but expecting an 18W light to perform like a 30+W light seems a little unrealistic.
runtime, a much lower low, infinite variability and much brighter spill. imo, a much more useful flashlight, for purposes other than “click on wow, look at that click off”
ok, before i get flamed, I’m sure a tk75 is plenty useful 0:)
Okay good thoughts here. I too thought it would make a good workhorse/powerhouse but what about it’s uses besides infinite variable light to say the terminator in a lower setting (power issues resolved) or a TM26 in the same lower setting? Would it still have a better beam? Probably. Would it run longer? Maybe. Would it be smaller? Definitely not. Would it have that wow moment, at least as much of one as the other two lights? Again, probably not. So it might fill in a gap for those who don’t need a super small size, a mighty thrower, and aren’t into the ultra high lumen race, but do want a powerful flashlight with a nice beam and good run time. Seems better and better the more I talk about it now actually. Instant bright would be a good feature as well as someone else pointed out.
I mostly agree - I think it just comes down to beam profile, and which you prefer. It is tough to get an idea of the MTG2 beam from just beamshots, at least imo, so I think it will eventually become relatively popular, but slowly, as more and more people see it in person…
edit: looking at the photos again, I’m not diggin the look of the switch, or the branding around it. but I think I’d get a lot of use out of the light.
This will be an interesting light to follow. Considering I already own almost the whole crelant lineup, I'll probably order this one when it comes out. The SST50 really underwhelmed me. The SST90 was interesting, but failed to "wow". Haven't seen an SBT or MTG2 yet.
If this light follows the pattern of all the other recent Crelants, it will likely have the same exact UI, except for the absence of the tailcap switch.
Personally, while I like the present Crelant UI, I think there is work left to be done...
-From the secondary switch, you can't turn off the light instantly... have to click twice.
-No memory after main switch is used.
-Very easy to depress button. I had by 7G3CS turn on in my pocket a couple of times after forgetting to turn off via tailcap switch.
All of these are fixable issues. At the very least I don't understand why they don't make a depression for the button, so you can't turn it on by accident.
It is good to finally see some MTG-2s ending up in lights though. I too own the whole crelant line and enjoy them very much. The finish on my 7g5cs is the best out of any of my lights.
The 7G5CS. I own three of them... and want to get a fourth. It's a solid light, with a unique UI. With the aspheric it's also a showstopper... http://laserpointerforums.com/f66/flashlight-beamshots-collection-81167.html
The 7G2CS is the most practical. The 7G3CS is my EDC on a fairly regular basis (this will likely change after the new zebralight 18650 light comes out).
The V9CS is nice, but I would opt for the 7G6CS as the best all around crelant right now.
The V11, v21, and v31, I would stay away from... not bad lights, but not great either. I only kept the v11, sold the other two.
I don't own the 7G9 (UI was unacceptable to me) and don't see the point in getting the V6CS - except maybe for price.
Actually my sincere hope, after seeing this thread, is that they drop this new LED into the 7G5CS format.
Your thread is what got me thinking about the possibility. Hard to tell from the photos, but it looks like the beam is nowhere near as narrow because of the LED size. Did you experiment at all with moving the aspheric closer or further?
Nice to see a flashlight equipped with an MTG2 finally making it to market. The current is slightly less than my MTG2 Torchlite, but this Crelant has a larger reflector. I do like the side switch, but would have preferred it flush mounted, but having a hidden strobe/SOS makes up for it. I also wish they hadn’t used a battery carrier, but from the photos, it does appear very heavy duty.
If the price is reasonable, I’ll have to decide if 1,800+ lumens will be enough for me. Considering most of my lights are about 2200-6000 lumens, I doubt this Crelant will de-thrown my Skyray King, which is a more compact powerhouse of a light.
I’ll keep an eye on this thread and wait for more details.
OP reflector, interesting... 550 meters? Dunno - Crelant streched those numbers before. Agree it's good to see an MT-G2 on the market, glad it's from Crelant. The UI is interesting, been waiting for a 7G9 upgrade like this but the 7G10 is a different animal.
