: Sorry, just noticed the OP said the above already.
EDIT2: Well, kind of. Press into pill, not press together. Sorry, again guys. I am multitasking to much stuff at the moment.
thanks comfychair, I’ll check to see if I have a 5/64in drill at home (I do miss metric!). I’ll have to have a think about how to do the pressing in as my vise grips are large’n’nasty (mostly used on the car), so I may do better to rig something up to use in the vise instead.
I was thinking something similar and you wouldn’t have to worry so much about getting the “rivet” on the back of the pill as flush. You’d have to be very precise with the drilling so that the LED was centred properly, but this and a thin layer of thermal great under the star would make a fantastic thermal joint. Then all you’d have to do is reflow the LED to the star once it was all together. I may try this with the C20 host I have coming, although my drilling is notoriously crap (no drill press).
Matt, wouldn't you just use your lathe to drill the hole? Unless its a multi-emitter you're going for.
Cool, please take pics if you do. I hear you on the drilling skills. I have a cheap HF press that I’m not sure will do much better.
I
Drill for screw holes to use just while setting it up... tighten the screws just enough so that the board won't slip on its own, but loose enough that the reflector can shift it into alignment. Remove, tighten screws, recheck alignment, then go to town drilling the rivet holes. Done! Well, you know what I mean...
Well, thats a different approach. My method is more suitable if you use a massive copper heatsink than for regular flashlights where you screw/glue the star down.
I would, but I can’t fit a drill chuck to my tail stock I’m pretty sure drill chucks were invented by the time my lathe was made (if only just), but it has a non-standard tail stock. Can’t even fit a live center either. However, as soon as I make my milling attachment I should be able to do it the other way round, sort of like making it into a drill press.
will do! I’ll practice on some spare stars first though
that makes perfect sense, although I may not have space for screws, unless perhaps I can tap the wire holes and use those? Would something like a very viscous grease (axle grease?) beneath the star to a similar job in centering the star, then I can use small C-clamps to hold it in place while drilling?
what I like about this “rivet through star and pill” idea is that not only will it provide an awesome thermal path but it will provide an excellent mechanical connection too, without having to go through the hassle of using screws. I’d even consider doing this for my bike lights, but I can’t see how I can heat up ~50g of finned aluminium housing enough to reflow the LED
