Uniball Jetstream is the best pen period regardless of price. I’ve tried many, and all the pen review sites agree on this anyway. It’s a dye based hybrid ink ball point. “RT” is the retractable version and most available, though I like the classic capped one, but the refill is the same. It comes in 0.5/0.7/1.0mm with the last one most common in office stores. 0.7mm is the best compromise, because 0.5mm has more resistance. 1.0 is slightly smoother, though they’re all head and shoulders above competition. If you’re more into gel-ink, the Uniball 207 is better than overrated G2.
Cheapest Jetstream 101 model is a lesser refill. It’s not bad but not as surreal as full size refills.
If I ever made anything this perfect, I’d probably retire.
Parkers and the traditional $ pen brands are very nice on the outside, but tend to use outdated tech inside. Mont Blanc has nothing on Uniball when it comes to writing.
My favorite is Parker Jotter,
It is around $5-6 basic model, all metal model is about $15 here.
it is solid, easy to write, slim to carry in pocket.
And it is a pen on use more than 50 years. proven quality.
I have recently purchased one with gold plated parts and my name engraved on it.
Roller ball liquid inks flow well, but feather/blot and smear. Good for right handed cursive writing but mediocre elsewhere. The tech hasn’t been updated since the 90’s and gels in particular have replaced them.
Actually, most any Pilot pen can be swapped (same refills work in the G2, V7, G6, etc.) I love the fact that the 1.0 Pilots are runny, which puts out enough ink to keep writing fast. I used to didn’t like that, but the longer in the work world made me dislike the finer point ones.
Parker Jotter isn’t great for bigger hands or if you like to hold the pen closer to the tip. It’s on the skinny side and its tapered shape gets skinnier near the tip. It can get uncomfortable to hold, especially if you write for long stretches.
Plus, being stainless, it’s kind of heavy. Compared to a plastic pen, you can feel the weight after awhile.
I’m guessing those recommending Parkers haven’t written with inks developed in the last decade or two. It’s just an ordinary ball point which needs pressure to work, line changes with angle, and sometimes skips. Even the mediocre G2 is better.
I used to like those, but got tired of one too many leaking.
Those are a popular choice at work. They don't have the smoothest or finest writing, but they feel good in the hand and they don't look as cheap as they are, and maybe that's why clients always seem to take one when they leave.
I'm still working through boxes and boxes of this pen I bought over a decade ago, and will probably still be using them until I die unless they dry out or get lost. I don't know why I bought so many!
I'm anal about my pens. I'm also OCD about going back over my writing where the ink didn't come out or was too light. The Pilot G2 was the first pen I ever used that helped me stop the childish behavior of tracing over my writing. I absolutely love them! Depending on what I'm doing I prefer either the .7 (most used) or the .5. The 1.0 is way to thick for me.
Now when it comes to red-lining things during review at work I prefer the Pilot V7.
I love pens and I have quite a collection. Cheap ones as well as some better ones.
I´ve bought the famous Uniball Signo and the Pilot G2. I think both suck. They feel cheap and the ink dries very slowly (no matter what kind of paper I use them on).
The Schneider slide - viscoglide writes quite good and I like the feel of the Lamy Safari ballpen. But I have not found THE perfect cheapo pen yet.
I have been using a Fisher Bullet Pen with a cut down Zebra JK refills for a while, works for me. The original pressurized refills last much longer than the JK ones, but the feed is awful and they are expensive to replace.
I also carry a rolled gold yard-o-led mechanical pencil, lovely things to own and cheap enough second hand.
