$2 DIY bench power supply for testing emitter and powering a hobby charger.
Also, you can easily get voltages that aren't officially supplied by the PSU. For example using the +12v as positive and +5v as negative will give you the difference between them, in that case 7 volts.
Nice work! I like the enclosure!
If you need a bigger power supply with way more amps you can also convert a server power supply.
How many amps would you need to properly annodize a 2C mag? My power supply can deliver up to 150amps at 13.8v, would that be enough?
Pretty cool, JM !!!
Those supplies should NOT be used with anything expensive and valuable, such as expensive hobby chargers.
See this review of one of them to see why: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=324
I’m not going to quote the full review here, but this picture of ripple on 12V rail should be enough:
That’s at 300W btw… Here’s for comparison Corsair AX1200i at 1200W:
Your link and your pics are no good. 404 error.
If they are no good for use with expensive electronics then there are a whole lot of computers (lots of expensive components in there) costing hundreds and thousands of dollars at risk that use them. Someone had better tell Apple, Dell, HP, Compaq, Asus, Gateway, Toshiba, etc...
I completed the wiring over the weekend and fired it up last night. Works a treat! Whisper quiet and puts out voltage in my choice of 24v/12v/7v/5v/3.3v
Fired up the new IMAX B8+ and it works great. Looking forward to going through my cells and running discharge tests to filter out the older bad ones from laptop pulls and to get some good matched sets. :)
Is the 3.3v output close enough for driving a single emitter? Say testing with a single Li-Ion max 4.5v driver. If not, would you use the 5v output with a resistor or something?
-Garry
I think there's enough wiggle room in the specs for a '4.5v' driver to run fine on 5v. I haven't found one yet that isn't happy running even from 2xCR123As.
Considering the forward voltage of an XM-L is around 3.3v I’d say it should be plenty to drive an LED directly. To run through a driver it should still work but not at full potential. An Nanjg powered by it won’t be regulated at full power but will still light up if you just want to make sure it is wired correctly.
You could add a variable output fairly easy. I have a handful of modules, I could mail you one or two and point you in the right direction to modify it. Add a voltage and ammeter, and you could be good to go
Thats danged nice!!! It's guys like you that make the world go around!! Doing projects like that are nothing less than great!!!
Congrats on the thought and the follow through!!! NICE! Dan.
Now I could go for something like that! At least a way to vary voltage with a voltmeter built in!
Also, I'm pretty sure I have one of these power supplies that I bought years ago (+/- 1995) for bench testing 12v car stereos. Maybe only used once or twice.
-Garry
Intriguing…can you PM me some info on the module and what all would be needed?
Looks like you already have what you’d need to run a hobby charger and whatever else. You even have 4.5v for runing a driver & LED at full power. :wink:
Thanks, TL! Coming from you that’s quite a compliment. :slight_smile:
They are the kis-3r33s module. You’d need a couple of capacitors and a pot. Pretty sure there is also info online on using a resistor for set voltage output. I think they have something like a 5-24v input
Been a while since I played with them, so I’m not exactly sure on the specs.
I expected a Hobby Charger would need a power supply capable of putting out more than 2A (I haven't looked that closely). How much current is your charger rated for? I did wonder if your PC PSU bench power supply might be a little redundant for me since I have this. Yes yours would put out more current, but would I need it? Plus the whole idea of building one is just so cool! (I have tons of PC power supplies.)
-Garry
Something I've done before, which is probably one of things no one should attempt ever, is wiring two PSUs in series to get 24v. Use the +12v pos from PSU #1 as the ground reference for PSU #2, you'll get 24V using PSU #1s negative and PSU #2s positive.
The cigar box really makes coooool
