What's the name of this screw?
13 posts / 0 new
Haggai
Last seen: 2 months 1 day ago
I have a power strip with this kind of screws:
http://i56.tinypic.com/n3mfdf.jpg
Some metallic object (the tip of a badly designed plug) has found its way inside the strip, and I need to get it out, for safety reasons.
Do you know the name of the screw type?
The closest I've found are holt or tri-groove screws, but I'm not sure it's the right type.
Edited by: Haggai on 05/24/2011 - 14:46
Don
Don's picture
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
pounder
pounder's picture
Last seen: 10 months 3 weeks ago
tamper proof screws are just asking to be slotted with a dremel cut-off wheel..that's what I do if you can get a wheel in there..
Haggai
Thanks, Don, but I tried and can't see a fitting bit in the sets you pointed to or other sets I looked at.
pounder, no way can I use a dremel there - the holes are about 5mm wide, and the screw is recessed about 5mm into the hole.
pounder
pounder's picture
ahh yeah that does hamper things..
Don
Don's picture
Drill the heads out. They will be self-tapping screws into plastic bushes which tend to be destroyed by removal. I think the vaguely triangular ones will do it.
If not, get yourself a screw extractor, drill a small hole into the head of the screw then try your luck with a stud extractor. They are extremely hard and very brittle - hours and hours of joy when they snap off in the head and fail to extract the stud/screw. Not sure if you get them small enough to go into a 5mm hole though. Failing that just drill the head out - you can usually then remove the screw body with pliers. Unless it's glued to the plastic which is entirely possible.
In that case, you just glue the thing back together.
Boaz
Boaz's picture
Last seen: 1 hour 3 min ago
Sound s like a pain .. depending on the price of a new one ..that's the degree of violence or force I use on fixing or wrecking the item . I also have Joe handyman who lives behind me who i can chat over the fence with about such hardware store items and dilemas...i'm usually back to more force  and the cordless drill .after about 20 minutes of trying to be smarter than an inanimate object I re-evaluate my time vs. effort and what I'm worth per hour  and hit the object with a hammer while crushing it in the vise to find out lastly what other amazing engineering they've  incorporated into this marvel of technology .I also try to gauge the structural integrity of the plastic as I bash it with a hammer and chop at it with a hacksaw ..lastly I scavage it for useful parts ,a switch , the cord or whatever is salvagable  and with great satisfaction drop the rest into the trash can .My idea of fun .
Boaz
Boaz's picture
or duct tape ..
Don
Don's picture
or duct tape ..
Nah, hot glue is the preferred solution in this case. Not that Don tape doesn't have its uses...
:bigsmile:
Haggai
I was hoping to find a 2$ screwdriver/bit that fits.
Maybe I'll try the drill'n'glue method...
Hobbyfotograaf
Last seen: 3 weeks 3 days ago
It becomes very difficult to repair things, if there is something wrong, you will have to throw it away and buy a new one...
I have this set of special bits, but if they design new screws, these become useless. The one you need is not in this box. (bought this on a local store for 9,95 euro)
Lennart
Lennart's picture
Last seen: 4 months 4 days ago
Lennart
photon1k
photon1k's picture
Last seen: 4 years 9 months ago
My idea of fun was reading this post. I laughed so hard I was literally crying. Probably because I recognized my own behaviour in your writing. Thank you!
