MX Power ML-310 Review - In progress
29 posts / 0 new
Don
Don's picture
Last seen: 1 year 1 month ago
MX Power ML-310
Reviewer's Overall Rating: ★☆☆Copy and paste, maximum ★★★★★
CR123 size
Summary:
Battery: CR123/AA
Switch: Reverse clicky
Modes: 3 H/L/strobe
LED Type: Cree Q3
Lens: Plastic TIR optic
Tailstands: Yes
Price Payed: $13.65
Pros:
  • TIR optic (total internal reflection). Gives a beam unlike anything else. A big hotspot with next to no spill.
  • Strong clip
  • Essentially a 6 mode light as it is quite a bit less bright on AAs so you have RCR123 H/L/strobe and AA H/L/strobe
  • Can use alkalines, NiMH, 14500, CR123, RCR123. As long as you carry the extension tube for AAs
Cons:
  • Toothed bezel - a few minutes with a bench grinder will sort this out though.
  • For me the knurling and finning is excessive and too sharp.
  • Switch is not intended to be moved much - the O ring came out in 2 pieces. Will toss in another one and remember not to remove the switch.
  • I think it is ugly - many disagree.
  • Awful O rings - this may just be my one though. Water resistance highly questionable. Not that it'll stop me from trying it.
Features / Value: ★☆☆Copy and paste, maximum ★★★★★
This is going to be a few days in preparation. Now off to take photos. Interestingly, Mr. Admin has just put up a review of the Romisen RC-I3 which is a very similar type of light, but can take 2AAs which this one can't. I'm pretty sure it's a Cree XR-E LED but the TIR optic is very, very firmly attached to the PCB with the LED on it and it felt like I'd rip the LED clean out of it before the optic came off. From that quick look, the LED board appears to be only marginally in contact with the light body with poor implications for heatsinking. This may be unfair though. The photos will tell all once I get the thing torn apart. It already seems that I'm going to have to replace nearly all the O rings in it - unscrewing the bezel section caused another one to come out in more than one piece.
For me, the toothed bezel is annoying. I like a little scalloping on the bezel so you can tell whether the light is on or not, but these teeth are silly. They will shortly succumb to Mr. Grinder and his partner in crime, Ms. Diamond File. You only really notice the effect on the beam at close range and it isn't nearly as bad as the Klingon bezel in my sig. Since this light has no spill worth mentioning, the teeth don't affect it.
bezel
Build Quality: ★☆☆Copy and paste, maximum ★★★★★
O rings! The switch action is short, firm and positive. The knurling is a little sharp for my taste and will give no real advantage for grip as most of it isn't going to come into contact with your hands in normal use. The threads feel nice, no grating, graunching or squeaking here. I'd like to see more threading on the AA extension's male end though. That said, it isn't going to fall out. Nothing appears to be glued which is good if anything goes wrong. Water resistance is dubious, but might be OK. I will try this. I think that if I can remove the plastic bush in the AA adapter section it'll also take 17500 cells for more than double the runtime of an RCR123.
Plastic Bush
Battery Life: ★☆☆Copy and paste, maximum ★★★★★
Not yet known.
Light Output: ★☆☆Copy and paste, maximum ★★★★★
Throw 11260 high 2750 low (RCR123)
Lightbox 867 high 221low (RCR123) 157 high 40 low (NiMH)
There are a lot more numbers to gather.
Quick beamshots. It was raining and it never really gets fully dark at this time of year - oh, and I forgot to turn off the kitchen light behind me.
Control
Control shot
You can see the effect of the kitchen light in the foreground. Must cut the grass soon.
High - Eneloop
MX Power high
Low
Low
For comparison
BLF DeLight
DeLight
MDXL "3W" light
MDXL
Some better beamshots that show how the beam is like nothing else. These aren't even remotely comparable with the others above.
Control
Control
High
high
Low
low
See how the optic concentrates almost all of the light into the hotspot.
Summary: ★☆☆Copy and paste, use rounded average, maximum ★★★★★
From an hour's playing with it, I think I like it. Build quality is OK - Good but the O ring quality is Dire - Execrable.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Edited by: sb56637 on 09/02/2017 - 12:01 Reason: sb56637 replaced budgetlightforum.cz.cc with budgetlightforum.com via Scanner Search and Replace module.
