I cringed a bit seeing this. I don't even like soldering the 7135s.
Thanks for the great read.
I solder the two caps end to end across the three legs. That puts one across the input and one across the output of the VR chip. Getting them to stay put till I solder them is the biggest pita. I’m thinking of making a cradle to pre install the caps on the pins before the chip goes on the board. The rest of the mod is otherwise pretty easy. I haven’t posted in this thread recently as since this part works, I’m working on the next part which is a battery fuel guage similar in size to a 16mm pcb. Maybe even use it to replace the tailcap switch pcb and show the charge level. I think I understand the circuit well enough. The question is do I A) have boards made and populated(expensive), B) have boards made but populated by me(less expensive, more pita but I can make them for different voltage at no added cost), C) make the boards myself using photoresist on either presensitized(better for small traces) or regular pcb material. Feel free to chuckle if you think I’m in over my head.
you might be in over your head, but you’re a strong swimmer!
I mistakenly posted the following questions in a different thread:
[image] Could linear driver work this way? AFAIK linear drivers regulate current to a certain value and burn excessive voltage as heat. Usually they are used with one Li-Ion battery and one led. For example we have a 4V batteries a 2A linear driver and a XM-L leds. In a 1 battery 1 led configuration led have 2A at 3,05V. The driver would burn 1,9W* as heat *(4-3,05)V x 2A = 1,9W And here’s my “thesis”: In a 2 batteries and 2 leds configuration (as pictured above) leds would still have 2A …
I meant to post here because this is were the original idea was posted.
I would like to try the mod in Post 22 above. I want to use it to drive an MG-T2 with 2 li-ions or 6 Ni-Mh’s. I’m not following the bit about adding a resister with a switch to cut it (the resistor) out at lower battery voltages. Would the resister part be necessary for my app which has fairly limited difference between supply voltage and Vf?
Secondly, wouldn’t the 2 volt dropout from the 78L05 serve as a low voltage cut off? 7 volts comes out to 3.5v for each cell.
Not needed. Remove & replace the original diode with a ~100 ohm resistor, and put a zener diode across (in parallel with) the top of the capacitor on the other side of the board. That's it, works fine.
I have pictures of what to do posted here somewhere, but with the forum's method of only listing threads started instead of all posts in all threads, it's a serious pain to go back and find stuff later, like now...
but with the forum’s method of only listing threads started instead of all posts in all threads, it’s a serious pain to go back and find stuff later, like now…
Click "My Account"
Click "My Posts"
Click "General Settings"
Change "Content" from "Node" to "Both"
Click "Apply"
Thanks comfy. I’ve seen your mod and it is great. Haven’t tried it yet, but will eventually. I already have some of these regulators and want to give this approach a shot.
Linear driver with batteries and leds in series
The 78L05 is only regulating the supply voltage of the mcu and is not otherwise involved in the led power circuit. Since the mcu will operate down to under 3V(1.5V/cell), there is a risk of over discharging the cells unless you pay attention to the led and recharge the cells when the light begins to dim on high(<6V or 3V/cell). With an overdriven led this should happen at a higher voltage but at lower output there’s still a risk of over discharging the cells. The switch and resistor was a means of burning excess voltage over what the 7135 chips could handle and when the battery voltage drops to something manageable, the resistor would be bypassed, allowing the 7135 chips to handle the remaining load. Probably not necessary with 2cells/2xmls or 2cells/1mtg but may be needed for 3cells/3leds and certainly for any more than that.
Thank you Rufus. So the regulator will just quit regulating below 7v and just let the current pass. Makes sense.
Thank you for your opinion on necessity of the resistor/switch. It’s worth risking inexpensive 7135’s to not have to develop a separate resister circuit with a mechanical or automated switch of some sort.
I’m not an EE so I don’t know what happens to the 78L05 below minimum but there’s another chip, the LD2981 that works down to 5V and is the same package size and pin layout. It would save a boatload of effort if a nanjg driver were layed out with this chip located next to the mcu. With more mtg mods going on it might make more sense now.
Check out the LM2936, it has a VERY low quiescent current and a 0.2V dropout.
The 7805 chips typically look like a 2V dropping diode at input voltages below their dropout voltage.
Rufusbduck, I'm finally going to try your idea in Post 45. I'm not going to surface mount, but I am going connect the L78L05 to the same point as in the below pic.
Question. Will the 5v regulator consume power all the time (i.e. even when light is off)? I can test this myself, but was wondering if you know right off the bat.
No, only when the circuit is complete. It does the same thing as the Zener mod but has slightly wider input voltage range so it could work with 2s liion - 2s led, 3s liion - 3s led, or 2s liion - MT-G2. The LD2981 will work for any of those. The L78L05 has a slightly higher voltage drop and works better on 3S mods. DrJones was the one who pointed me towards them way back when.
Thanks Rufus. Sorry, I should have been more specific. I was thinking momentary switch situation where battery circuit is always complete. Kind of figured it wouldn't use juice when the cells are disconnected.
Thanks for the info on the lower voltage drop units.
Yes, it will draw large amounts of power. And not give any reverse voltage protection. Try an LM2936.
Thanks TexasPyro. So if I did use one of my L78L05's, it would need to be a light that I can lock out. Kind of expected that, but hoped other wise.
The way I wire it still has reverse protection since I use the polarity diode as the jumper from B+ to the input pin of the voltage regulator.
Old thread I know but resuscitated due to current application.
The LM2936 has built in reverse polarity protection and a dropout of .2v and is available in sot223.
The LD2981 doesn’t have reverse polarity but dropout is between .007-.170V and quiescent current is 80 microA no load. It’s a sot89 package.
Both require capacitors on input and output.
Using an FET in place of all 7135 chips and adding 28.7k resistor to regain low voltage protection.
I keep starting down this path (LDO voltage regulation) and then end up going off the rails. I want to implement LDO for a 4S configuration. Based on the data sheets, the LM2981 out. The LM2936 can take up to 40 volts. So it seems the way to go. It doesn't appear to come in a SOT23-5 package, which is a bummer if one wanted to use wight's LDO board. Guess air wires will be the solution until I get a chance to build some boards in Eagle.
I'm ordering some 5v LM2936's and 81's right now. So I'm all ears if anyone has any relevant suggestions.
EDIT: Ended up just ordering some LM2936's in the TO-92 package as it seems they would be easier to air wire. I need to figure out what size/type caps I will need for the input cap. The data sheet also says the device's overall input cap can be relied on if within 3 inches of the LM2936, but encourages using a input cap regardless. So maybe I can skip that cap.
The data sheet says proper ESR is critical on the output cap. It says a resistor value of 500-mΩ to 1-Ω must be used in series with output cap for ceramic caps to simulate ESR. It calls for a minimum 10 μF cap for the 5v version. I'm assuming the 10 μF smd's we use on our DD drivers is ceramic. So it appears I don't need to order any caps.
What’s the series Vf of the LEDs?
