>>>>>Can I see a picture of the battery case?
I stupidly ripped it apart before looking at the label.
When I cracked it and saw the unmistakable green of Samsung 2200s, THEN I looked at the label:
um08b72 4400 mah.
So look at your label before cracking the case open.
I suppose i could try and argue with the guy, but if I was him I wouldn’t take a pack back in a bucnh of little white plastic pieces. Mine was NOT easy to open. Built like a plastic tank.
It’s only money. I’ll check the label next time.
ALTHOUGH, I have cracked mucho packs at this point and the labels are not all that accurate. I probably would have cracked the case even if I saw the 4400 on the label. I have opened quite a few packs that had a higher mah than advertised mah li-ion battery inside. Never lower, but sometimes higher. So the labels are an indicator of what you MIGHT get, but they’re not always accurate. Same goes for country of origin on the cells. I have opened quite a few that said Japanese cells but were samsungs or LGs. Maybe 10% if I had to guess.
Good luck and check the label.
Betcha everyone gets 2900s except for me. Story of my life. I knew my weekend lucky streak wouldn’t hold!