Nothing
Last seen: 1 year 8 months ago
Hi Don,
Sorry for being a bit premature with my post as I know your review is in progress but if you come to strip it down please confirm that the bezel unscrews as in the DX picture because I'm damned if I can get it off mine?
Looking forward to hearing the rest of your views on the light.
Thanks,
Gary
Don
Don's picture
Mine certainly comes off - will have pictures up shortly. Nothing is glued on mine.
disassembled
juhha
Last seen: 1 month 1 week ago
I have two of these lights. Bought the first one just because...(DX shopping spree) When it came, took the AA extension off, placed a 16340 inside the tube, and almost got blinded! When pressing the switch, it takes 1/4 a second to turn on. (Write 100 times:  not to look into the led when the flashligh doesn't come on after pressing the switch!)  It has a pretty large hotspot and throws quite well for the size.
It is(most used) my farm EDC light. That's why I have 2.(neither broke. One to abuse and another to use...) I'm not very fond of it's looks, but I really like it's beam. It easily throws 60-70metres and gives a 10m wide usable ball of light. The clip is ok, but the screws are rubish. I don't know if it's because of abusing it, but they are always loosening up.
It's a zombie light a with designer beam.
I have also a Romisen RC-A4, that is this light's twin and I prefer the MX.The RC does not tail stand and even if it's a thrower, has much more spill.
One question: Can I change the romisens lens to a TIR one? Can I buy it on DX? Wich one?
Don
Don's picture
Short answer, probably.
Longer answer, the only such optic I can see on DX is
http://www.dealextreme.com/details.dx/sku.4628
which isn't the same. I searched using
http://www.dealextreme.com/products.dx/category.917~search.TIR%20optic
Probably find something suitable on www.dotlight.de if you live in the EU. German postage is hideously expensive though.
http://www.dotlight.de/en/LEDs/LED-High-Power/CREE-LEDs/Cree-Optics
These clip over the LED very firmly.
juhha
Thanks for the answer. I'll check those links with more detail later.
alfreddajero
alfreddajero's picture
I changed out the screws on mine for button head metric ones and also used blue loctite to keep them in place.
With Darkness, there will always be Light.
Don
Don's picture
Will probably replace them with better ones later on.
Nothing
Thanks Don.
It took a Herculean effort and a little bit of paint damage but finally managed to get it off.
I see what you mean about the attachment of the optic.
Cheers,
Gary
FlashPilot
FlashPilot's picture
Last seen: 37 min 12 sec ago
Hi Don,
Have you had any luck getting 17500's to fit by removing that bushing?
Don
Don's picture
Hi FP
In principle it looks like it ought to work, but that plastic bush is firmly attached in there and I suspect non-destructive methods are not going to work. There is no way any 18mm diameter cell is going in there and it is almost airtight with my allegedly protected 17500s. I've not yet seriously tried to shift the bush though - but the back half will accept my 17500s which are the same length as my protected 14500s.
FlashPilot
Hi Don,
So if I understand correctly, the AA aluminum battery extension has a plastic bushing inserted to hold a AA battery in place. You were able to insert a 17500 into that spacer up to the point where it contacts the bushing. Your protected 17500 is the same length as your protected 14500. This sounds like a great candidate for a dedicated 17500. Are you going to give it a try? You could always use paper or tape wrapped around a AA later if you wanted to go back..
Looking at the pic, It doesnt look like the male threaded part is much larger than the AA, so I dont see how the 17500 would fit. That would make the aluminum threaded part paper thin if that black ring is the entire thickness of the bushing. Am I seeing this correctly?
I can see how it might fit in the female end.
Id buy this for the dedicated 17500 light, but dont want to invest in 17500's and the light if it wont work that way.
Thanks for having a look! Cool
Don
Don's picture
It will, I am pretty sure fit, once that bush is pressed out. With what I've got to hand I couldn't get it out - using an A size NiMH (17670) as the pusher and a 20mm socket as the catcher turned out to be a bad idea. The cell contained quite a lot of energy still and vented quite impressively. It came from a totally dead laptop battery pack. I now have both thermal and alkali burns on my hand. Ah, just like the good old lab days. I have to go and see a mechanic tomorrow so I'll try it on a hydraulic press to press the bush out. Will let you know if it fits once I'm done.
Don
Don's picture
This is a 17500 in the main tube.
