That’s the low battery protection thing kicking in on the drivers; you’ll get the same thing if you suddenly impact the light (Not that I’m recommending this) or switch modes too fast in some cases.
It should enter this mode automatically when the battery is low (Step down from high/medium, but maybe not from low) however I wouldn’t rely on it.
I get similar on the light I modded. Because my modded light isn’t exactly perfect the battery can move and if I shake the light while it’s on the battery looses contact with the driver for a moment and then low voltage kicks in. So basically by doing what you’re doing you’re simulating low battery voltage.
One of mine had a faulty switch and would go into low-voltage mode entirely on its own. When changing modes, it was pretty much random if it would rotate by 0, 1, or 2 modes or go into low-voltage or just give a dim flicker. But I contacted Intl-Outdoor about it and they sent me a free replacement switch. Works great now.
I had a couple of DIY Hosts that gave me the same behaviour, in the end it was due twice to bad grounding of the pill to the driver, and once bad grounding of the switch.
Need to get the S3.
The emitter and tint choices are a bit confusing.
If I want the S3 with the floodiest beam w neutral tint, which configuration should I choose?
( T5-5C?)
My Convoy S3 just arrived with a faulty tailcap, take 10 clicks to turn on. I have metered it and confirmed the cap is faulty. I would like to get a new cap rather than return this half way around the world for refund/repair. Can you tell me which ones will fit? Cheers
It's likely just the tailcap switch inside the tailcap that needs fixed. Have you removed the retaining ring to get the switch out to see what's wrong (perhaps a bad solder joint)? I can't help you locate a switch, but at least you can stop pursuing an entire tailcap (which you likely won't find).
One of my S3 units had a faulty switch. Intl-Outdoor sent me a new switch for free, since that’s where I got the S3 from, but it took a while.
You might have better luck simply re-melting the solder in your switch, since that can often solve this type of issue. However, I-O and some other stores sell extra switches if you’d prefer to just buy a part.
No, getting hot quickly is a good thing. It means the heat is getting transferred out to the air like you want. If it didn't get hot it would mean the heat is trapped at/near the emitter and could potentially overheat and/or damage the emitter.
Your Zebralight has a temperature sensor and dials down the power to keep it under 60Celcius. Your convoy doesn’t have this feature and let’s the heat rise until you decide to turn it down. Your convoy will naturally get hotter than the ZL after a few minutes. .
There is also a caveat to that too…getting hot fast means it’s pumping out ALOT of heat…if there isn’t enough surface area or thermal mass to the light…the heat has nowhere to go fast enough and only heats up the entire unit
This is why lower modes is a good thing…if it’s getting too hot too fast, throttle it back and allow the heat to distribute and convect away…then if you want you can bump up higher for a little bit…this is why I like the STAR firmwares auto throttle function
Do protected 3400 cells (e.g. the ones from Fasttech) fit into the Convoy S2? After reading all posts regarding this, some refer to the S2, others to the S3…
Last I heard, the S3 can take protected cells but the S2 can’t. I don’t know about the newer S2+ though.
Most of the Convoy S line only takes unprotected cells, and usually only cells without any additional wrappers or button tops. It’s fine though, as long as you use firmware with decent low-voltage protection (which all pre-assembled Convoy lights should have).
I used to buy only protected cells, but now I prefer unprotected unless I’m using them in a serial configuration… and I try to avoid serial configs.
Not in mine, even samsung laptop pulls end up with dents in the top if im not careful.
Personally I would be worried about shorting a protected cell or damaging the cell protection circuit
