REVIEW (IN PROGRESS): EagleTac TX25C2 XM-L2 U2
I think those things are not relative, they’re big cons. Rubbish UI and mode spacing are huge flaws in a light that’s supposed to be more versatile due to its size. I don’t know why they changed it, UI in G25C2 is much better for all-around flashlight. Modes like this: 7-459-965lm are useless for most users that want to actually use it instead of showing off. I like the size, brightness, throw etc, I’d buy one in a heartbeat but because of this UI I won’t spend ~$90 for something basically useless.
I know what you mean, it's been criticized more often by potential buyers than by final owners. I also referred to the many well-received "pseudo 2-mode" EDC lights on the market (4Sevens Quark, Nitecore MT-series, Klarus P-series, Jetbeam B-series, Armytek Partner-series, etc) and in practice it works out okay in many RL situations: 7lm (looks brighter because of focused spot) Low <-> 459lm Hi.
The 965lm could be considered 'extra'.
3 readily accessible modes makes operation of the light simpler than 4 or 5 modes because of the head position. G25C2 and SX25L3 have larger diameter heads .. so it's easier to distribute more modes to the head positions. i guess.
I love the simplicity of my Quark Tactical and Klarus P1A. I've been praising the Quark Tactical UI numerous times on this board. If the physical build quality and anodization were better, the Quark Tactical would be my top choice as RL light, EDC that is.
In the review i tried to make my point in case, so that potential buyers are not too deterred about the mode spacing. On the paper it looks drastic, in reality it's a fair design. I hear little serious complaints from adopters of the light, on the Russian and Geman folums it's been a very well-received light, on CPF too i think. Selling well, little complaints.
But i know what you're talking about. It's on paper.
Well its far from useless. If I’m outside and away from home, the TX25C2 is my EDC. I have no issue with the lumen spread. A fourth level could come in handy, but would likely complicate its easy to use UI.
Inside and around home I use my D25C clicky. It’s also a great little light. But the extra power and throw of the TX25C2 comes in handy when walking in nature & away from city lights.
My only issue regarding the modes is the lack of detent, physical or audible, to tell easily which mode you are in. So often I just start it in low and twist it to the desired level needed for the current application. Would be nice to start it in that mode from the get go though. Of course high(full tightened) and low(loosened over 1/2 turn) are easy to find before startup.
Because both groups are aware of the situation and potential buyers are the ones who found that mode spacing unacceptable. Actual owners are ok with it.
Not only on paper - on practice there’s no mode to lighten up objects 20-40m away. Low is too low, high is too bright with short runtime. 4 modes in G25C2 are easily accessible as well. TX25C2 may have just modes because of different design (but not different diameter - battery tubes have almost the same diameter) but that doesn’t explain why they got rid of the most useful mode and didn’t reduce high mode.
It was well received because it’s bright, throwy, small and well built flashlight light and actual owners were aware of mode spacing. But out of all aspects UI got the most compalints.
Phantom23, this should make you happy! ;)
https://budgetlightforum.com/t/-/21235#comment-462016
Not really, they’re all floody. I already sacrificed many lumens and bought Nitecore EC2 which is small, throwy and has nice UI.
Cool! That alignment works perfectly on mine as well. Thank you sir!
:evil:
:crazy:
One of the best reviews I’ve ever seen. Thanks a lot K!
Go ahead a brew a cup of coffee before you enjoy it. :slight_smile:
the first preliminary readings from the Fenix sphere are out!, and repeated measurements at different conditions (room temperature, cell model, cell quality, with SS bezel, without SS bezel) are carried out in order to ensure data integrity and reproducible data under the same conditions, and to guarantee definitive numbers to be published.
since the tests and results are very positive, already a heads up for the moment: Fenix lumens scale and EagleTac lumens scale are not too far apart, they are definitely in the same ballpark for the below so far tested ET lights! Well, the TX25C2 Hi-mode (40%) seems to be spec'ed too high but that's 1 outlier only.
In the review text i had called the light a "1000 Fenix lumen light" (before this very post) and that's true at 1sec after activation (996.6 lumens on the Fenix scale). After 30secs on Turbo, the output is 899.5lm on the Fenix scale, so Fenix would have printed "900 ANSI lumens" on the retail package, because ANSI measurement is taken 30secs after activation. In this sense, i should call it a "900 Fenix ANSI lumen light". It doesn't matter how i call the light. The point is that it is brighter than any Fenix light which is spec'ed with 899 Fenix ANSI lumens or lower. In the current Fenix catalog, the TX25C2 beats for example the output (at t=30sec) of:
T20C2 MkII XM-L U2 CW
mode CW spec max after 30sec
Lo spec 10 12.1 12.0
Med spec 90 90.8 89.4
Tu spec 600 634.9 602.7
TX25C2 XM-L2 U2 CW
Lo (0.5%) spec 7 9.1 8.9
Med (10%) spec 208 194.6 191.2
Hi (40%) spec 459 321.3 306.7
Tu (100%) spec 965 996.6 899.5
TX25C2 XM-L2 T6 NW
Lo (0.5%) calc "6.5" 7.8 7.8
Med (10%) calc "193" 173.9 171.1
Hi (40%) calc "426" 279.8 273.6
Tu (100%) calc "897" 890.8 821.1
The above numbers (blue boxed) may not be the very final numbers to be published in the review text, repeated measurements will show if they can be even bettered. Cell was protected NCR18650A.
selfbuilt had published "900 SB ANSI lumens" for the NW. The above (preliminary) table shows that Fenix would have spec'ed the NW with "821.1 Fenix ANSI lumens", which means that selfbuilt's numbers are
900/821.1 = 109.6% of the Fenix number.
On the one hand his "900" hit the (calculated NW) ET spec of "897" spot on, on the other hand both numbers are ~10% over the Fenix scale. Consequently, in his lightbox the CW would read 109.6%*899.5 = 985.9 SB ANSI lumens.
With this number, the TX25C2 CW would still be the lumens leader in the current table (with peak throw 109.6%*20,200 = 22,140 lux@1m):
That's today's info update. More to follow when more's available. Thanks for your attention.
i LOVE this light
Finally got a TX25C2 (did NOT pay $95) and….you’re right, it is SMALL! Smaller than the numbers and images can convey. It’s a hair brighter than the C12 (measured via the totally unscientific ‘bathroom bounce test’) but the C12 outthrows it by a good margin. Here’s a pic next to a Convoy S3 to help with perspective…
congrats to the purchase!! 8)
do you have a photo of C12 together with the squirrel eagletac? :)
It is dwarfed by the C12…which is a small light!
the C12 is so much bigger! better throw is to be expected then. can't surprise as much as the compact eagle ;)
thanks for the share tallboybass :beer:
Got mine modded by Vinh. I'm fairly certain it's pushing well over 1000 lumens on high now, and the throw, for such a small light is spectacular. On par with much larger lights.
Wish I’d bought this, my new SC600II is disappointing :frowning:
I sold mine as soon as I got the modded one back from Vinh.
I'll probably buy it again... love playing with the UI, but I'm going to hold off until xml2 NW version is out.