17500
And a 17500 with the head perched on it and the spacer alongside.
spacer
I've done enough destruction for one day so I'll leave the more energetic methods of debushing (Sadly voting for Obama worked in the US, but won't work in this light) for another day.
FlashPilot
Oh my gosh! I'm sorry you burned yourself (in more ways than one). I hope it isn't to serious.
After you recover, maybe you could try boiling it to see if that softens the plastic bushing, and then try again wearing gloves and a deep well socket.
With the 17500, this looks to be a fantastic EDC! What are your thoughts? Good luck with the press tomorrow!
FlashPilot
P.S. Thanks for the pics and the effort!
Don
Don's picture
I've had way, way worse. A pair of jeans used to last about a week before something nasty had eaten them. At 2 weeks my lab coat wouldn't have enough of it left to make a duster.
A mild burn to the left thumb is no big deal. I was a chemist back in the late 70's when that meant handling large quantities of dangerous materials all the time. And what I was testing was sewage just to add some biohazard fun. You did get to be good at washing your hands though....
Boiling is a good idea though - and remember not to use NiMH cells for drifting things out. Off to put the kettle on.
Don
Don's picture
Should be fun tomorrow.
"What did you get up to last night?"
"Oh, I boiled a couple of torches and baked one for an hour in the oven"
That should kill just about any conversation and probably lead to questions being asked about medication....
Don
Don's picture
Boiling doesn't seem to soften it enough to let it shift. Was well worth a try though. Time for a press tomorrow. It's probably drill out easily enough if I had a drill press but it'd be nice if this could be a reversible mod.
FlashPilot
HAHAHA! I just read your other thread about your HS-802. Sorry you're having such a hard time of it. I must say, you certainly are a tenacious fellow! (Damn those idiots that assemble these cheapo lights. LOL!) Perhaps a blow torch might be the next step. Following extraction, maybe a buffing with a rouge wheel to polish the aluminum adapter would add character and distinction. Does sodium hydroxide remove the paint and anodizing from the aluminum? Have you experimented with GITD paints on the host body?
Don
Don's picture
Caustic soda (sodium hydroxide) dissolves aluminium as well as anodising. As someone I know who was used to cast iron cylinder heads decided to decoke his aluminium cylinder head. Well there was no carbon on - but not much of a cylinder head either.
The glue lost to a great deal of force after an hour at 300C in the oven. I think I'll hide the scars with heatshrink.
meester
Last seen: 11 years 3 months ago
Does anyone know any other AA 14500 lights that can take a cut to accomodate a 17500. I know the Romisen RC-I3 can handle it. The Akoray 106 won't and neither will an Uniguefire S10.
(As some of you obviouly know on this site but for general info; lights that can handle a combination of AA 14500 and 16340 are only 1mm from being able to handle a 17500 and the jump from 880mah to 1300mah rated batteries.)
Pee myself laughing at you "voting for Obama worked in the US" comment. Haha good one. Maybe worked if you are old school USSR type. Nothing good about Obama if you think well of America.
Don
Don's picture
Don't know of any others, in general the compromises necessary to use multiple cells are not ones that the manufacturers care for - production costs get higher.
FlashPilot
Hi Don,
Have you had any luck in removing that bushing?
Don
Don's picture
Not yet, the mechanic was gone by the time I escaped from work. Just thought of another approach - now where did I put that 18mm dowel?
meester
Taping a piece of sandpaper to something that will fit into a drill can be pretty effective. While milling bits and rotary die grinder bits are useful they can be aggressive. Many drills can handle half inch inserts and that is close enough to build up with sandpaper. I mounted my drill in a "vise" and worked the light body up and down the shaft and got a nice consistent finish.
For my UniqueFire S10 I tried a 1/2" rotary file because I had a lot of meat to remove since it was only a AA/14500 body to begin with. The S10 can't get to 17500 size though.
FlashPilot
Hi Don,
Have you had any luck getting 17500's to fit yet? Yeah, I know you've been busy with other lights.
Don
Don's picture
Not yet - but I do have to get to see the mechanic this week as he's got my car to put in a new cylinder head gasket.
meester
It seems that the Akoray 16 is spec'd as 1 mm thicker than the 106. The threads ar nice but too deep on the 106 to open up for a 17500. The extra mm may be interesting. I may get it to try.I just wish it had an R5 to begin with.
