Umm . . . I don't think anyone is going to say those things! We're waiting for you to do it! :) Thanks for these tests by the way! This is very helpful information to many of us!
-Garry
-Garry
Very nice and useful graphs!
I have bookmarked this page!
Djozz, would be nice have a chart going to 10A or slightly beyond on the MT-G2. You dont have to kill it just for the sake of killing it. But if output seem to continue to rise, then I would not mind seeing what 12A would do, despite not knowing of any drivers that will do that kind of output.
There is not that much point in going far beyond 10A just for the sake of killing it. But it would be nice to know if there is some headroom left at 9A. 0:)
I agree with R86, no need to destroy it. I’m more interested in finding where adding more current results in no increase or a decrease in output. In the case of the XP-G2, this occurred before failure. The XM-L2 was still trending higher when it failed.
This information is very helpful, just don’t feel the need to destroy the emitter if the useful information has already been captured.
I probably would have tried this already if I had a supply with that current carrying capability (6A max for me).
Thanks for your efforts on this!
ok, I don't know what to expect actually, the MT-G2 is a multi-die emiiter, the combined surface area is much higher than a xm-l and the solder path is huge so if the thermal path is built like the xml2 the dies should be able to handle 20+ amps, but if the bond wires can handle that? When the weakest wire goes the rest follow directly because of increased current. Wait and see...
I don't think you'll need to kill it, I suspect the light output will fall off a cliff long before anything goes ZZZZAP.
In terms of ºC/W versus area the Luxeon T comes out on top.
LED: ºC-mm^2/W
MK-R: 13.6
XM-L2: 10
XP-G2: 8
Lux T = 5.44
XP-E2: 9
The XP-G2 is slightly larger yet has a higher thermal resistance value than the Luxeon T. The T's thermal resistance is less than double that of the MK-R despite the latter having over four times the area through which to transfer heat. Not sure why the XP-E2 appears to fare worse than the XP-G2 in this regard but I rashly conjecture and am likely wrong that it has something to do with the way ºC/W is measured and the following tidbit:
Max Rated Wattages/Square Millimeter (85ºC)
MK-R: 1.9
XM-L2: 2.48
XP-G2: 2.25
Lux T: 1.57
XP-E2: 3.15
I just saw this. That was awesome. Simple and to the point; turn it up 'till it blows.
Also interesting that the XM-L2 kept getting so much brighter at higher currents. I was under the impression that anything much over 3 amps went to heat with increased lumens dropping off. Is the upgraded XM-L2 different or am I missing something else?
Sorry if this has already been discussed . . .
learningFoy
:O
This is y I luv the amps and the coppa
And copper.
It just hit me. I already have a xml2 on a copper sinkpad that is reflowed to a copper slug that is reflowed to a brass pill in a Torchlite SV-D2. The light has really good heat sinking. Driven at 4.5 amps the light has no issues at all. Some people have been driving MG-T2’s hard in them.
So, I want to change out the driver and push that xml2, but not hurt it. Any opinions what current I should use? I want to try 7 amps. Is that pushing too close to the limit for this type of flashlight being used outside in hand?
Very roughly, 7A at 3v (XML) is the same power (watts) as 3.5A at 6v (MTG2). Actual numbers will be different and also you have to figure in driver efficiency and a whole bunch of other stuff but that should be enough to get you started.
That helps put it in perspective. Thanks. I need to try to do this tonight. Wife is out of town. So it’s time to play with my flashlight.
Do it.
Also, what driver? I need to find a two cell driver that does 6-7 amps for an XML2
I’m going to use my go to driver for the first attempt. The Manafont “3T6” driver. People have been resister mod’ing those for multi-emitter lights with good success.
Hmm, 7 amps is very close to the current that blowed the led. Mind that in the test the time at which the led was at that high current was perhaps 2 minutes, no one knows if the led can do the trick continuously without burning through. The temperature in a actual flashlight will be higher too. And I guess there is some variation between individual leds too.
All in all, well, perhaps just give it a go and tell the world
djozz, I managed to repair a single broken bond wire on an XM-L with Liquid Solder from Radio Shack.
Perhaps a very narrow strip of wax paper could be laid on top of the gap between the plates, the liquid solder placed to contact the remaining tabs, then the wax paper removed after it cures? I’ve used aluminum for separation when soldering and it works just fine as the solder doesn’t stick to it.
Don’t recall it being said but the bond wires are brass.
Nice work with the charts, appreciate it!
Just a thought…
Wow, that sounds like a delicate job well done. I am still curious if the xm-l2 can be driven a bit harder than 8/9 amps with extra thick bond wires, this may be a way to do this :-) .
I am told that the bond wires were gold, but that may be a myth among flashoholics...
But I would just about swear I read in Cree documentation that the bond wires are brass.
I used a fine seamstress’s pin (German made, thinner stronger steel) to lay the smallest possible bead of the black liquid solder in place. When I took a macro image of the work it looked like something a giant splashed on it by stomping in a mud puddle. lol
In this instance, 2 of 3 bond wires were pulled when de-doming. The wires were still there, I just had to move them back into position and bond them to their counterparts. Pretty easy, considering and compared to what you were facing with the wires blown off completely. But it might be quite possible to use a thin wire as a replacement, if placed into the liquid solder such that a small drop is on each end, perhaps the wire could be placed in position and the liquid solder would bond it there effectively re-wiring the damage. ??
Perhaps the bond wires are gold plated brass? They seem stiff and brittle, much like brass would, but look like gold. Seems funny, looking at their tiny size, that everyone is stuffing larger wires in lights to conduct the power they crave when it all has to come through these teeny tiny wires in the end!
How many Amps does it take to vaporize Phosphor?
My bet is, there’s some folks here that aim to find out! lol
Could a thin piece of brass sheet, or copper sheet, be curved into a “half pipe” then bonded in place over the connection points on either side of the gap using the liquid solder? Hmmmm…….
Ok, this really got me brainstorming….why couldn’t a thin strip of the very dome that’s been removed be sliced with an XActo knife to fit over the gap and cover the emitter side exposed plate so the liquid solder won’t short the 2 sides, then use the liquid solder in a solid sheet right over the top of the silicone strip joining the connecting plate to the die? The liquid has a tendency to pool, a needle point can be used to drag “traces” where they need to go. The material dries to a hard but not unbreakable solid, they call it a glue but it doesn’t have any real elasticity to it and will flake/break if stressed or pried on. I think it’s infused with graphite. It does stick fairly well, but not like an epoxy.
This could be used to re-enforce existing wires so they wouldn’t blow under higher amperage. Or so it seems to me.
Edit: For the record, the gap doesn’t need bridging as is evidenced on this XM-L, but the layout is different on the XM-L2 and I assume the XP-G2 as well. If the 2 sides cannot be connected, then this bridging method may work to provide an answer.
