the first preliminary readings from the Fenix sphere are out!, and repeated measurements at different conditions (room temperature, cell model, cell quality, with SS bezel, without SS bezel) are carried out in order to ensure data integrity and reproducible data under the same conditions, and to guarantee definitive numbers to be published.
since the tests and results are very positive, already a heads up for the moment: Fenix lumens scale and EagleTac lumens scale are not too far apart, they are definitely in the same ballpark for the below so far tested ET lights! Well, the TX25C2 Hi-mode (40%) seems to be spec'ed too high but that's 1 outlier only.
In the review text i had called the light a "1000 Fenix lumen light" (before this very post) and that's true at 1sec after activation (996.6 lumens on the Fenix scale). After 30secs on Turbo, the output is 899.5lm on the Fenix scale, so Fenix would have printed "900 ANSI lumens" on the retail package, because ANSI measurement is taken 30secs after activation. In this sense, i should call it a "900 Fenix ANSI lumen light". It doesn't matter how i call the light. The point is that it is brighter than any Fenix light which is spec'ed with 899 Fenix ANSI lumens or lower. In the current Fenix catalog, the TX25C2 beats for example the output (at t=30sec) of:
- TK22 XM-L2 U2, 680 Fenix ANSI lumens (1x18650) *lol*
- PD32UE XM-L T6, 740 Fenix ANSI lumens (1x18650)
- TK45 3×XP-G R5, 760 Fenix ANSI lumens (8xAA)
- PD35 XM-L2 U2, 850 Fenix ANSI lumens (1x18650)
- TK41 XM-L U2, 860 Fenix ANSI lumens (8xAA)
- TK35 XM-L2 U2, 860 Fenix ANSI lumens (2x18650)
T20C2 MkII XM-L U2 CW
mode | CW spec | max | after 30sec |
Lo | spec 10 | 12.1 | 12.0 |
Med | spec 90 | 90.8 | 89.4 |
Tu | spec 600 | 634.9 | 602.7 |
TX25C2 XM-L2 U2 CW
Lo (0.5%) | spec 7 | 9.1 | 8.9 |
Med (10%) | spec 208 | 194.6 | 191.2 |
Hi (40%) | spec 459 | 321.3 | 306.7 |
Tu (100%) | spec 965 | 996.6 | 899.5 |
TX25C2 XM-L2 T6 NW
Lo (0.5%) | calc "6.5" | 7.8 | 7.8 |
Med (10%) | calc "193" | 173.9 | 171.1 |
Hi (40%) | calc "426" | 279.8 | 273.6 |
Tu (100%) | calc "897" | 890.8 | 821.1 |
The above numbers (blue boxed) may not be the very final numbers to be published in the review text, repeated measurements will show if they can be even bettered. Cell was protected NCR18650A.
selfbuilt had published "900 SB ANSI lumens" for the NW. The above (preliminary) table shows that Fenix would have spec'ed the NW with "821.1 Fenix ANSI lumens", which means that selfbuilt's numbers are
900/821.1 = 109.6% of the Fenix number.
On the one hand his "900" hit the (calculated NW) ET spec of "897" spot on, on the other hand both numbers are ~10% over the Fenix scale. Consequently, in his lightbox the CW would read 109.6%*899.5 = 985.9 SB ANSI lumens.
With this number, the TX25C2 CW would still be the lumens leader in the current table (with peak throw 109.6%*20,200 = 22,140 lux@1m):
That's today's info update. More to follow when more's available. Thanks for your attention.
