Since the moonlight mode doesn’t have PWM and each 12.5% in output doesn’t have PWM, I don’t think the moonlight uses any of the AMC7135 chips but uses something else instead. Seems to me you could double stack each 7135 if you wanted to get 6A output without effecting the moonlight mode. Of course I’m just spit-balling here but it sounds logical on the surface to an electronic ignoramus like myself.
that’s kind of what I was wondering, it would be nice to keep moonlight - 12.5% of 3a - 50% of 3a - 4.5a+ for high and use an xm-l2 nw on copper that way you get moonlight low no pwm medium no pwm - high no pwm 8)
I’m merely looking to build on the awesome platform presented 0:)
We have here, a light that seems infinitely configurable, we have been told we can set brightness levels at 12.5% intervals that have no pwm (8 chips, 8 levels that can be independently turned on, well you start at 1 and stack those intervals) that being the case, we have the options of a number of sensible levels and one stupidly high turbo level to unleash the throw potential of this host, check out tom e’s results in relics zy-t08 review thread to get where I’m going with this.
Given the opportunity, and potential, would you really not even ask the question?
It’d be my best thrower (since I gave the TK75 away), yet still be usable indoors thanks to low/extra-low modes. I think it’d get like 65k to 70k lux stock, and go down to around 3 lumens on the 8mA mode.
It’s programmable
I had been kinda thinking about a ZY-T08 or HD2010 or Jacob A60 or ZY-C10-S anyway, just for fun.
It’s programmable
But on the other hand…
It’s too big for most of my purposes
I almost never have a use for a long thrower
The control app might not be compatible with any of my devices
If they can fit this programmable driver into a Convoy S3 or similar, it’d be a no-brainer.
Maybe I just need to get the hardware to flash an ATTINY and take apart some tube lights. Or, the HexBright looks nice too, and its video shows the ability to handle press-and-hold events so it’s an electronic switch. Looks like its programming language is sufficiently powerful too, so I could give it algorithmic features and a wide variety of UI styles.
Or, as they say on CPF, maybe I should just get both. Or do all three.
if one can program 30 modes, or more, how does one access all the modes? Half press? How would u remember them all? Could someone please address this, thanks…
toy keeper, as I said in another thread, I’d really like to hear both yours and chloe’s opinions on one of these actually in hand.
The zy-t08 really isn’t so big, considering, I love mine for a jacket/cargo pocket thrower, I just see this as adding so much more usability to a stock zy-t08.
I’m not sure I’m the best person to ask… I grew up playing piano because I have long fingers. For me it’s more a matter of finding a place to put the light, and not so much about holding it. Ideally it’ll be small enough to fit in my purse and light enough to not rip the lining at the seams.
However, I do rather like lights small enough to be carried between fingers like a cigarette. Those are particularly comfy. Anything smaller than a SK-68 works pretty well for me as an EDC.
Just get a $4 BT USB dongle for your PC. Even a Mac can emulate windows if it needs to. They do have a Windows app for the FLEX system in addition to the Android (superior to IOS anyway ).
IIRC, it’s about 2cm longer and the bezel is about 2cm wider. Both are likely due to the bigger reflector. The handle, of course, is twice as wide with the two batteries. (like a Fenix TK35 handle)
It’s not huge, but it’ll still require a coat pocket or holster or bag.
I can stuff either a C8 or a SRK into my purse, but in either case the weight is enough to tear the lining a bit at the seams. I suspect the Asgard will only fit in my heavy winter coat pocket or backpack, so I don’t expect to be carrying it very often. Then again, I’ve been thinking of un-sewing and re-sewing this purse with a stronger lining material so I can carry more toys. AA, AAA, and 16340 lights are nice, but they’re no substitute for my bigger lights.
a nice light in the medium-throwy class…though I’m most looking forward to having this tech in smaller form factors. I look forward to Flex lights in the sub-C8 category (like Convoy M1/M2 or Shiningbeam Blaze) as well as something truly EDC’able in jeans’ pockets.
For the Asgard, there are 254 bytes reserved for commands and their accompanying parameters. However, each mode is limited to 64 bytes due to memory constraints. 64 bytes are enough for a morse code about 5-character long, depending on how you encode the message.
The light has a reverse clickie so no it can’t stay on while power button is pressed.
Mode groups are called profiles in the app. You can define unlimited number of such profiles, but to switch between them you’ll see your smartphone to be around.
There is a group of advanced commands which contains (pseudo) RNG (and more). We will explain on these advanced controls when the app is released.
