Seriously? 500kcd from an XML2 TN31?
I know it’s mind boggling, but it’s not 500kcd. It’s not that easy reaching 500kcd.
Here’s the modded TN31 shot I really like to show it’s true throw capability 300yds to the furthest tree up the street. And this was only a manual 1.2 sec shutter just like the others above. ISO was 400 and focal was 3.2.
Those guys that are interested in buying one of these from Vinh can go here. He’s selling them like hotcakes. He’s just a great guy who knows what he is doing to get all you can out of these type flahlight mods.
Rick,
You will not believe the difference.
I highly recommend his work to anyone here. He’s making lights years ahead of what’s out there now on the market.
These lights are said to even out throw saablaster’s TN31MB that are rated at a little over 400K.
Vinh said he got 480K out of my other TN31 I sold him. I have no doubt this one is right at that or better.
So you’re telling me that a tn31 driven at 6.5A has 500kcd while my tn31 driven at 5.6A only has 360kcd? 900mA especially beyond the 6A mark giving an additional 140kcd?
Both dedome and using the same Led…
Okay… If you say so…
Believe what you wish. I’m telling you what Vinh said. You can take your negatism somewhere else for all I care. I have no doubt this TN31 is 480K at least.
So you’re telling me that a tn31 driven at 6.5A has 500kcd while my tn31 driven at 5.6A only has 360kcd? 900mA especially beyond the 6A mark giving an additional 140kcd? Both dedome and using the same Led… Okay… If you say so…
I'm looking into this now. Today I measured about 7 amps between the carrier and driver for 2 resistors, and getting about 390 kcd measured. So, I'm not getting much more. I know my kcd #'s are low, so maybe it's really 410-420 kcd, still 60 kcd (12.5%) behind. I copper braided the + spring and saw no gain at all. So only thing I can conclude is the LED-star and positioning. vinh says he's doing something about it, just no clue what exactly. I left everything pretty much stock - same star, same emitter, but re-seated the star with AS5 and lapped the surfaces, went with 20 gauge LED wires.
So if it's only 12.5% addition he's getting, in theory you could make that up in simply re-positioning the LED - I've seen those kind of improvements before, but really doubted it for the TN31, but who knows - maybe the factory/design was that messed up?? Thinking if you raise the LED, lower the profile of the plastic alignment piece, you may get a nice bump, so could be what he's doing.
He mods a ton of lights I'm assuming for profit, so he's either too busy or too protective to explain details of this mod, dunno... he's a pretty good guy and probably just too busy, but he doesn't really participate on BLF, so maybe he'd post details on CPF eventually. Now if I could take a look at Brad's mod'ed TN31 or any other vinh 480 kcd TN31 or his super K40's, it would probably be pretty obvious. He only fairly recently did these high end TN31 mods, before, he was not doing any resistor mod at all, just de-doming, wires, and a SinkPAD he claimed...
Edit: Just posted a detailed question to vinh on his help line forum on CPF. May take a while but see if I get an answer.
Ohh, also, 480 kcd is what was measured by someone on this level TN31 mod, but of course there could be a wide variance from unit to unit, so 500 kcd is in the realm of possibility for what you are seeing.
geez, that picture is insane! ive seen plenty of modded tn31’s but this one takes the cake.
i am highly interested in the k40 now. i like the fact that its smaller, but more importantly ….you said more spill and slightly less throw.
ill give some away some throw for some spill.
hey brad, about how much for floodier/spill would you say? you dont happen to have a beamshots of your k40 along with your tn31 do you?
that will help me decide.
Beamshots are in here of both.
Guys I had a guy send me a pm the other day about updating my XM-L thrower thread I once did that I deleted some of the images due to the fact a lot of them were taken I believe in auto exposure. And I didn’t want nor feel like I should leave them up here due to the fact that my buddy troop taught me better and now I know what truly seems to represent the beam you will see in person with your own eyes. So I just got done taking some at 110yds off my pool deck at my neighbors pool. It is very clo…
This TN31 that Vinh did for me makes the BTU Shocker seem like a toy.
I’m telling you it’s very close on a wall to my POB 35watt HID that saablaster said his POB did like 540K. Now I know this TN31 won’t out throw the POB due to the like almost 6” reflector diameter. But it’s the most throw power I have ever seen in a flashlight this size.
Here’s a shot from the BTU Shocker. Compare that to the TN31 that Vinh modded. It’s like comparing night to day.
Fortunately the Shocker is not a designed for throw light, like the TN31 - really no comparison. Nothing beats a fully mod'ed Shocker in output and throw in this general size. I'm measuring 4,500 lumens, 220 kcd. Now if you de-dome those XM-L2's, whoa, potentially it can reach the same 450-500 but with a lot more spill and output. Of course for a couple more pounds and a lot less runtime .
Click to Subscribe?
YES
I just got done taking these beamshots on the same exact camera settings as the 110yd shots above of man exposure 1.2 sec shutter f/4 ISO 400 to show you guys that Vinh’s TN31 XM-L2 mod holds its own with a 540k approx Power On Board 35watt HID spotlight.
Now I took this one of the POB at 300yds. The only thing different between this one and the TN31 300yd shot is the focal on this one is 4 and on the TN31 it was 3.2.
So to show a mouseover and mouseout comparison between these 2 mouseover for the POB 35 watt HID and mouseout for the Vinhnguyen54 dedomed XM-L2 6.5 amp TN31. Now you be the judge. I know which one I'm picking for the one that won.
That pool wall says it all. This even surprises me. :bigsmile:
Unthinkable!
That means this Vinhnguyen54 TN31 mod will easily out throw a FF4.
Unthinkable!
That’s what I say.
To be fair I’m gonna go take another TN31 shot to show the same beamshots from the exact same nite.
