Here’s the details on what Vinh does.
- XML2 6500K Dedome 1800 LED Lumen (Factory 3-3.5A will be raised to 6.5A) (tint will look like 5000K after dedome)
- Thick direct copper bonding
- Premium Thermal Comound
- Larger LED Wires
- All current conection touch up
- Battery carrier tweak
- Tune for most intense hot spot focus
- These lights will be shipped to me at the beginning of August. Orders will be fulfilled immediately as I receive them.
- Expect very intense hot spot and generou swide spill.
- I like this light more than the TN31 because you get a larger hot spot and wider spill that light up a larger area while losing just a bit throw (neligible throw IMO). Most importantly I like the K40 more than the Tn31 because the size is more compact! Two of my customers who had the chance to handle my fully modded K40 and TN31 side by side pick the K40 over the TN31. These two customer were the only people that got to handle the lights side by side.
- The first 3 mode in the UI will be very close to factory. The next three mode will be brighter than factory.
- Runs very hot on the 6th mode or Max brightness. On extended run turn the light down a few clicks
- You can run the light as long as it gets too hot to hold.
