Me too, I’m seeing spots when I blink, I didn’t think holding it down in low mode would cycle to a mode that bright! Whops
I’ll do some “don’t wake the girlfriend bathroom walks” tonight with my SC600 MKII and see if it passes her “has to put electrical tape over the alarm clock display because it wakes her up when the numbers change” test
The SC52 and SC600 Mk II have programmable M2 and L2 (previous models only had programmable H2). Set the light to low (either L1 or L2) and perform 6 double-clicks (12 clicks total). That will put you into programming mode for L2. Double-click to cycle through the available L2 levels. You should be able to get ridiculously low; maybe not quite as low as SC52, but it should be close. Turn the light off to finish programming L2.
Is the default H2 the brightest? Or can you program the H2 to be brighter than the out-of-box H2? Obviously from my questions, I’m more interested in the high than I am in the low-low :)…
LICK FOR HIGH RES! (camera make them look brighter than they are, the MKII is super dim, to the human eye looks just slightly brighter than ohaya’s SC52 pic above).
Amazing!!! Loving the MKII now!!! They just need it in a high CRI or at least warm version and I’m done
On the SC52, there are three low sub-levels. Low, and three other super low to select from.
Personally I find the lowest one to be just too low. The second lowest one, is fun... I just leave the SC52 on like that all the time. Not like it will discharge the battery in under a month.
If the modes on the SC600 MkII are the same, this will be an absolute incredible light, and chances are it will run for months on end, if needed.
How is the strobe? On the SC52, I really would have preferred they drop the medium modes, and get a decent strobe/sos/beacon modes in.
I call it super retarded burnt out firefly mode now
Here is the best pic I could take with my camera. The SC600w looks just a hair brighter in this pic than it does in real life, but the MKII is spot on. This was taken with a calibrated white balance and high CRI source for the background lighting, not sure if you can make out the tint difference between the two
The silver ring usually denotes the three mode version (high, low, strobe, memory but starts in next mode :(). I’ve seen a 5 mode one with a blue ring as well.
I think that the SK68 was originally made by “Sipik”, and all others that make “SK68” are actually “SK68” clones, and that I guess that they can make all kinds of “design” adjustments. For example, I have a silver/gray “Uinfire Sk68” (from FT, and yes, that’s actually the spelling) that looks like a “Fordex” (bought via Amazon). I’ve seen blue ones, green ones, etc., so I guess some manufacturers put that silver band around their version.
Nitecore's first ring-operated flashlight in a long time, the SRT-7 sports the new XM-L2 Emitter, RGB LEDs, and infinite variability from 0-1000 lumens.
SRT7 – Revenger , Designed in 40 mm big head style, as well as high output and long throw. Adopted the Generation III magnet ring technology and built-in RGB 3 color outputs, integrating law enforcement warning Signal, strobe, and beacon functions, it is the unique product in the market which is especially suitable for professional users like the military, law enforcement, hunters and flashaholics as well.
Power source: 1 x 18650 battery or 2 x CR123
LED: Cree ML-L U2
Update! The Revenger SRT7 comes with the brand new
Cree XM-L L2, and achieve the 1000 ANSI lumens !
measurements :
Head diameter 40 mm
Body 25.4 mm
length 158 mm
Weight 173 grams
Activated, the lamp is on one end cap, the selection of the light is achieved using the rotary ring on the lamp head.
There are also built three other LED that can emit red, green, and blue light !
The rotary ring on it, the following lighting levels from left to right ( ie, clockwise ) :
Locator Beacons ( short flash as a position light )
Red / blue light ( changing, strobe effect )
blue light
green light
Red light
standby
Turning range of 0.01 to around 1000 lumens, infinitely variable
turbo
strobe
