Got the same problem with the 3 mode 4A driver, could only get slightly over 3A out of it.
The sinkpad and higher forward voltage on the XM-L2 certainly doesn’t help but it seems to be a pretty high voltage drop in the driver as well :~
I have the 4A version in a light. (the one with ramping. Comes from IOS, not FT). I am getting more like 3A. 2,8 on a slighly used cell (Panasonic or Sanyo)
Today I just got the protected NCR18650PD from IOS. Pretty fresh of the charger I am getting 3,75A on the tail running one XM-L. Not sure how soon it falls down. Based on first impression it seem to be a much better match with the driver circuit than with the “regular” high quality protected cells.
I also have the 5A version too (3 mode from IOS)… Still not finished the light that I am going to put it in. But Ill report back some place on this forum.
Plan to use it with 5 XP-G and one 32600 battery. Should be no issues with high vf on the LEDs or the amount of juice from the battery. So time will tell.
I have seen others report lower values on these drivers too. I suspect that in a bench test with perfectly constant and high input current they may deliver as rated, but in real life they seem to perform lower to considerably lower than expected.
As Garry mentioned. VF to XM-L2, or VF in general when going for 3,5A to a single emitter is an issue that is in many cases not driver related. But in the case of these drivers, they seem to under perform in general when it comes to real life use in flashlights.
I got these drivers in 4A and 5A on order. You "must" use low resistance batteries on a XM-L2 single cell build w straight amp regulated drivers with driving high current (over 3A). I've gotten 4.2A measured on 4.2A Nanjg drivers. Also, you have to use heavy gauge wire (~22) and check your springs. The first 15 mins or so of use on a battery is excellent output and amps. The KK ICR's and MNKE IMR's do pretty well.
RaceR86's results above is a good sign for the 4A driver - 3.75A measured on a fresh Pana PD. These type of drivers never seem to deliver the full amps as spec'ed, same for the drivers from IOS. I'd expect 3.7A from a 4A driver, and 4.5A from a 5A driver, but 2.6A is bad, really bad. Not sure what a high drain Pana battery is exactly, plus you need heavy gauge leads on your DMM - you are getting into ranges where all resistance is the enemy, you need slim to none resistance, everywhere.
I found the 4a version from ios gives 3.7a on an xm-l and 3.3a on xm-l2 using a king kong (or a Samsung unprotected/sanyo protected), 2.6a to me suggests either the meter leads aren’t so good or……they sent you the 3a version by mistake (its an easy mistake to make tbf).
Just to show how sensitive the 4A driver is to give out high output. Some more tail cap readings to XM-L on copper. Stock wires on the driver (26 AWG to LED from driver, same size or slightly smaller between the boards).
Protected Panasonic 18650PD 3,75A (freshly charged, from the charger)
Protected Panasonic 18650PD 3,6A (freshly charged, but with several hours to rest)
Protected Panasonic 18650B 3,4A (freshly charged, a few hours to rest)
Protected Sanyo UR18650F 2,6A (freshly charged, a few hours to rest)
The difference is about as expected considering that the PD generally is better, and that the 18650B has less voltage sag in the beginning compared to the Sanyo battery. Cant comment yet on the PD, but as said, the others batteries will go below 3A fairly soon (Sanyo already are from the start). I have both green (FT) and black (IOS) 18650B, and they were pretty much equal.
I assume mine and Gords driver are the same. Our high measurements are pretty equal. (Same dealer, same specs, too)
Larger batteries with low resistance and minimal voltage sag probably have a decent advantage when they are used for some time. Or batteries in parallel.
Gords, how does your behave with the larger batteries when voltage are lower? More like 50-70%?
Due to the output being so low, and not well regulated, that might be the reason IOS seem to have stopped to sell them? They started to disappear slowly not too long ago, now I cant find them anymore…
If you have a boost driver on 1 cell, do you think that cell can really deliver 5A except for a very short time? The driver would have to pull more than 5A to feed the set output voltage and then take some more current for that regulation, you end up pulling more than 5A, cell struggles since it it will rapidly deplete and voltage sag would be great, resistance becomes great since it's such a high current on such small voltage.
I have the 5A version and the only way I can get 4.7A on an XM-L2 is with a power supply set to 4.2V. I used 20ga emitter wire and braid on the driver and tail spring. I get about 4.2A on a TF flame 26650. Using 20 ga wire between the boards will probably help.
For me, I’m going back to the East-092 DD driver. I get 5.5A from that J)
I did a 14*7135 driver and got 4900mA with the DMM in series with the standard Nanjg leads with a UR18650GM at 4.15V (offload measured). I think that driver is simply bad, too much drop in the circuit.
The silicone has advantages for flexibility, but been finding this stuff harder to solder - dunno if it's this particular wire or what, that's why I got the IOS wire on order. The teflon coated, silver tinned solders up real well, but turns stiff, sometimes good, sometimes a problem.
