Do you know how that driver performs on 2 cells with 1 led? Does it only go direct drive with 3 cells + 3 led’s?
Think I need one of these drivers
Thanks!
Thanks!
This is a direct quote from Hank: It's more likely to output 3.5A with 2*18650. With 3LEDs and 3Cells the driver will probably go linear and we don't know if it will do 3.5A to each. The output current has not been tested, so we can't really say it's truly 3.5A even if that is what we requested.
Pretty sure it's 3.5A output though from previous posts, but not sure...
Sounds like a happy accident, haha.
Wish I had the funds to get a BTU shocker
ive got to get some of those batteries!!!
Thanks for your comments and help, it is very much appreciated, at least I’m learning ha ha!!
tabs
Yes, or Samsung 20Q's or 20R's - might even be better? Check your amps though to be sure it's within reason. Also please check your copper braiding in the carrier, not sure if I did all 5, and I'm also concerned how they hold up under battery changes... I've had some fail after a while, but it may be because of my earlier methods. Seems like I learn a little more with every mod.... With the solder wick, it helps having a little extra length curled up, and you have to keep the solder from wicking up or down from the ends. If it does, toss it and try again. Those springs w/solder wick in the Shocker carrier take a beating with long cells like the KP protected ones.
instead of a good 22 or 20 ga wire? I usually even leave the silicone insulation on the short wire in case one end lets go, which hasn’t happened to date. I also solder the wire inside the spring, up against the bottom ring so that it’s on the board and in contact with the spring coil and at the top I solder it to the inside of the top 2 coils where they meet. In this way I’m not interfering with the springs travel or it’s connection to the cell, just transferring the current to the wire.
If it’s a larger spring, like on the tail switch, I actually put a bit of a coil into the wire so that it compresses vertically instead of trying to bend over and chance getting in between spring coils. I’m finding this addition makes the single biggest difference when modding a light, aside from an emitter swap. It also lets you tweak the most from a driver swap.
Dale - don't think I tried the silicone wire, I think (maybe once?). The springs compress close to fully flat though with KP 3400's, so wondering if there's room for the insulation on 22 gauge for example. I should really try it though. It sounds like I solder the solder wick ends exactly like you describe for the wire. Well, got two more Shocker battery carriers to wire up at home, so, time to try it!! Wondering if it would make a difference for a TN31, hhmm...
Very impressive results Tom. And I thought my 3700 lumen BTU was impressive. Now you made it possible to get another 1000 lumens out of it. Wow. Very cool experiment. That setup isn’t to practical with little batteries and direct drive though. Might be if fun to have a spare BTU “turbocharged” like that just for fun.
Wonder if using lower quality batteries are the culprit for other not satisfied owners of BTU?
In my case, I don’t think so. I’ve tried 3xEfest IMRs and also new (bought in anticipation of the Shocker) 3xCGR18650 (high drain) batteries, with same results, ~100Klux.
Edit: These are the CGR18650s:
http://www.ebay.com/itm/230794118631?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1439.l2649
Thanks ohaya.
Did you message Ric about your issue?
Hi,
Yes, I did, but FYI, I don’t want to derail Tom’s thread here, so you can check this other thread about my situation:
Jim
Well done, de-dome (400K lux?) and beam-shots please! J)
Next logical step is to dedome, just make sure the get the PICS before and after!
Nice work as usual Tom.
Dunno bout de-doming the Shocker - think there are focusing issues, it's been done, think'n maybe vinh, maybe mentioned on CPF? can't recall. This shocker is on the way to Colorado - owner. Jim (ohaya) mentioned the LCK-LED driver to me (http://www.lck-led.com/5000ma-driver-modes-p-935.html), the size and function match up to a Shocker - wondering now how that driver would workout, if better than the IOS 3.5A rated driver I used. Think'n it would go direct drive, but even if not, if it tries to achieve 5 amps regulated, wow, another shocking setup .
Man, de-domed, 400+ kcd with all those lumens and spill would be insane!!
Try it with some 1st gen XML T6s, if dedoming does much. I know with the tn31 it more than doubles throw, not sure about this though but it definitely should increase.
um, now this is outrageous! waaaay to go tom E
tom, I have used that driver before, it is a good one imo, infact I ordered two more last night for a couple of convoy l2 builds, the last one I received looks nothing like the picture on that page……I’m hoping these next twp will be identical to the first o recieved or I’m in the cacky but I will report back.
fwiw, I used it in an mt-g2 build and I couldn’t be happier with the outcome, really good mode spread and no whining.
All of these threads on modded BTU’s are really making me want to send out mine or order a new one for moding by one of the amazing talents on this forum! Tom, amazing work as always sir!
