Any updates :D?
How about now :D?
I'm awful aint I?
I'll do a minor update tomorrow. Integrating sphere might happen in a week, but taking it apart and modding will probably be over a month away.
Is there anything in particular that you're looking for?
Beamshots, lumens, battery life and lumens sag :D! THROW!
Id like to know whether I should choose D40A or X3 and neither you nor the have finished your reviews :P!
What's wrong with the beam shots I have up now? Do you mean wall shots?
I compared some lux readings here: https://budgetlightforum.com/t/-/20211#comment-446490
I still need to standardize how I take those readings before I add it to the top.
Lumens will require me to finish building and calibrating my integrating sphere bucket, and even that might be a while because I'm probably going to get a different lux meter that will require me to recalibrate and retest everything.
I can't do lumen sag.
Tailcap readings will come tomorrow, and battery life can be estimated from that.
I am still waiting for outdoor AA beamshots. How hard could this be?
I forgot about that. That's going to be at least a few days. I don't go out to that park at night on weekends. Too much gang activity.
Hi leaftye…. Many thanks for the review.
Btw, try setting your camera’s white balance to “tungsten”. This ought to be the right setting for the pics taken in your light box
For the outdoor shots leave it at the “daylight” setting. Hope this helps.
Added tailcap readings to the review.
I bet that'd really help with the light box pictures. I'll stick with the current setting for the outdoor beam shots so the comparisons between photo shoots is more direct. Thanks for the tips.
Well done with the beamshots, thanks!
Now, the question, do you have any multi AA light that you could compare X3 with regarding its output?
Another set of beamshots in such case would be too much asked, eh :P?
Only a short question:
Xintd x3 vs convoy L4? Wich is better?
If you can't beat em ....join em
Not sure if the xintd is the same as at other shops, but I noticed that my x3`s anodization isn't so strong...it looks good, but gets damaged easily.
I put it in a bag with 2 other lights, touching each other. When I took them out of the bag, the x3 had quite a few blemishes in its anodization.
Again, this might be different from the ones sold at IOS, because mine comes from BG.
Is it me or does the T6 HD2010 look brighter?
My opinion has limited value, but to my eyes, from the pics alone, the XIN has a slightly brighter hotspot. The HD has better spill. Hard to pick which I like though, as the HD seems a more effective ‘light’, while the XIN can make use of AA’s.
Which has better internals I have no idea. I think Id grab a XIN for the versatility of AA’s. I want a solarforce s2200 so spill in other lights seems pointless. I wont be buying 20 lights, just a few.
Famous last words! :)
-Garry
six of one, four score of the other.
How is the mode changing with this light? Do I have to wait forever to keep it from being reactivated in the next mode?
How heavy is this flashlight compared with HD2010? And what kind of button response does it offer?
It's a Qlite driver in the version sold by IOS, so it's the same as any other Qlite. That's to say it's pretty good. The one quirk is that it requires a quick double click to get that first mode change, and then it's a normal single press for the rest of the mode changes. I think this is to prevent accidental mode changes.
The button feels fine to me.
