What do you think could cause an anodized coating to fade with only exposure to skin oils and a couple showers? I have one which has lost quite a bit of its color (click for bigger versions):
This shade of turquoise is a relatively subtle color though, so look what happens if I change its hue by 60 degrees to show how the same fading would look in blue: (all I changed was hue, nothing else)
Was this even anodized at all? Could it have been anodized and dyed but not sealed? Any other ideas what would explain this?
Does this mean we can have white coloured anodized type 2 lights?
If this is possible, I want to request that every light from now on is white anodizing.
Anodizing dyes are technically not opaque - they are translucent. Because of this, white is pretty much impossible - it will always be tinted toward the color of the base material - in this case, grey.
Yep. One other nice feature of the coating is that it will survive to whatever temperature the aluminum itself will survive. In other words, the coating will not be damaged, degraded, discolored or removed by heat until the point at which the aluminum melts.
The process of applying CeraFuse involves plasma discharge with temperature over 5000 Celsius… I wonder how much it costs to apply this to lights. How practical is this?
They're very nice people. The man to ask for is Peter Masella.
I, unfortunately, do not have time to manage a group buy - but if someone else wants to, I'm sure it wouldn't be a problem.
I never really thought about it before, but I will probably strip the anodize off of one of my lights and send it with our next batch. It would be really nice. It's just astonishing how hard this stuff is. Tough as nails doesn't even describe it because you can grind down a steel nail on aluminum coated with this stuff :)
Thats odd. It doesn’t entirely look like a wear pattern especially around the model name.
Try boiling just the body in water for 30 minutes (sealing it). If you don’t boil the head you could see if that continues to fade while the body doesn’t.
