REVIEW (IN PROGRESS): EagleTac TX25C2 XM-L2 U2
Cool! That alignment works perfectly on mine as well. Thank you sir!
:evil:
:crazy:
One of the best reviews I’ve ever seen. Thanks a lot K!
Go ahead a brew a cup of coffee before you enjoy it. :slight_smile:
the first preliminary readings from the Fenix sphere are out!, and repeated measurements at different conditions (room temperature, cell model, cell quality, with SS bezel, without SS bezel) are carried out in order to ensure data integrity and reproducible data under the same conditions, and to guarantee definitive numbers to be published.
since the tests and results are very positive, already a heads up for the moment: Fenix lumens scale and EagleTac lumens scale are not too far apart, they are definitely in the same ballpark for the below so far tested ET lights! Well, the TX25C2 Hi-mode (40%) seems to be spec'ed too high but that's 1 outlier only.
In the review text i had called the light a "1000 Fenix lumen light" (before this very post) and that's true at 1sec after activation (996.6 lumens on the Fenix scale). After 30secs on Turbo, the output is 899.5lm on the Fenix scale, so Fenix would have printed "900 ANSI lumens" on the retail package, because ANSI measurement is taken 30secs after activation. In this sense, i should call it a "900 Fenix ANSI lumen light". It doesn't matter how i call the light. The point is that it is brighter than any Fenix light which is spec'ed with 899 Fenix ANSI lumens or lower. In the current Fenix catalog, the TX25C2 beats for example the output (at t=30sec) of:
T20C2 MkII XM-L U2 CW
mode CW spec max after 30sec
Lo spec 10 12.1 12.0
Med spec 90 90.8 89.4
Tu spec 600 634.9 602.7
TX25C2 XM-L2 U2 CW
Lo (0.5%) spec 7 9.1 8.9
Med (10%) spec 208 194.6 191.2
Hi (40%) spec 459 321.3 306.7
Tu (100%) spec 965 996.6 899.5
TX25C2 XM-L2 T6 NW
Lo (0.5%) calc "6.5" 7.8 7.8
Med (10%) calc "193" 173.9 171.1
Hi (40%) calc "426" 279.8 273.6
Tu (100%) calc "897" 890.8 821.1
The above numbers (blue boxed) may not be the very final numbers to be published in the review text, repeated measurements will show if they can be even bettered. Cell was protected NCR18650A.
selfbuilt had published "900 SB ANSI lumens" for the NW. The above (preliminary) table shows that Fenix would have spec'ed the NW with "821.1 Fenix ANSI lumens", which means that selfbuilt's numbers are
900/821.1 = 109.6% of the Fenix number.
On the one hand his "900" hit the (calculated NW) ET spec of "897" spot on, on the other hand both numbers are ~10% over the Fenix scale. Consequently, in his lightbox the CW would read 109.6%*899.5 = 985.9 SB ANSI lumens.
With this number, the TX25C2 CW would still be the lumens leader in the current table (with peak throw 109.6%*20,200 = 22,140 lux@1m):
That's today's info update. More to follow when more's available. Thanks for your attention.
i LOVE this light
Finally got a TX25C2 (did NOT pay $95) and….you’re right, it is SMALL! Smaller than the numbers and images can convey. It’s a hair brighter than the C12 (measured via the totally unscientific ‘bathroom bounce test’) but the C12 outthrows it by a good margin. Here’s a pic next to a Convoy S3 to help with perspective…
congrats to the purchase!! 8)
do you have a photo of C12 together with the squirrel eagletac? :)
It is dwarfed by the C12…which is a small light!
the C12 is so much bigger! better throw is to be expected then. can't surprise as much as the compact eagle ;)
thanks for the share tallboybass :beer:
Got mine modded by Vinh. I'm fairly certain it's pushing well over 1000 lumens on high now, and the throw, for such a small light is spectacular. On par with much larger lights.
Wish I’d bought this, my new SC600II is disappointing :frowning:
I sold mine as soon as I got the modded one back from Vinh.
I'll probably buy it again... love playing with the UI, but I'm going to hold off until xml2 NW version is out.
SC600 can be modded? Or are you talking about the ET?
I contacted him….he told me he only does a dedome and copper…no driver mods. I assume yours got ‘the works’, right?
I'm talking about the ET.
I don't think the SC600II can be modded. In fact I'm waiting on word from Vinh whether he is willing to try to mod my ZL S6330.
“Why his review ended up being so wordy and not exactly informative, i’ll ask him about it, you betcha.” - :slight_smile:
scnr
had to add this photo with dinogirl to the review text *chuckle*
^ 10 helium balloons? ^
