oh dear god man. he was totally joking.
no way in hell PDs would issue such a light! lol. no effing way.
(bluetooth security being the least of reasons why.)
The reason for the plastic reflector and non-AR lens is because they found that each of those adversely effects the BT signal. Together it cripples the signal really bad.
ZY-T08 was chosen for its proven high quality plastic reflector and its proven performance as a very good thrower. It just works out best for this initial light where the main focus is on the technology more than the host itself
The next 2 models will have completely original bodies and between these three lights most all flashlight needs will be met
You already know something about “battery features” ? Low voltage warning? Voltage readable over bluetooth? Capacity readable over bluetooth?
too cheap and too bright for the government
i also seriously doubt any one will have one set up to illuminate an enterance. was just a fictional situation where blue jacking could be considered an issue
thanks fasttech, that sounds more than sufficient protection against hacking
Thanks JohnnyMac for the insight! Normal bluetooth have a range of 10m and normally do not need line of sight, unless it’s a very basic bluetooth module I guess.
And… what?? The “next 2 models”?! My wallet is screaming for help.
But only AR coating? Is still too much for BT signal?
Actually, to conserve energy, Bluetooth is turned off most of the time. Unless you explicitly turn it on, no one is able to connect to it…
Ahh. That’s good. So how do you explicitly turn it on? Is it done from the (physical) light itself, like a specific press sequence?
ohaya: Pulsar:or maybe a cop will be using it, and while he is using his light to blind you at a night time traffic stop, you can dim it down to a pleasing level :cowboy_hat_face:
somehow i doubt this driver is a standard 17mmI seriously doubt (or hope not) that a LEO would use a light like this in that kind of situation… too much risk (even a little is too much) of something like what you described. I also seriously doubt that it’d be approved for use in this kind of situation, as it’d probably not get through any security review unless there are adequate safeguards, and just the “normal” Bluetooth security is not “adequate”.
Sorry if I came off being a little negative :)… FYI, I do think this light is a cool thing :)!
JohnnyMac:The next 2 models will have completely original bodies and between these three lights most all flashlight needs will be met
maybe an EDC light? …
Looking forward to those!
JohnnyMac:The reason for the plastic reflector and non-AR lens is because they found that each of those adversely effects the BT signal. Together it cripples the signal really bad.
That makes a lot of sense actually. So, those of you worried about being hacked, add an AR lens and alu reflector to protect yourself. Don’t forget your foil hat too! I never got a ZY-T08 so might just do this instead, if reviews are positive. Curious what these next two models will be. :~ Monster flooder and something more pocketable/EDC perhaps?
There is low voltage protection. At 3v it will kick into moonlight mode to get you out of whatever jam you might be caught in.
That is what they found during testing. They tried but it severely impacted signal reception. Having said that, unless you plan on changing the programming while walking of driving, you could always put on your own AR lens and just unscrew the bezel and remove the lens, reprogram the light, then reassemble the lens and bezel.
i wonder if there will be a flood of bt drivers in the next year…
i have heard of bt micro lights in development as well
i wonder if there will be a flood of bt drivers in the next year… i have heard of bt micro lights in development as well
As I understand it, Fasttech has already acquired patents on the technology and idea. I know the owner is extremely wealthy and will bet he will do what is needed to protect his investment.
Out of curiosity is anyone planning on trying to port the android app to ios? Sadly I don't really know enough to do so, but I certainly plan on playing around with it and seeing what I can get to work.
You can use Bluestacks on your computer and emulate an Android environment and you can run Android apps. But I’m not sure if the bluetooth would work.
kinda funny, just ordered ZY-T08 couple days ago and now the asgard appears in the same host...
excited to see the review though :)
kinda funny, just ordered ZY-T08 couple days ago and now the asgard appears in the same host…
So we need only new driver
JohnnyMac, why do you know so much? And what more do you know? 0:)
Because I’ve had some conversations with fasttech prior to this light being announced. You already know most all about this one now but if I told you what I know about the next lights I’d have to kill you. :bigsmile:
Nice light! Out of my budget though, after dropping $50+ each the last two months on lights. If there was a way to transfer my coupon code to someone else I’d do it.
