IS Promotions: Rayus C01 / PT10 Series Intro [8/28]
I call it super retarded burnt out firefly mode now :wink:
Here is the best pic I could take with my camera. The SC600w looks just a hair brighter in this pic than it does in real life, but the MKII is spot on. This was taken with a calibrated white balance and high CRI source for the background lighting, not sure if you can make out the tint difference between the two :slight_smile:
LICK FOR: HIGH RES or UBER HIGH RES!!
-Jamie M.
Great pictures!!
How about a photo with the SK68 and SC600 MkII tailstanding next to each other?
Wasn’t there one in post #224?
Oops, missed that, thanks.
What’s the silver ring on the SK68? Mine doesn’t have that, maybe why I missed it
The silver ring usually denotes the three mode version (high, low, strobe, memory but starts in next mode :(). I’ve seen a 5 mode one with a blue ring as well.
LICK FOR HIGH RES!
LICK FOR HIGH RES!
LICK FOR HIGH RES!
-Jamie M.
Hi,
I think that the SK68 was originally made by “Sipik”, and all others that make “SK68” are actually “SK68” clones, and that I guess that they can make all kinds of “design” adjustments. For example, I have a silver/gray “Uinfire Sk68” (from FT, and yes, that’s actually the spelling) that looks like a “Fordex” (bought via Amazon). I’ve seen blue ones, green ones, etc., so I guess some manufacturers put that silver band around their version.
Thanks very much for the photo’s and explanation mate
Nitecore SRT 7 pre-order
Estimated arrival, second week of May.
Nitecore's first ring-operated flashlight in a long time, the SRT-7 sports the new XM-L2 Emitter, RGB LEDs, and infinite variability from 0-1000 lumens.
Maybe I’m totally blind, but nowhere in the description or on the text in the pictures does it say what battery or batteries it takes?
And do you know if the Turbo/960 lumens mode would hold for the full 1hr45mins, or does it step down after a few?
Thanks for all the crazy deals :smiley:
-Jamie M.
Is this in Black or Military Gray? a discount code :stuck_out_tongue:
Here this should help :bigsmile:
Nitecore SRT7 “Revenger “ LED Flashlight
SRT7 – Revenger , Designed in 40 mm big head style, as well as high output and long throw. Adopted the Generation III magnet ring technology and built-in RGB 3 color outputs, integrating law enforcement warning Signal, strobe, and beacon functions, it is the unique product in the market which is especially suitable for professional users like the military, law enforcement, hunters and flashaholics as well.
Power source: 1 x 18650 battery or 2 x CR123
LED: Cree ML-L U2
Update! The Revenger SRT7 comes with the brand new
Cree XM-L L2, and achieve the 1000 ANSI lumens !
measurements :
Head diameter 40 mm
Body 25.4 mm
length 158 mm
Weight 173 grams
Activated, the lamp is on one end cap, the selection of the light is achieved using the rotary ring on the lamp head.
There are also built three other LED that can emit red, green, and blue light !
The rotary ring on it, the following lighting levels from left to right ( ie, clockwise ) :
Locator Beacons ( short flash as a position light )
Red / blue light ( changing, strobe effect )
blue light
green light
Red light
standby
Turning range of 0.01 to around 1000 lumens, infinitely variable
turbo
strobe
Thanks :slight_smile:
Now, just to find out how/if there is step down, by time or thermal, etc. I’ve found nitecore is very misleading with their advertising when they say things like 960lumens for 1hr45mins :wink:
-Jamie M.
BLFUSER doesn't work for the pre-order?
On the one hand, I'm rather excited by this light, on the other hand, given the price point, I'm hesitant to pull the trigger. Would be the most expensive single 18650 light to date.
Any news on the SC600II Zebralights?
Thanks for the help picrthis, information is still very scarce on this model even to us. We'll be updating the listing as we know more. The SRT 7 has an automatic stepdown after 3 minutes on Turbo, but you can reactivate it like previous models.
Sorry, for some reason the BLFUSER code expired yesterday. I have extended the code again sitewide. Currently there are no promotions on this light due to how new it is. We've had an issue doing an intro promo with the TM26 previously.
Our order status shows a second batch of SC600MKIIs shipped but with no tracking number, we're attempting to contact Zebralight again about the status of this package.
I want one. I probably won’t get one due to the size and price, but I still want one. Good item for a xmas/bday list.
It seems like it’s roughly the size of a C8 but much cooler with the control ring, colors, random-speed strobe, and police flasher. However, I think what I really want is more along the lines of a rave light than a tactical light. If it had disco/rave modes and a wider beam and the control ring could also control the speed of a true strobe mode (freeze moving objects in place), I’d be buying one right this minute.
Hey guys, I've simplified our main post to make it easier to read and find products. You also do not need to log into our website to check coupon codes anymore :)
We're recently picked up the Nitecore MH25 which just about completes our line of Nitecore Products. The Nitecore MH25 comes with a Nitecore 2300 mAh 18650 and can be had at a special price with the coupon code: MH25
The MH25 is a two mode flashlight with a programmable second mode. It comes with a micro-usb charger for your charging convenience and a Titanium plated Stainless Steel clip because what's more fashionable than a sleek black flashlight hanging off your favorite belt or out of your pocket? (Or you could use the included holster.)
Wow, first post looks WAY WAY better, nice work :wink:
-Jamie M.
Received my Amytek Barracuda, and chargers yesterday.
For the price it's definitely a steal. It easily holds its own against the Crelant 7G5CS.
My only gripe is it won't tailstand. Are there any tailcaps/adapters that would allow it to stand?
Great deals …just ordered the EA8 and an I2 charger. Thanks for the deals.
