Due to the size of the reflector vs. the size of the LED, it is destined to be more floody than not. At around 450-500 lumen, it still has some punch as a close- to mid-range light.
The mode programming is as simple as bridging two small contacts with anything conductive: wire glue, pencil graphite, or solder for a more permanent solution.
The Mag64656 is said to put out 14-17,000 Lumens… but it’s huge 7 26650s. To me it’s amazingly bright and puts out enough heat to warm up people 20ft away, but due to the size the wow factor isn’t there. But that said it is awesome. I keep several unmodified Mags just so I remember what normal is. That said the FF3 is the real deal. The soon to be released FF4 will be something like 5mm larger and a larger SMO reflector but also has a low 24w, 40w, and turbo 60w. But when I’m looking for something that’s a bit more practical because of shorter runtimes of the HIDs, I’m a huge fan of the wicked MagMods at LambdaLights. I think I have about 15 or so of those and they all still have that effect you get when you get a light that put you in awe once again.
Do you happen to have an SC52 or SC600 (or MKii)? How does it compare a high? I think that the SC600 MKII is suppose to be “900 lumens”, but at least to me, on high-high, and on 18650, it seems just barely brighter than my SC52 on 14500, even outdoors, at night. I’ve heard otherwise, but I’m wondering if there’s something wrong with my eyes (night vision problems?).
I was just outside, checking out some of my “smaller” lights (ITP A3 “upgrade”, D25A TI clicky, SC52, and my new SC600 MKii), and something occurred to me: It seems like it’s a lot easier for a smaller light to “impress”?
I first tried the ITP. I hadn’t used it at night in awhile, and I was kind of surprised, it pretty well lit up a large part of the area in front of our house (we have about a 250-300 yard open area, line-of-sight, in front - it won’t be long though, cuz they’re building next to us).
Then I tried the D25A, and it was a bit brighter, but a lot more throw than the ITP. The SC52 was brighter yet, but lit up a wider area. Finally, the SC600 was brighter yet, but even flipping between the two highs that it has, the high-high didn’t seem that much brighter than the SC52.
I guess that that goes to show that the SC52 is still a heck of a light :)?
But, it also got me to thinking that as the light gets bigger, and the brights get brighter, it gets harder to impress? In other words, and this is just a theory and some made-up numbers, it seems like going from say, 110 to 300 lumens looks like a huge difference, but going from 500 to 900 doesn’t seem that much?
I’m going to go take out some of my “bigger” (not that big though) lights now…
I have had my D25c clicky for 6 or 8 months now and edc it every day and it still impresses me and everyone else everytime I turn it on with an IMR cell. We did not get the 770 .lumens that Selfbuilt got but did get 650 otf lumens. Unbelievable for a light that size.
for EDC? i don’t think i have seen anything that brighter than lightmalls C8 XM-L2 for under $20 straight out of the box.
hopefully someone can prove me wrong… because i could use brighter light than C8 XM-L2 for under $20
although this M10 clone come very close… it has tighter hotspot for thrower.
modify this and it will surely beat the C8 XM-L2… but it will push over $20 mark :~
No, not for EDC, not necessarily anyway. I generally carry my ITP, but once in awhile the SC52.
I have like 3 C8s already… well one is a C4-MCU or something like that, but it sure looks like a C8, and it takes a C8 pill, and 3 more coming from FT, including a Convoy C8 with the 8*7135. I like the C8s, and also have a couple of the C8 pills from FT, trying to get up the nerve to build one of them, but I’m not sure if I could do better than some of the ones like the Convoy C8 which already has the 8 7135s.
I just received a Eagletac TX25C2 two days ago, and it is a compact little powerhouse for a stock light. I am very impressed. I was taking a walk last night when I realized this little light is putting out more lumens than my K40, TN31mb, etc and is my second brightest light to my sky ray king. The new Zebralight 600 is a little shorter and about 100 lumens less but still should be added to the list I believe.
Yeah man, if you don’t have a SkyRay King (or UV-S5 clone) yet, you need one in your collection. Especially with that many C8s already! SRK definitely wows, so long as you get a good one.
Those are all FastTech parts: I can agree with that as being an impressive light, but for my build, I used a cooler tint emitter and Nanjg 101AK driver which only drives at 1.4A, but is still very impressive in such a small pocket-sized light:
Also the comments say CR123 batteries, but what rechargeables would work with this? Would a 16340 work?
Edit: Also the comments say it’s “thin aluminum”. When I first started, I bought a couple of “Police 3W” lights from Buyincoins, and they were really cheap, thin, aluminum. Almost like toys. Is the WF-501A better quality than that?
