well I was paying attention and reading every new post, the hardware was ready long time ago but then came the UI experimenting, every second post started with “I now changed …” and it was kind of exhausting to follow all that…
Perfect one-button interface would for me be DrJones mobydrv interface but with 2 changes:
- long press for instant power off and
ability to toggle mode memory on and off so it would return to previously used mode after powering it off (if mode memory is active) or start from first mode (if mode memory is deactivated)
and since you are using more advanced MCU with more I/O capabilities you could add SMD led diode as battery status indicator or/and you could add a second button (or 2-stage button)…
It has instant power-off by long press. Also has the ability to control mode memory. There is a blinky mode that blinks out the battery voltage and temperature.
When the battery voltage falls below 3.0V, the light blinks two and the light level cuts in half. The reduced load causes the battery voltage to rise and the process repeats each time the battery hits 3.0V. When it gets so low that it can no longer produce light, the light shuts off.
Any chance on making a driver that can be run from 12VDC? I’d like to use a SRK on my son’s dirtbike for a headlight since he likes to ride a little past dark.
(I don’t have a SRK yet, but once things are clear, I’ll get one. The only thing that kept me from buying one was the stupid stock driver …
Do you have a reliable source for SRKs?)
P.S.: Is there any chances of getting a driver like this for the Kung? If so, I would go crazy
One note on SST-90. It has a fairly high Vf even when driven at only 3A (3.47V after ten seconds or so). An XM-L is right around 3.2V at 3A, XM-L2 is 150mV or so higher.
The result on and SST-90 will be an early drop-out of regulation.
At 6A, the SST-90 Vf is 3.65V.
Note: These were tested on actual emitters I had mounted on a heatsink.
