Hi everyone;
I’m only a watcher on budgetlight for a long time.
Yesterday I complete a little 1000 lumen with single AA project and wish to share.
Firstly I bougt
the emitter from Fasttech.
It’s
http://www.fasttech.com/products/1609/10003889/1277804-cree-xm-l2-t6-1c-10w-6500k-1052lm-led-emitter
And driver from Dx
5 mode 4 star 2800 mah led driver. It’s the best way to feed a T6.
http://dx.com/p/17mm-2800ma-5-mode-regulated-led-driver-circuit-board-for-flashlight-diy-dc-3-4-5v-127684
And finally I need a little aluminum flashlight from anywhere.
And find it from DX.
http://dx.com/p/mini-0-5w-1-led-50-lumen-1-mode-flashlight-black-1-x-aa-134272
It have more than enough quality and the is a pleace for hold driver and emitter like expencive ones.
Total budget like 5,7+4,2+3,5 (13,4) USD.
Montage is very easily.
Results are
Tank007 703 (110 Lum)
Xml2 T6 with 2800mah (14500 battery. No idea Lum)
Thanks for interest.
Volkan Ademoglu.
hi volkan welcome to blf and congratulations on completion of your first project, I hope its given you the drive to enjoy many more builds.
Welcome Volkan,
in Turkish “Hoşgeldin”
It's good to have you here, vademoglu!
Werner
(Werner)
June 1, 2013, 12:17pm
5
That will Not work like you imagine…
The problem is this driver, will not give you 2.8A with a 14500 and xml2…
I have learned that a good driven XPG sometimes is better than an under driven XML. So order a xpg2 from fasttech and compare the light outputs…
relic38
(relic38)
June 1, 2013, 12:46pm
6
Welcome to BLF! That is a nice build. One of many to come I bet, if you hang around here.
Chloe
(Chloe)
June 1, 2013, 12:54pm
7
Hi Volkan! Welcome to BLF! :party:
Unfortunately I couldn’t see your photos unless I go to Google Docs directly. You could upload them to Picasa instead?
Sounds like a fun little guy that puts out a bunch of light. I may have to copy you and make one too. Welcome aboard vademoglu!
Here is a similar driver for about a buck less:
http://www.fasttech.com/products/1612/10001683/1186301-8-amc7135-2-group-25-modes-led-flashlight-driver-n
vademoglu
(vademoglu)
June 2, 2013, 12:10pm
9
Thanks for your good wishes.
The video link from last night .
I use the tail button with one hand. Because of this mode changes shown bad on video.
fyesilova
(fyesilova)
June 2, 2013, 12:31pm
10
it is better you specify “mA” instead of “mAh”.
mAh is a unit for battery capacities, means mA hour
your driver’s current capacity is the amount of current that can handle, unit should be “mA”
ryansoh3
(ryansoh3)
June 2, 2013, 12:47pm
11
Interesting build, do you have a way to measure the tailcap current?
