Are you saying the couple cells you tested had dropped to 4.10?
Thank you wiljen. I just bought one of those batteries.
No, no ,no …. I’m just saying in general. That’s one of my main ways of judging whether to keep a battery or chuck it. I haven’t had these long enough to see how they’ll do. Talking more about pack pulls. These 2900s are new (supposedly) and should be fine.
A couple did drop to 4.16 over the first couple days, but that was on the first charge.
Except for protected cells to use in my very few multi-cell lights, I use almost exclusively pack pulls. Although since I am a battery nut (hoarder might be a better description), I do buy a few of the more interesting cells to see how they do.
But I didn’t have enough batteries that were exactly positively the same to judge light intensity between lights simultaneously. So I got three of the 2900-mah packs for that end, but that’s really unusual. I find so many GREAT batteries in used packs, it kills me to pay for ’em.
There is this home depot in a town close to Death valley, and it’s like people buy NEW computer packs and throw them in the recycling bin there. It’s like Christmas every two weeks when I go there to town to do my food shopping (180 miles round trip). The guys at that home depot are so totally nice that they open up the recycle bin so I can look better. Last time I had three guys helping me dig through the mountain of dead duracells to find the good stuff. Best home depot i ever went to.
I ordered the item in the original post and it arrived yesterday. Cells were at about 1.78V. Charging one up now. My cells also have 9511 code.
I opened up another pack and had 4 cells at 1.91 and 2 at 1.72. I checked again in the morning and the 2 1.72 bounced up to 1.84. I probably won’t get around to charging them till this weekend.
Thanks for the clarification Ubehebe. Sounds like a good approach. Good job on building repore with your HD recycle bin folks.
Yea them HD guys can be pretty cool sometimes. Must get good benefits.
Just got in my 2 packs, already got one apart and it had the 2900s. :D They are all charging up now.
Well done scaru, now you have even more redundant cells
Seriously though, nice score.
Mine came in. Cells are all marked 9511 (same batch reported in others). All were 1.78-1.80 Volts on arrival. Charged all at .5C to 4.2v to start them off easily. Ran one on the CBA this evening and discharging at 2A gave a total capacity of 2917 mAh. I’ll run a few more on the CBA after a few cycles but they look to be perfectly good cells on first test.
Thank you for reporting wiljen. I don’t have discharge testing equipment. So that information is appreciated. My cells have been taking the correct amount of time to charge about 3 amps and have been taking and holding full charges.
Quick question, seen this pack listed at 7200mah http://www.ebay.com/itm/11-1V-7200mAh-Battery-For-Acer-TM07B41-/261127278644?pt=LH_DefaultDomain_0&hash=item3ccc661034
Does that mean that it has 12 cells at 1800mah? since there is no such thing as 3600mah batteries? I would think that would be good deal either way for $19
And has anyone seen the any more of the 2900mah packs???
What I know about batteries those batts with the voltage that low cant be right…
You can check this packs, are new and working, I think that is a good option;
http://www.ebay.com/itm/400478669912?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
http://www.ebay.com/itm/400478669310?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
Just a guess but I think its 9 cells, 3s3p pack. That would mean it contains a 2400mah. Maybe these http://www.fasttech.com/product/1210702-as-is-sanyo-18650-2400mah-36v-rechargeable-lithium.
Just a guess.
Those have very low mah
Yea i think you’re right since the pack looked like 3x3 configuration anyway.
Just a guess.
Interesting. So is the mAh derived from the single battery mAh multiplied by how many are in series, or by how many banks are formed? 9 cells, but divided into 3 per bank means 7200/3=2400. It would seem to work the same way for voltage… as 3.7v x 3 = 11.1v.
I’ve seen some Asus Eee PC cells showing 7.2v or 7.4v and 5800mAh. That means it has to be two banks of batteries in series, but the casing looks very fat like there are 3 rows of cells. Maybe there are 8 cells total, divided into 2 banks of 4 cells?
Correct. Cell capacity (mah) is multiples by the number of parallel banks. Voltage is cell nominal voltage times number of cells in series. The the second battery you mentioned is most likely 2s2p (3.7v*2=7.4v, 2900mah*2=5800mah). Maybe it looked fat because the cells are arranged sideways?
got 2 Acer battery packs… they all 2900 CGR panys (?) all of them 1.90V, try to charge them on Nitecore smartcharger… but after few seconds the lights stay ON… it won’t charge
@Daylighter, so the I4 refuses to charge yours? Maybe take them out and put them back in? If that doesn't work I have a few more ideas.
I’ve seen that happen with the I4 on a few I had. Try putting them in another charger like a wf-139 first and get them up over 2.4 then the i4 will work. For whatever reason if the voltage is below that the i4 refuses to charge them.
