djozz's didn't-make-the-deadline-for-the-OLDIYfromscratchbuildcontest :-( entry
I was wondering how much that stuff would shrink. I believe there is some stuff that can be bought, that will shrink very little. The stuff that they use to do those scorpions and spiders inside the globes. I will have to look that up. I hope they still work for you when it's done.
What does I say. Cheating? I love it. I smiled the whole way through reading chapter one. I cant wait for chapter two. I must be on the wrong pain killers as you guys are so creative with what you do. Thanks for doing the build. Better late than never aye. Cheers.
Have you checked the thermal expansion coefficient of your resin? Maye the domes get pressen on again when you fire up the MT-G2. :wink:
(Casting electronics in resin can lead to interesting results. Still excited how it works out :-))
It would probably work if the casting was done on layers with a thinner layer at first.
This is really cool, & you have also given me an idea for a ‘standard’ torch mod in regards to the power circuit.
:beer: :beer: :beer:
This is the resin that is used for casting insects and stuff, it says so on the packaging. It might just stick better to the chitin skeleton of insects (and scorpions) than to silicone and brass...
That is great, even if the light fails, this has been both a good read and an inspiration for other mods. I'm a happy man .
And because I just had to know before carrying on I did a 'test drilling' through the plastic towards the battery poles and probed with the battery connected to two paperclips:
Still in business ....
Applause, hollering and whistles.
Drilling - resin - Jurassic Park!
Were you able to get any of the DNA out also :?
Too cool.
Friday was my last day at home alone, and worked as fast as I could to finish the built, I just wanted it done.
As I had tested: the cast-inside-polyester light worked , so there was reason to go on. I had to remove the excess polyester by sawing and sanding. i could do most of the rough work with the small bandsaw and the electric sander, but the top part with the raised bits had to be done by hand, and it gave me a little insight into what the work would have been if the original hand-build rules were to be followed in the whole build (I admire you hand-build guys for that). Then I hand-sanded all sides with 400 and then 800 sand paper, and polished the brass a bit with the Dremel. The Dremel was not good for polishing the polyester sides of the light. I managed to get the polyester reasonably clear by rubbing it endlessly with ordinary copier paper, I think it works by heating up and melting the top layer of the plastic by the rubbing movement .
Since animated GIF's are all the rave at the moment at BLF , I tought myself how to make them (though they are not as neat as some others I have seen), and so you will be bothered by no less than three of them . Here's one, of the cutaway of the excess polyester (I was lucky, the screws came out of the polyester easily):
Then I made the battery connections. I used a 9V battery connector and drilled away the rivets of the connection bits:
I used small brass M2 screws to attach them to the light.
For the switch-screws I wanted flat-head brass M4 screws, I did not have any and could not easily find some, so I used conical ones and soldered a partly bored out nut onto it. Then sanded it into shape. (million dollar question: what is the flashlight in the following picture )
So here is the end result, a wireless , 3-emitter, 4-mode, 9V flashlight, not as slick as planned, but I think it is charming:
joehoe, another animation :
operation and currents (test batteries are a Duracell 170mAh NiMh and a Conrad Energy 200mAh NiMh, freshly charged, all currents were recorded 5 seconds after switch-on, I don't think the light would survive the usual 30 seconds, apart from the moonlight modus , you can monitor the MT-G2 on your skin directly on the back of the emitter):
both screws loose: moonlight, all leds light up, the pretty mode), current 0.7mA with both batteries
left screw tightened, MT-G2 + XR-E light up, too hot within 20 seconds): 0.5A with Duracell, 0.7A with Conrad battery
right screw tightened, MT-G2 + XM-L light up, too hot within 20 seconds: 0.55A with Duracell, 0.8A with Conrad battery
both screws tightened, just the MT-G2 lights up, with 5s manual stepdown (IF bleeding hot, THEN loosen screws, fast): 1.7A with Duracell, 3A with Conrad battery
(The batteries drain about as fast as the light heats up whenever leaving moonlight :evil: )
I do not have a fresh 9V alkaline at the moment, I will add that later. Also I could not do output measurements because I do not have a integrating sphere, and a ceiling bounce measurement is impossible with a so broad flood (trust me, I tried, I even did an attempt to direct the light to the ceiling putting the light inside an old bicycle front lamp reflector). You can guess however that 3A through the MT-G2 will output about 2000 led-lumen (before the emitter heats up lightning-fast), so say that 50% of that actually manages to leave the light, 1000 lumens is pretty ok for this ieniemienie light .
Seemingly the light has just useless modes, with a moonlight that is 1 lumen the most, and three other modes that can't be used for more than seconds. But I found it is actually nice when it is used on empty alkalines, the direct drive MT-G2 squeezes the last bit out of them, with usable output most of the time. But let's not try to justify this light, it is built for fun .
Some beamshots, first is MT-G2+XR-E 2.5 meters from corner, second is just MT-G2 2.5 meters from corner, third is MT-G2 20cm from wall. Exposure is automatic (phone camera), the idea is that the pictures give an impression of the beam, not the brightness (but it is pretty bright alright )
The side-by-side emitters give nice shading effects in which you can also see what the difference in die size does, here's the shadow of my desk lamp, the MT-G2 plus XR-E together:
So that's it, I loved thinking about the design, and it was huge fun doing the build, and was a bit surprised that it actually worked. I can think of endless improvements on the design and how to build it now, but I doubt that I will ever actually make another one, the build was more a proof of concept than anything else. I will end with yet another animation of the light (on moonlight mode), and a gallery of the light together with some predecessors in its evolution that I build a few years ago. Thanks for reading .
Still a cool idea that I think you could improve on if you wanted to. I like the jigsaw effect. Since it kinda looks like Wall-e’s head, maybe it could have copper hair for heat dissapation. :arrow:
The hair idea sounds cool, I just thought about how to add fins, but wiring sounds much more appropriate here :-) . By the time the next contest is started I may change my mind about not building a successor, but I think (if I have the time to join the contest next year) I am more likely to try something completely different then.
That’s cool, Djozz. It seems you have a talent for the craft of modding.
that really is such a cool light. I think it’s my favourite build of anything I’ve ever seen on here. It’s just so… neat!
Well blow me down. Let there be light, and there was light. Well done djozz. The thing actually works not that I ever doubted your abilities. May I say a crazy light for a crazy ? Cheers.
Love the idea, love how you pulled it off, and absolutely love the animated gif’s showing it off! Well done, on many fronts!
The only way I’d build another raygun is if I were offered way too much. The idea is now stale even though I could do it better(maybe) the second time around. The hardest part is coming up with an idea that is worth putting all the time and effort into. The danger is coming up with that idea.
Thanks for all the compliments guys, I guess OL's competition brought a lot of build energy out of everyone joining. Now my serious build time is used up until next summer I'm afraid, from now it is back to modest late night modding for me, but that's fine as well
And now I'm going on a 5 day bicycle trip , leaving the family at home this time (I get 1 week leave from the family every year and that is now) . I just take some small EDC lights with me (with the DQG 18650 tiny NW clamped on the handle bar at night).
Cheers!
Nice machines you have there! :slight_smile:
Man, that turned out really good - hope you are able to join in for the next BLF DIY comp :slight_smile:
:beer: :beer:
