Does the solder wick on the tailsprings make much difference? And is the difference only applicable to high current draw type situations, or could most lights benefit?
Just got a 170 lumens bump on a HD 2010 by wiring in that solder wick. There's factors though, I soldered the spring down better than what it was before, so maybe a difference on that alone? Maybe you could replace the stock spring with a better qual spring? But how do you really know a spring is high qual and better than the stock springs? What the seller says? The higher cost? Can you get an exact size replacement? So, probably easier to just wire the spring.
Also, on my original mod'ed HD2010, I noticed I could no longer get the high lumens, high throw #'s I used to get. Then yesterday, decided to take apart the tailcap to see what I did there as a reference - and there it was! The solder wick gave way and was all cramed up on the top of the spring! Mystery solved! That was before I did the solder wick in a better way. Early, I ran it outside the spring -- now I put it inside the spring. Also, to get rid of the solder flux in the wick, I am soaking it first in acetone -- this keeps the solder from running up/down the solder wick that sitffens it up.
get a convoy l2 and put an xp-g2 in there, its an instant step up on most xm-l throwers, I’m still waiting to get some xp-g sinkpads but I suspect that the xp-g2 will soon become the top dog for throwers, for example, check what the deft x is using.
If you follow toms examples for cutting circuit resistance to a minimum as they will help any light, stock or modded, sinkpad your xp-g2 and just take care mounting everything I highly doubt an xm-l/l2 will come close in throw.
My l2 build is very agricultural compared to toms work but the host is probably the best budget thrower platform you can lay your hands on, I’ve also read about a high amperage driver in the pipeline for exactly that host as the driver cavity is its only weakness.
I’ve found an a8 clone on ebay, tube screws straight into the defiant head and its about half the price of an a8, colours god awful but I bought it to mod for use in my work tools, as it takes a 17mm and 20mm star, that at least will be easy enough.
At about a hundred dollars the K40 is a quality light with no need to mod. Not quite 70 but not 150 either. I think it can take the slot directly before the BTU. There are crelant models at about 70k stock as well for a little less that can take up a slot before the K40.
it did indeed, not the usual cut down piece of conduit either, its one of the best budget ebay lights I’ve bought, once I get some qlite drivers I’ll be building it up and putting it to work.
Now we’re getting somewhere! Several of the suggestions look like they have promise. It looks like there aren’t many off the shelf choices. I checked out the Crelant 7g9, the small sun zy-t08 w/mods, and the t13 w/mods. I have to be honest I love the Convoy L2. I’m thinking of getting the host edition.
My first and only mod was with the Keygos M10. I mimicked gords mod with the same driver with lots of groups and U3 led. It was pretty simple. It’s much brighter than the stock one. Yes I bought 2 M10’s just so I could compare. On my fluke its running 4.2 amps at the tail.
So what does the group think of this:
*Convoy L2 Host, same driver as the keygos M10 mod, dedomed U3.
It’s either that or go with the East driver like in my direct drive HD2010. Not sure how good that is with the 2 battery config of the L2. I’ll attempt to gas dedome for the first time. I’m such a nerd.
Depending on the quality of the batteries, using the East driver could smoke your LED. Don’t be afraid of gas dedoming. It’s very simple. Toss the led in gasoline one night and remove it the next. You might want to give the glass a few swirls or spray the led when your done to get the loose bits off. Tom E started a good thread on dedoming here.
