FLEX Asgard @ Fasttech
Never thought of the size since now…
How is the size compared to a c8? Similiar just with2 batts, or much bigger?
IIRC, it’s about 2cm longer and the bezel is about 2cm wider. Both are likely due to the bigger reflector. The handle, of course, is twice as wide with the two batteries. (like a Fenix TK35 handle)
It’s not huge, but it’ll still require a coat pocket or holster or bag.
I can stuff either a C8 or a SRK into my purse, but in either case the weight is enough to tear the lining a bit at the seams. I suspect the Asgard will only fit in my heavy winter coat pocket or backpack, so I don’t expect to be carrying it very often. Then again, I’ve been thinking of un-sewing and re-sewing this purse with a stronger lining material so I can carry more toys. AA, AAA, and 16340 lights are nice, but they’re no substitute for my bigger lights.
Edit: Dimensions:
  • XinTD C8 V4: 155mm long, 45mm head, 25mm body, 185g
  • Fenix TK35: 164mm long, 51.5mm head, 43.6mm body, 256g
  • FLEX Asgard: 174mm long, 65.5mm head, 42mm body, 329g
  • Fenix TK75: 185mm long, 87.5mm head, 52.5mm body, 510g
  • Skyray King: 133mm long, 59mm head, 50mm body, 512g
a nice light in the medium-throwy class…though I’m most looking forward to having this tech in smaller form factors. I look forward to Flex lights in the sub-C8 category (like Convoy M1/M2 or Shiningbeam Blaze) as well as something truly EDC’able in jeans’ pockets.
To answer some of your questions:
  1. For the Asgard, there are 254 bytes reserved for commands and their accompanying parameters. However, each mode is limited to 64 bytes due to memory constraints. 64 bytes are enough for a morse code about 5-character long, depending on how you encode the message.
  2. The light has a reverse clickie so no it can’t stay on while power button is pressed.
  3. Mode groups are called profiles in the app. You can define unlimited number of such profiles, but to switch between them you’ll see your smartphone to be around.
  4. There is a group of advanced commands which contains (pseudo) RNG (and more). We will explain on these advanced controls when the app is released.
Thanks! This gives me a much better idea what the light might be capable of.
I’m just waiting for the app now, to see if I’ll be able to run it.
I just want to be clear, this works with Windows XP and up right? The only reason I ask is that a lot of people seem concerned about being able to program this flashlight.
Well, that doesn’t sound quite ‘right’. Any person who buys this Should and Expects to be able to program it by Bluetooth, either from the PC app, or smartphone app. That’s the main attraction of this light. So your question comes across as a little ‘strange’. If not they would be better off with a ZY-T08.
But we don’t know yet anyway. Still gotta wait for the reviews, to confirm it.
I only ask, because I’m pretty sure I saw very early on that they said it would be via windows or Android. But I keep reading people worried that they can’t program it. Unless there’s been some information I missed- almost all people have access to Windows or Android devices so I’m asking for confirmation. Ok, let me wade back through and find the info for myself….
Edit: That took two seconds… Fastechs website…
Well that’s what I wanted to know.
Yep it’s stated in the website. But I’ll see the reviews to further confirm it. :slight_smile: I hope the reviewers could test programming via PC and phone :slight_smile:
No worries. We will. :)
(screenshot from a beta version of the software, UI will be changed to final..)
moonlight 20s - 100% 1s - moonlight forever……
thats evil J)
ordered.
pretty damn pumped.
Looks like Foy missed out on the beta . . .
daylatedollarshortFoy
Well, my prerelease sample of the new FLEXCandles Asgard model arrived today. This is the light with the Bluetooth equipped driver that can be programmed wireless on the fly using your Android device or even from your Windows PC using their custom FLEXCandles app. Sorry for some of the crappy pics...I couldn't wait to post them. :bigsmile:
Are you serious? Have you tried PM’ing them?
Hows the FnF compare to the small sun johnny??
Aside from the user interface, pretty much identical in every way. LOL! :slight_smile: I’m waiting to see if the others have received theirs yet and whether they are seeing a couple issues that I’ve noticed. Then I need to work with Fasttech to iron things out. :wink:
Not a big deal, I'd rather wait on the final version anyway.
jusmessinFoy
Yeah, but there were a bunch of people (including me) who were looking forward to your review! Can we start a campaign or something?
