Believe what you wish. I’m telling you what Vinh said. You can take your negatism somewhere else for all I care. I have no doubt this TN31 is 480K at least.
I'm looking into this now. Today I measured about 7 amps between the carrier and driver for 2 resistors, and getting about 390 kcd measured. So, I'm not getting much more. I know my kcd #'s are low, so maybe it's really 410-420 kcd, still 60 kcd (12.5%) behind. I copper braided the + spring and saw no gain at all. So only thing I can conclude is the LED-star and positioning. vinh says he's doing something about it, just no clue what exactly. I left everything pretty much stock - same star, same emitter, but re-seated the star with AS5 and lapped the surfaces, went with 20 gauge LED wires.
So if it's only 12.5% addition he's getting, in theory you could make that up in simply re-positioning the LED - I've seen those kind of improvements before, but really doubted it for the TN31, but who knows - maybe the factory/design was that messed up?? Thinking if you raise the LED, lower the profile of the plastic alignment piece, you may get a nice bump, so could be what he's doing.
He mods a ton of lights I'm assuming for profit, so he's either too busy or too protective to explain details of this mod, dunno... he's a pretty good guy and probably just too busy, but he doesn't really participate on BLF, so maybe he'd post details on CPF eventually. Now if I could take a look at Brad's mod'ed TN31 or any other vinh 480 kcd TN31 or his super K40's, it would probably be pretty obvious. He only fairly recently did these high end TN31 mods, before, he was not doing any resistor mod at all, just de-doming, wires, and a SinkPAD he claimed...
Edit: Just posted a detailed question to vinh on his help line forum on CPF. May take a while but see if I get an answer.
Ohh, also, 480 kcd is what was measured by someone on this level TN31 mod, but of course there could be a wide variance from unit to unit, so 500 kcd is in the realm of possibility for what you are seeing.
geez, that picture is insane! ive seen plenty of modded tn31’s but this one takes the cake.
i am highly interested in the k40 now. i like the fact that its smaller, but more importantly ….you said more spill and slightly less throw.
ill give some away some throw for some spill.
hey brad, about how much for floodier/spill would you say? you dont happen to have a beamshots of your k40 along with your tn31 do you?
that will help me decide.
Beamshots are in here of both.
This TN31 that Vinh did for me makes the BTU Shocker seem like a toy.
I’m telling you it’s very close on a wall to my POB 35watt HID that saablaster said his POB did like 540K. Now I know this TN31 won’t out throw the POB due to the like almost 6” reflector diameter. But it’s the most throw power I have ever seen in a flashlight this size.
Here’s a shot from the BTU Shocker. Compare that to the TN31 that Vinh modded. It’s like comparing night to day.
Fortunately the Shocker is not a designed for throw light, like the TN31 - really no comparison. Nothing beats a fully mod'ed Shocker in output and throw in this general size. I'm measuring 4,500 lumens, 220 kcd. Now if you de-dome those XM-L2's, whoa, potentially it can reach the same 450-500 but with a lot more spill and output. Of course for a couple more pounds and a lot less runtime .
Click to Subscribe?
YES
I just got done taking these beamshots on the same exact camera settings as the 110yd shots above of man exposure 1.2 sec shutter f/4 ISO 400 to show you guys that Vinh’s TN31 XM-L2 mod holds its own with a 540k approx Power On Board 35watt HID spotlight.
Now I took this one of the POB at 300yds. The only thing different between this one and the TN31 300yd shot is the focal on this one is 4 and on the TN31 it was 3.2.
So to show a mouseover and mouseout comparison between these 2 mouseover for the POB 35 watt HID and mouseout for the Vinhnguyen54 dedomed XM-L2 6.5 amp TN31. Now you be the judge. I know which one I'm picking for the one that won.
That pool wall says it all. This even surprises me. :bigsmile:
Unthinkable!
That means this Vinhnguyen54 TN31 mod will easily out throw a FF4.
That’s what I say.
To be fair I’m gonna go take another TN31 shot to show the same beamshots from the exact same nite.
I will find out soon enough. I have a TN31mb and a Vinh modified TN31 coming. I also have a Vinh modified TK75 with dedomed emitters. My TN31mb was measured at 400k. It will be interesting how the TN31 modded by Vinh stacks up and depending on Brad’s pictures I might order a K40 as well. The TK75 with dedomed XM-L2s might be the most impressive light I have though. I also have a modded Dereelight that slightly out throws the TN31mb. If I had a decent camera I would probably bust my beam shot cherry but no dice there. Maybe I can see if I can borrow one.
Ok here you boys go to be fair. I picked the best out of 4 shots. So both of these samples were taken on the exact same nite. So mouseover POB 35 watt HID spotlight mouseout Vinhnguyen54 dedomed XM-L2 TN31.
Again I’ll have to pick the Vinhnguyen54 TN31.
Does that guy pay you for turning his pool into a hot tub? Lol
I really want to see the k40 modded compared to these.
I heay ya! No pay yet. LOL!
I’ll show you some beamshots soon. Vinh told me in a pm at CPFMP that he can’t really tell much difference between the TN31 that he does vs the K40.
Now who said this vinhnguyen54 TN31 wasn’t 500K?
Saablaster tested his POB 35watt 6000K spotlight on his light meter to be right at 531K lux if my memory is correct which I know it’s right at that number. I say mine should be right at what his was.
