SmallSun ZY-1104 AAA LED Flashlight Features
- Compact and portable design
- SmallSun ZY-1104 AAA LED Flashlight
- Powered by 3xAAA battery (not included)
- Durable Aluminum Alloy housing
- Constant current circuit
- ON/OFF power switch by pressing the end of the torch body
- One mode reverse clicky
- SmallSun ZY-1104 AAA LED Flashlight with built-in strap for carrying conveniently
- Perfect fit for home maintenance, outdoor activities, hiking, night fishing, camping, caving, hunting etc SmallSun ZY-1104 AAA LED Flashlight Specifications Brand/Model: SmallSun ZY-1104
Color: Black
Lens diameter: 31.7mm
Length: 111.7mm
Weight (including the packing): 110.0g
SmallSun ZY-1104 AAA LED Flashlight Package Included
1 x SmallSun ZY-1104 AAA LED Flashlight
This flashlight have a very special look ,it is use Cree XP-E Q5 , 3-Mode 280-Lumen LED Flashlight with Memory,prowed by 1* CR123A/1*16340.ON/OFF power switch by pressing the end of the torch body.For more information ,you can visit our website .
I'm very glad that you will like it ,and we will update the new arrival and top seller flashlight everyday ,now there is a coupon code WELCOMETOLIGHTAKE ,5% off everything until June 30th 2010,please hurry up and have a good time on it ,thanks !
Suterfire G2 XPE R5 5-mode 120 lumen LED Flashlight
This is a very nice flashlight ,it is a new brand for everyone ,but also have a good quality .It's use XRE-R5 LED ,With 5-Mode 120-Lumen,Hi > Med > Lo > SOS > Strobe .Prowered by 1*18650 battery .ON/OFF power switch by pressing the end of the torch body.Perfect fit for home maintenance, outdoor activities, hiking, night fishing, camping, caving, hunting etc
URL for this product : http://www.lightake.com/detail.do/sku.29211
OK ,thanks for your advice ,I will follow your advice ,if you have any other good advice ,you also can tell me ,and we will do our best to meet your's need ,or if you have and pruduct requests ,you also can tell me ,i will notice the purchasing department to purchase it ,thanks again for your advice !
SmallSun ZY-C60 Cree Q3-WC 180-Lumen LED Flashlight Torch Black $8.26
SmallSun ZY-C60 Cree Q3-WC 180-Lumen LED Flashlight Torch Features
- Compact and portable handheld design
- SmallSun ZY-C60 Cree Q3-WC 180-Lumen LED Flashlight Torch
- Powered by 1*CR123A batteries (not included)
- Aluminum Smooth and SMO Reflector
- 180 lumens max (manufacturer rated)
- Flashlight with built-in strap for carrying conveniently
URL for this flashlight : http://www.lightake.com/detail.do/sku.30524
Here is some more advice. I see your 5% discount coupon has expired. I would recommend that you always have an active discount for the members here any any other flashlight forum that you may visit regularly. I bought a few things with the last coupon and was going to buy some more things yesterday, but the coupon ran out, so I didn't buy anything, since I figured that there would be another coupon later.
AKOray K106 Cree Q5 5-Mode 160-Lumen LED Flashlight Gray
AKOray K106 Features
- AKOray K106 Cree Q5 5-Mode 160-Lumen LED Flashlight
- Powered by 1*AA battery (not included)
- Maxium Lumens: Output up to 160 Lumens (manufacture rated)
- Glass lens and aluminum orange peel reflector cup
- P.D.C Voltage range: 0.7-4.5V DC
- 5-Mode: Hi > Med > Lo > Strobe > SOS
- Flashlight with built-in clip for carrying conveniently
URL for this prouct: http://www.lightake.com/detail.do/sku.27971
SAiK SA-207 Cree Q3-WC 130-Lumen LED Flashlight Torch $9.49
SAiK SA-207 Cree Q3-WC 130-Lumen LED Flashlight Torch Features
- Brand New SAiK SA-207 Cree Q3-WC 130-Lumen LED Flashlight Torch
- Powered by 2xAAA batteries (not included)
- Coated glass lens and plastic smooth reflector cup
- Constant current circuit, voltage range: 0.8~13.0V, 1.5V Max.
- SAiK SA-207 LED Flashlight with built-in clip for carrying conveniently
URL for this flashlight : http://www.lightake.com/detail.do/sku.30602
SolarForce L2 Cree XP-G R5 5-Mode 320-Lumen LED Flashlight Features
- Brand New SolarForce L2 Cree XP-G R5 5-Mode 320-Lumen LED Flashlight
- Powered by 2x18650 batteries (not included)
- Coated glass lens and aluminum smooth reflector cup
- Constant current circuit, voltage range: 4.2~8.4V, 8.4V Max.
- 5 modes: Hi > Mid > Lo > Strobe > SOS
- SolarForce L2 LED Flashlight with built-in strap for carrying conveniently
- Come with Extension Tube
SolarForce L2 Cree XP-G R5 5-Mode 320-Lumen LED Flashlight Specifications
Brand: SolarForce
Model: L2
Emitter Brand/Type: Cree
Emitter BIN: XP-G R5
Color BIN: White
Brightness: 320 lumens maximum brightness (manufacturer rated)
Lens diameter: 32.1mm
Length: 200.0mm
Weight (including the packing): 153.0g
