EDC+ makes the Triple Nichia 219 92CRI driven at a low 2A and making 465 lumens, measured. Nice drop-in, all copper construction with silver plating to deter oxidation. http://edcplus.com/edcplusis-x60l3-triple-nichia-219-neutral-white-led-p60-dropin-p-131.html Have that as well as the Triple XP-G2 at 720 measured lumens in Solarforce L2P hosts and really like em. Of course, they’re floody with triple TIR optics.
I used the 92 CRI 4300K Nichia, obtained at Illumination Supply.
If that 2.04 A from the MBI HF is also going through the led, the initial lumen output must even be a bit higher than 200 lumens, closer to 300, but the upbuilding heat in such a small light (even though it is copper, the total surface area is just not very high) is costing lumens when it runs hot.
Although there is some debate on this (someone test this to settle the discussion?), I personally don't think it matters a lot if the heatsink is aluminium or copper, the main bottleneck for the heat path to the outside is the small surface area between led and board (it helps a lot if the led board is copper and even more important that there is no dielectric layer there), once the heat arrives at the heat sink the area the heat must go through is so much higher that any well conducting metal will do.
It was what the powersupply measured, the Vf probably being a bit lower. That reading was from the first run before the led had ever been exposed to more than 2A current. After I did the 4A current test I went back to lower currents and by then the Vf appeared a bit lower. This could be the reason for the inconsistent readings (or it was just my wacky test set-up ).
The small copper light heats up in pulling heat from the emitter but indeed, there’s just not enough mass there to make a huge difference. Also the 10250 Nuke runs out of power very fast at those levels. You can hook up a fresh hot cell for the amperage test and watch it plunge.
I also suspect you’re right about spreading the heat out to anything that conducts it, but wouldn’t a copper sink keep the copper star cooler such that the emitter stays that little bit cooler, and brighter? Only really useful I suppose when an emitter is being pushed hard, way beyond it’s limits. Like taking a 1.5A rated XP-G2 to 4A+. Or taking the Nichia 219 also a 1.5A rated emitter, to 5A and more, all copper would really make a difference there and I’m betting the numbers would prove that out.
Encase it in Titanium and watch it fry. (Ti nut, getting sold on copper for heat)
great work djozz! It’s neat to see how well the sinkpad allows the Nichia to cope with increased current, but it still shows how lumens/ watt drops off a cliff at higher currents (much the same as Match’s and the tests on CPF showed). Still, a 1.5A buck-boost driver would be perfect for this LED.
If you wanted a triple parallel on copper, why not Stinkpad-ify one of the IS 20mm triple stars? It’d be a bit of effort and a drill press would be very useful, but something neat to do. You’d still be stuck with the Carclo triple optics though, so it’ll still be more of a flood light. I’d be half tempted if I didn’t have a list of things to do as long as my arm and no particular need for one
I did a 219 mod with this light that I had waiting for it, a nice and cheap small thrower, I did a small review on it earlier:
I used the Nichia219 on the Sinkpad that I have done the above measurements with. I cleared the driver from all components and wired the battery + and minus directly through to the led. Assembled it all, the business end now looks like this:
It looks like that black spacer around the led is blocking light, but although it did that before, I sanded that ring down so much that it does not block the light anymore. Also I blackened the inside of the bezel with heater paint to remove the annoying rings in the beam profile (see the review), it looks now like this, nice:
The numbers coming out of this light, although it is completely direct drive now, are still less than I hoped for. On a freshly charged cgr18650ch (IMR) cell tailcap reading is 1.9A, and ceiling bounce lumen estimate is 300 lumen, where I hoped for 2.1A/350lumen. Apparently there is still a bit of voltage loss somewhere in this host. The throw by the way is 13klux@1meter, not at the least impressive, with the original xpe-led it was 25klux@1meter.
Oh well, it has still become a nice flashlight, the only Nichia219 'thrower-ish' light I have, I am looking forward to using it on nature strolls at night. And this is apparently about as far as the Nichia 219 goes in a single li-ion cell flashlight without boost driver.
This is cool stuff. I gotta do something with a H1 B10 using 2S 18650 and a buck driver. I know the output will be much lower, but I want high cri more. Based in your experience so far, what is the max current you would recommend if properly heat sinked? I know I would be taking a risk, but I would like to try the max current that would most likely not blow the LED.
As seems to be the case with most emitters on copper (or even on aluminium), the maximum output is reached long before the led blows (at least with good heatsinking). As can be seen in the graph the maximum output on copper is obtained at about 3A and although the led survives at over 4A, there is no point going over 3A.
Support the cause here, the more demand Intl Outdoor sees the more likely they are to make it. It should happen as they said but it takes them quite some time to make it.
Lets spawn their thread and emails with requests of XP-G/Nichia 219 Noctigon triple.
And I’m not going 2A triple or something, direct drive triple 0:)
Whether it’s going to be on alu or IO manages to make a copper triple board.
That would do to get the led at 3A, but since the OTF output of a single 219 light will never exceed 450 lumen, I want the light to be small, 2x18650 is just too big. Thinking of that I can just throw in the 2 Efest 16340 IMR batteries that I have in this light, direct drive will be no problem because the batteries can not deliver more than 3A anyway at this voltage (I doubt even if it reaches 2A with them, thinking of the high Vf of the Nichia) (to be continued...)
So in the end the waiting is indeed on the triple copper board...
Just encase you missed it, I did say 18350, not 18650. So 2x18350 will fit most 1x18650 tubes. (I have some AW IMR 18350 that work brilliantly in my Crelant lights).
Also I may have misunderstood, but are you saying you can direct drive off of 2x16340’s? i.e. direct drive from 8.4v?
And yes there is no proper driver for using Nichia 219 in general or XM-L2.
No good single or multiple cell drivers able to do boost/buck at 1.5A or 3.0A. (Efficient and programmable with a flat stabilized output curve.)
If the batteries suck enough then yes. But you will overload them, the batteries may not be able to give you the necessary current so they drop voltage a lot. If it’s some tiny and low capacity batteries, cheap brand batteries, that is quite common.
Sure you can’t do that with 2x good 26650 as they won’t drop and will burn it.
Also overloading the batteries means loosing usable capacity. You get more runtime when they are not overloaded.
Now that you are surprised I am not so sure anymore.... The voltage of 2 16340's under the max 4.4 A load that I tested will not be 8.4V but much lower, but perhaps not as low as 4.8V (the voltage at 4.4A), hmm, better be careful then .
Thank you for the response. I guess you’re saying there is no point because the lumens per watt peaks around 3A in your test. Is that correct guess? I see your graph, but your table shows lumens continuing to climb, but at a progressively slower rate, up to 4.5A. I don’t want to slow down your thread educating me. So no response is necessary. I need to go learn more about lumens and OTF. I just thought OTF was lumens net of light lost in the reflector and lens.
Yes, the lumens peak around 3A (the lumens/watt probably peak around 100mA ) In the table that is also the case, but you may have read the voltage colomn as current?, the current is the first colomn. And I am only glad when people learn something from what i write down , just a few months ago a lot of the number stuff was new to me, I was glad to learn from others as well
