I had a couple of CJ-1's from goldengadgets/ebay and a pair of Husky 1AA LED's from HomeDepot two years back and they worked pretty well for a good amount of time (one Husky's switch cap eventually wore out, and one CJ-1 from eBay broke when dropped on the concrete floor the other day).
I'm looking for a flashlight that's a bit brighter now, that gives about 25 lumens at least. I was reading earlier posts and the Powerlight only gives about 11 lumens. So it's not bright enough for my use:
Am I reading right? Or is there another choice that gives 25+ lumens?
I got an NF-05 from DX a few months back. The brightness was good enough for me (somewhat brighter than CJ-1), but the cap switch was really bad and constantly flickered/not working. DX sent me a replacement and that one's cap switch went bad a few weeks later also--so that's pretty frustrating. I was able to get up to 5 hrs runtime with usable brightness using an Eneloop AA so if it didn't have the bad switch I'd have ordered a few...
Right now, I'm not eager in getting a high power LED as I need a good amount of runtime (>=3 hours) and my budget is < $7. I don't need a perfect beam--as long as it lights up the area and works properly that'd work good for me.
because it falls right in the middle of a cheap bad tint chinese emitter and a low end old cree . the nf o5 is ugly tint sharp edged 4to5$ light..I think the powerlight IS a blf delight but don't take my word on it.5 to 10$ is a tuff range .usually cheap bodys bad threads not great clips at 10$ you starting to get into p4 q2 q3 emitters Like I said there is a hole in that price range anything good there would be a nice light to sell it would fill the hole .sadly there isn't much it's filled buy old AAA junky lights , multiple led lights which would be ok if they weren't junk 9 leds or 12 leds and lexeon emitter lights but you lose any hope of runtime with those .Jump up to a newer emitter and run on low or med and get the efficiency and the runtimes come up but the pices of the lights go up too . 30 lumens is a medium not a low, so you're asking for a 5 mode light to get a 30 lumen long runtime .I have a D-10 nitecore AA that runs 35 lumens 6 hours . you can aassume nitecore is doing it right and yet maybe that claim is high so lets say 5 hrs ....So an xpe R2 emitter ought to give you 4 hours at 35 lumens pretty easy good luck finding an xpe r2 for 7$.. you can't buy the emitter for that kind of money .. sounds to me like it's either a multiple 5 mm led light or another chinese emitter . or
I actually have a couple of the Coast Mini Tac 1AAA lights and I really love them also. But they're just a bit too dim for my use. On Coast's website there's a newer model G10 using 1AAA:
It claims to give 20 lumens and 4 hr runtime. Perhaps in real use it's like 15 lumens/3hr. But I'm not able to locate any place that carries it.
I think CJ-1 probably gives about 12-14 lumens roughly--somewhat brighter than the Mini Tac. It gives about 3 good hours of usable brightness and that's what I really like.
So a light that gives about 15-17 lumens is perhaps good enough for me (instead of 25-30 lumens).
Still, I'm not sure if anyone has spotted a useable light w/ about 17 lumens w/ some good runtime (3+hrs) with my price range (< $7). I guess I still have the 5-6 bucks mentality (CJ-1 used to cost like 4-5 bucks 2 years back).
Despite the rough edges and threads, beam, etc. on the NF-05 (I think it actually gives about 15-17 lumens), I am quite impressed by the runtime it gives--roughly 4.5-5 hours. I can leave a couple around the house/garage/car compartment box and I don't need to think about recharging often. But the bad switch just makes it unusable... . If I can figure out how to remove the switch (it's a plain plastic and no leverage to remove it) and fix it that'd be really nice.
Still have a good old bottle of WD40--and sure enough it helps!
It still works only 50% of the time now (before it was 90% not working). I'll keep clicking it on/off a bunch of times more and see if it eventually heals completely.
Now it's completely working. Thx E1320 -- that spray does the trick!
Now I have two NF-05's w/ working switches. :)
One of the NF-05 is dimmer than the other (one gives probably same output as CJ-1 -- perhaps 12-14 lumens, the other is brighter--perhaps 17-18 lumens). I'm going to keep them around now.
Yeah Wd 40 is the shizzle for switch cleaning ..it works wonders on pots. sadly it has gone way up in price .. the days of the dollar can of WD and a 1$ roll of duct tape fixing all that ails ya is over ..
I remember when i was young we.......(wanders off towards the garage muttering... ##*^++^**##darnkidsthesedays..)
OP, if you can pony up $10 more, this is an ideal power outage light: https://budgetlightforum.com/t/-/2599#comment-46681
MUCH MUCH better designed than any of the cheapo chinese ones.
But Boaz is right, $7 light with cree is not feasible. What you're specifically looking for is a low end cree or osram with a pwm low mode of <25% for as cheap as possible. The problem is that even if such a thing exist, it's basically going to be crap build quality, not the kind of thing for either using regularly or emergency.
Hi there gu9o7z, we're very glad to have you here!
I have ordered 3 interesting 1xAA lights for less than $4. I hope to do a comparison review of them when they arrive in a few weeks. This price point is still my passion. It's what started the B in BLF! :)
Another one that just came out that looks pretty nice is:
http://www.manafont.com/product_info.php/small-sun-zy5771-led-flashlight-black-aa-p-7131
There are quite a few places selling the power light hx-g011 which is basically the same as the BLF Delight from ebay. I agree there appears to be a large variation of reported brightness and run time by reviewers. Here are a few examples of sellers.
