OK, I went a little crazy… I added the ability to change the Morse code message without having to re-program the driver. Default is SOS. If you want it to send “FOR QUEUE” or any other message (up to 16 chars/60ish dots and dashes) you can now do it. It’s a kludge, it’s a pain, but you can do it.
The editable morse code is a really cool feature and, important for flashaholics, completely useless up to the moment the zombie outbreak starts (you know: zombies don't know morse).
It’s actually not too bad. You enter Morse programming mode (hold down switch while powering up the light until it blinks 9 times. Release switch. It blinks 9 times again to confirm you are in Morse programming mode. Then it starts blinking once a second. Count the blinks (A=1 … Z=26 SPACE=27). Press button when the desired letter is reached to store it. It blinks three times and starts counting up letters again. Lather, rinse, repeat. When done, power off the light. If you miss your desired letter, it will start counting again.
Read the description in the first post. The driver is programmable. You select the modes that you want to use from the list of available modes. If you don’t want to see a mode, don’t program it in. There is a hidden mode available for saving that one annoying mode that you might someday need.
well I was paying attention and reading every new post, the hardware was ready long time ago but then came the UI experimenting, every second post started with “I now changed …” and it was kind of exhausting to follow all that…
Perfect one-button interface would for me be DrJones mobydrv interface but with 2 changes:
- long press for instant power off and
ability to toggle mode memory on and off so it would return to previously used mode after powering it off (if mode memory is active) or start from first mode (if mode memory is deactivated)
and since you are using more advanced MCU with more I/O capabilities you could add SMD led diode as battery status indicator or/and you could add a second button (or 2-stage button)…
It has instant power-off by long press. Also has the ability to control mode memory. There is a blinky mode that blinks out the battery voltage and temperature.
When the battery voltage falls below 3.0V, the light blinks two and the light level cuts in half. The reduced load causes the battery voltage to rise and the process repeats each time the battery hits 3.0V. When it gets so low that it can no longer produce light, the light shuts off.
Any chance on making a driver that can be run from 12VDC? I’d like to use a SRK on my son’s dirtbike for a headlight since he likes to ride a little past dark.
